<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Moment Timezone / Invalid time value]]></title><description><![CDATA[<p dir="auto">Suddenly after several months of a successful usage of my outlook calendar and the calendar-module a bug. Maybe somebody knows a suitable solution?</p>
<p dir="auto"><img src="/assets/uploads/files/1651433545863-1651431379897-819a41d6-e9e1-446b-be1d-12bc42fb474f-grafik.png" alt="1651431379897-819a41d6-e9e1-446b-be1d-12bc42fb474f-grafik.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1651433553588-111e60fb-7003-4cec-91ed-e0487b18bd6c-image.png" alt="111e60fb-7003-4cec-91ed-e0487b18bd6c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">also adding some lines of code didn’t fix the issue <a href="https://forum.magicmirror.builders/topic/15803/error-moment-timezone-has-no-data-for-customized-time-zone/6?_=1651432649589&amp;lang=de">https://forum.magicmirror.builders/topic/15803/error-moment-timezone-has-no-data-for-customized-time-zone/6?_=1651432649589&amp;lang=de</a></p>
<p dir="auto"><img src="/assets/uploads/files/1651433573151-1651433342853-857e2ad0-2824-4ad1-901b-0f48926f937b-image.png" alt="1651433342853-857e2ad0-2824-4ad1-901b-0f48926f937b-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/16711/moment-timezone-invalid-time-value</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 03:09:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16711.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 May 2022 19:33:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Wed, 04 May 2022 13:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> ok  moved event from Outlook to Google cal.</p>
<p dir="auto">then used multiple cal entries to merge the results together</p>
]]></description><link>https://forum.magicmirror.builders/post/101660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101660</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 May 2022 13:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Wed, 04 May 2022 13:07:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I deleted the bad event in outlook and added a new google calendar with that occurrence series in order to subscribe it againg with my outlook cal…</p>
]]></description><link>https://forum.magicmirror.builders/post/101658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101658</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Wed, 04 May 2022 13:07:38 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Wed, 04 May 2022 12:22:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> what did u do to fix it? so that we might help others</p>
]]></description><link>https://forum.magicmirror.builders/post/101656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101656</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 May 2022 12:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Wed, 04 May 2022 12:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok, sounds nasty… I recognized in my debug-logfile that those custom time zones were converted correctly. Just the null values were the  problem. Fixed for me now…</p>
]]></description><link>https://forum.magicmirror.builders/post/101655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101655</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Wed, 04 May 2022 12:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 19:00:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> said in <a href="/post/101623">Moment Timezone / Invalid time value</a>:</p>
<p dir="auto">why there are these null values in the array</p>
<p dir="auto">the luxon library (which handles repeating events) had a problem and returned trash(all nulls)</p>
<p dir="auto">doesn’t matter what other cal systems do… ours is hand written  by volunteers over many years…<br />
I spent a year getting it to handle timezone and std/dst time shifts…</p>
<p dir="auto">and then added on the MS crasy special TZ…(custom tz… what do you need THAT for)</p>
<p dir="auto">here is another crappy bug that every system has to handle…</p>
]]></description><link>https://forum.magicmirror.builders/post/101629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101629</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 May 2022 19:00:29 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 15:12:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am sorry, I don’t know anymore what the bad tz was.i believe it was undefined, but I don’t know… Sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/101624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101624</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 02 May 2022 15:12:50 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 15:12:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sorry for the wrong reply, it refers to <a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> …</p>
<p dir="auto">My local TZ seems to be right, but it don’t know, why there are these null values in the array. I subscribed my outlook calendar in another google calendar and it worked. These appointments are also rightly displayed in my iPhone, just by subcribing the outlook cal.</p>
]]></description><link>https://forum.magicmirror.builders/post/101623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101623</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Mon, 02 May 2022 15:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 15:06:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I just use Putty to connect via ssh. It won’t open a new window. You can check on your mirror or in browser, whether the mirror is loading the modules. When the error message appeared, I canceled the script via crtl + c. Then you have to search a bit in your logfile e.g.</p>
<pre><code>cat /pathtoyourfile/somefile.txt
<p dir="auto">in order to figure out where the wrong appointments are.  In my case it was more or less easy because the RangeError and the null-values in the array were very noisy.</p>
]]></description><link>https://forum.magicmirror.builders/post/101622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101622</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Mon, 02 May 2022 15:06:21 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 14:32:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> if u looked at the error messages, the UUID is a unique value, set in the ICS file… so you canget that and search for it…</p>
<p dir="auto">my question is</p>
<p dir="auto">do you think the ‘bad’ timezone was YOUR timezone?</p>
<p dir="auto">I could create a fix  to do the if undefined, set it to local system tz…</p>
<p dir="auto">i think the latest luxon library barfs now , where it used to return something…</p>
]]></description><link>https://forum.magicmirror.builders/post/101621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101621</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 May 2022 14:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 14:18:36 GMT]]></title><description><![CDATA[<p dir="auto">… solved for me now …</p>
