<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mmm-amazon-photos - slideshow not working]]></title><description><![CDATA[<p dir="auto">Hello All,</p>
<p dir="auto">First post (and I am a Newbie) so please be understanding :)</p>
<p dir="auto">I have issues with getting MMM-Amazon-Photos to do slideshow for some reason… here is my config</p>
<pre><code>{
      module: 'mmm-amazon-photos',
      // position is important
      position: 'fullscreen_below',
		  slideshowSpeed: 60 * 60 * 1000,
		  imageUrls: ['https://www.amazon.co.uk/photos/share/MyShare']
        // see below for configurable options
<p dir="auto">I have also tried with this config too but same result:</p>
<pre><code>{
		  slideshowSpeed:  10000,
<p dir="auto">Any help anyone could offer would be greatly appreciated!</p>
<p dir="auto">Many Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/16733/mmm-amazon-photos-slideshow-not-working</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:54:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16733.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 May 2022 19:44:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mmm-amazon-photos - slideshow not working on Mon, 09 May 2022 10:49:00 GMT]]></title><description><![CDATA[<p dir="auto">I cannot see any errors relating to the module in the console…</p>
<p dir="auto">I have raised it as issue on the GitHub repo.</p>
<p dir="auto">Many thanks for your help.</p>
<p dir="auto">Regards</p>
<p dir="auto">KD</p>
]]></description><link>https://forum.magicmirror.builders/post/101727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101727</guid><dc:creator><![CDATA[KD]]></dc:creator><pubDate>Mon, 09 May 2022 10:49:00 GMT</pubDate></item><item><title><![CDATA[Reply to mmm-amazon-photos - slideshow not working on Sun, 08 May 2022 11:57:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kd" aria-label="Profile: KD">@<bdi>KD</bdi></a> the author made some update a couple months ago  so I would open an issue on the GitHub repo</p>
<p dir="auto">also look in the developers window console<br />
ctrl-shift-i, select the console tab and scroll up to see any errors.</p>
<p dir="auto">u can filter the messages by putting a unique part of the module name in the filter field</p>
]]></description><link>https://forum.magicmirror.builders/post/101718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101718</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 May 2022 11:57:52 GMT</pubDate></item><item><title><![CDATA[Reply to mmm-amazon-photos - slideshow not working on Sun, 08 May 2022 10:13:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hey Sam - it just displays one image of the album and it doesn’t rotate any other images… if I reboot the RPi or if I refresh MM it changes the image… but sits on that single image…</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/101717</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101717</guid><dc:creator><![CDATA[KD]]></dc:creator><pubDate>Sun, 08 May 2022 10:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to mmm-amazon-photos - slideshow not working on Sat, 07 May 2022 20:02:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kd" aria-label="Profile: KD">@<bdi>KD</bdi></a> could you tell us what happens?</p>
]]></description><link>https://forum.magicmirror.builders/post/101709</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101709</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 May 2022 20:02:48 GMT</pubDate></item></channel></rss>
