<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM screencast switch automatically to desktop and starts on desktop (ON MAC contd))]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/10615/mmm-screencast-switch-automatically-to-desktop-and-starts-on-desktop-on-mac">MMM screencast switch automatically to desktop and starts on desktop (ON MAC)</a></p>
<p dir="auto">Having the same problem.<br />
Screencast appears on the desktop with a second instance of Electron simultaneously appearing on the dock.<br />
So not appearing in MM.<br />
Using one display i.e. the laptop.<br />
Has anyone got this working on a MAC?<br />
Does it work on a Windows platform or only on the Pi?<br />
Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16684/mmm-screencast-switch-automatically-to-desktop-and-starts-on-desktop-on-mac-contd</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 02:53:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16684.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Apr 2022 06:44:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM screencast switch automatically to desktop and starts on desktop (ON MAC contd)) on Fri, 29 Apr 2022 02:53:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rudiau" aria-label="Profile: rudiau">@<bdi>rudiau</bdi></a> the audit is useless.</p>
<p dir="auto">2.19 is greater than 2.1</p>
]]></description><link>https://forum.magicmirror.builders/post/101543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101543</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 29 Apr 2022 02:53:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM screencast switch automatically to desktop and starts on desktop (ON MAC contd)) on Fri, 29 Apr 2022 02:47:51 GMT]]></title><description><![CDATA[<p dir="auto">Well, that didn’t format as expected.</p>
]]></description><link>https://forum.magicmirror.builders/post/101542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101542</guid><dc:creator><![CDATA[rudiau]]></dc:creator><pubDate>Fri, 29 Apr 2022 02:47:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM screencast switch automatically to desktop and starts on desktop (ON MAC contd)) on Fri, 29 Apr 2022 02:45:49 GMT]]></title><description><![CDATA[<p dir="auto">Reinstalled Node.js, MM and Screencast.<br />
Pulled from the master.<br />
Two things I noticed:-</p>
<ol>
<li>
<p dir="auto">In MMM-Screencast.js it states:<br />
“requiresVersion: “2.1.0”, // Required version of MagicMirror”<br />
I’m running  v2.19.0) , does this matter?</p>
</li>
<li>
<p dir="auto"><strong>Terminal Reports</strong></p>
</li>
</ol>
<h1>npm audit report</h1>
<p dir="auto">&lt;ejs  3.1.7<br />
Severity: high<br />
Template injection in ejs - <a href="https://github.com/advisories/GHSA-phwq-j96m-2c2q" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/advisories/GHSA-phwq-j96m-2c2q</a><br />
No fix available<br />
node_modules/ejs<br />
peer-dial  *<br />
Depends on vulnerable versions of ejs<br />
node_modules/peer-dial</p>
<p dir="auto">2 high severity vulnerabilities</p>
<p dir="auto">Some issues need review, and may require choosing<br />
a different dependency.<br />
/&gt;<br />
Also this report from Terminal on MM boot.<br />
&lt;[29.04.2022 12:16.12.257] [LOG]   screencast stderr: objc[43214]: Class WebSwapCGLLayer is implemented in both /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libANGLE-shared.dylib (0x7ffa58e93318) <strong>and</strong> /Users/rudi/MagicMirror/modules/MMM-Screencast/node_modules/electron/dist/Electron.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libGLESv2.dylib (0x10b6de9c8). One of the two will be used. Which one is undefined.</p>
<p dir="auto">[29.04.2022 12:16.14.074] [LOG]   screencast stderr: [43212:0429/121614.073923:ERROR:service_worker_storage.cc(1904)] Failed to delete the database: Database IO error/&gt;<br />
My bolding.<br />
<em>One of the two will be used. Which one is undefined.</em>??<br />
Don’t understand.<br />
Any help?<br />
Thanks Rudi.</p>
]]></description><link>https://forum.magicmirror.builders/post/101541</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101541</guid><dc:creator><![CDATA[rudiau]]></dc:creator><pubDate>Fri, 29 Apr 2022 02:45:49 GMT</pubDate></item></channel></rss>