<p dir="auto">I have just deleted one of my oldest serial appointments. It had one of the above tzid (unfortunately I don’t know which one) and the error messages have disappeared …</p>
]]></description><link>https://forum.magicmirror.builders/post/101620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101620</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 02 May 2022 14:18:36 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 14:00:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  yes, of course I did. I work exclusively via ssh. But the command above seems to try to open a window. Unfortunately, this then breaks off with</p>
<pre><code>/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
<p dir="auto">i found these tzid</p>
<pre><code>"tzid":"W. Europe Standard Time"
"tzid":"undefined"
"tzid":"Customized Time Zone"
<p dir="auto">The first one is my time zone.<br />
I try to identify the outlook calender entries, so that i can probably fix this there. I’m just wondering why this suddenly occurs. So it must be a newly added appointment that is causing the problem. I just can’t remember which appointments I have recently added :worried_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/101619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101619</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 02 May 2022 14:00:51 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 13:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> you of course enabled SSH on the pi, right??</p>
<p dir="auto">so you can do this from the ssh session</p>
<p dir="auto">you can also download the ics on your PC to examine, search for TZID</p>
<p dir="auto">is the TZID for you local tz??  I may be able to create a fix for this</p>
<p dir="auto">but I don’t want to drag in looking up the broken TZID… already do this for all the MS created non-standard<br />
junk.</p>
]]></description><link>https://forum.magicmirror.builders/post/101618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101618</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 May 2022 13:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 13:46:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have now also received this error message. Unfortunately, my mirror is “deeply” integrated so that I cannot connect a keyboard and mouse. So I cannot easily create the log file as described above without removing the mirror from the wall.</p>
<p dir="auto">Is it possible to recognise the wrong time zone from the data excerpt you posted here?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> said in <a href="/post/101608">Moment Timezone / Invalid time value</a>:</p>
<p dir="auto"><img src="/assets/uploads/files/1651475948004-40447359-e2a8-40b7-bceb-826bf7bd3088-grafik.png" alt="40447359-e2a8-40b7-bceb-826bf7bd3088-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I couldn’t find anything suspicious at the moment. What have I overlooked?</p>
<p dir="auto">Thank you<br />
Sepp</p>
]]></description><link>https://forum.magicmirror.builders/post/101617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101617</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 02 May 2022 13:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 11:31:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> can u fix that in outlook?</p>
<p dir="auto">is it your local TZ?</p>
]]></description><link>https://forum.magicmirror.builders/post/101613</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101613</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 May 2022 11:31:23 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 07:19:09 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1651475948004-40447359-e2a8-40b7-bceb-826bf7bd3088-grafik.png" alt="40447359-e2a8-40b7-bceb-826bf7bd3088-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101608</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101608</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Mon, 02 May 2022 07:19:09 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Mon, 02 May 2022 07:14:43 GMT]]></title><description><![CDATA[<p dir="auto">thanks, I found the wrong calendar entry!<br />
I have inserted a recurring event that seems to have been converted by Outlook as a wrong Customized Time Zone…</p>
]]></description><link>https://forum.magicmirror.builders/post/101607</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101607</guid><dc:creator><![CDATA[thger1312]]></dc:creator><pubDate>Mon, 02 May 2022 07:14:43 GMT</pubDate></item><item><title><![CDATA[Reply to Moment Timezone / Invalid time value on Sun, 01 May 2022 20:41:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thger1312" aria-label="Profile: thger1312">@<bdi>thger1312</bdi></a> see this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/16617/error-moment-timezone-has-no-data-for-customized-time-zone/2?_=1650986841061">https://forum.magicmirror.builders/topic/16617/error-moment-timezone-has-no-data-for-customized-time-zone/2?_=1650986841061</a></p>
<p dir="auto">if you turn on debug</p>
<p dir="auto">add  , “DEBUG”</p>
<p dir="auto">to the   config.js  so that it looks like this</p>
<pre><code>	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
<p dir="auto">then if using pm2,</p>
<pre><code>pm2 stop all
cd ~/MagicMirror
npm start  &gt;somefile.txt 2&gt;&amp;1
<p dir="auto">run til the cal should appear</p>
<p dir="auto">ctrl-c on the npm start  window</p>
<p dir="auto">then edit the somefile.txt and search for  error ,<br />
RangeError</p>
<p dir="auto">you should find the troubling cal event…</p>
<p dir="auto">the timezone should be  America/New York , instead of  EST5EDT<br />
(or whatever your timezone is, from the IANA timezone database <a href="https://www.iana.org/time-zones" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.iana.org/time-zones</a></p>
<p dir="auto">neither MM nor the library, nor any of the javascript libraries used to parse the ICS file contents uses the timezone definitions inside the ICS file.</p>
<p dir="auto">MM DID change the luxon library in this release which is used on the specific call that fails with that error</p>
<p dir="auto">last person I helped, their cal event looked like this</p>
<pre><code>BEGIN:VEVENT
DTSTART;TZID=EST5EDT:20220118T080000     &lt;------ these two lines are the trouble
DTEND;TZID=EST5EDT:20220118T090000   &lt;------
RRULE:FREQ=MONTHLY;WKST=SU;INTERVAL=1;BYMONTHDAY=18
DTSTAMP:20220425T012218Z
]]></description><link>https://forum.magicmirror.builders/post/101604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101604</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 01 May 2022 20:41:00 GMT</pubDate></item></channel></rss>
