<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Module not found error]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">A few modules after install, in this case both MMM-Homeassistant &amp; MMM-Awesome Alexa on startup indicate "module not found<br />
Yes, I do run npm install in the folder<br />
I have checked my config, reinstalled, updated the module but cannot get it working<br />
If I comment the module out all is fine</p>
<p dir="auto">Any help will be appreciated</p>
<pre><code>[07.05.2022 23:14.30.436] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
Require stack:
- /home/johanba/MagicMirror/modules/MMM-HomeAssistant/node_helper.js
- /home/johanba/MagicMirror/js/app.js
- /home/johanba/MagicMirror/js/electron.js
- /home/johanba/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
[07.05.2022 23:14.30.439] [LOG]   Loading module helpers ...
[07.05.2022 23:14.30.440] [LOG]   No helper found for module: MMM-pages.
[07.05.2022 23:14.30.441] [LOG]   No helper found for module: alert.
[07.05.2022 23:14.30.442] [LOG]   No helper found for module: clock.
[07.05.2022 23:14.30.444] [LOG]   No helper found for module: MMM-COVID19.
[07.05.2022 23:14.30.444] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.445] [LOG]   Module helper loaded: EXT-Alert
[07.05.2022 23:14.30.445] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.446] [LOG]   Module helper loaded: Gateway
[07.05.2022 23:14.30.447] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.447] [LOG]   Module helper loaded: MMM-Todoist
[07.05.2022 23:14.30.448] [LOG]   No helper found for module: MMM-WebView.
[07.05.2022 23:14.30.448] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.449] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
[07.05.2022 23:14.30.450] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.451] [LOG]   Module helper loaded: EXT-Detector
[07.05.2022 23:14.30.451] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.452] [LOG]   Module helper loaded: MMM-GoogleAssistant
[07.05.2022 23:14.30.452] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.453] [LOG]   Module helper loaded: EXT-Pir
[07.05.2022 23:14.30.454] [LOG]   Initializing new module helper ...
[07.05.2022 23:14.30.455] [LOG]   Module helper loaded: MMM-MacAddressScan
[07.05.2022 23:14.30.457] [ERROR] App threw an error during load
[07.05.2022 23:14.30.459] [ERROR] Error: Cannot find module 'request'
Require stack:
    at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
    at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1105)
    at Function.Module._resolveFilename (/home/johanba/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (node:internal/modules/cjs/loader:785:27)
    at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
    at Module.require (node:internal/modules/cjs/loader:1012:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/home/johanba/MagicMirror/modules/MMM-HomeAssistant/node_helper.js:2:17)
    at Module._compile (node:internal/modules/cjs/loader:1116:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
[07.05.2022 23:14.30.461] [ERROR] Whoops! There was an uncaught exception...
[07.05.2022 23:14.30.468] [ERROR] Error: Cannot find module 'request'
Require stack:
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/johanba/MagicMirror/modules/MMM-HomeAssistant/node_helper.js',
    '/home/johanba/MagicMirror/js/app.js',
    '/home/johanba/MagicMirror/js/electron.js',
    '/home/johanba/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[07.05.2022 23:14.30.472] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.05.2022 23:14.30.473] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[07.05.2022 23:14.30.770] [LOG]   Launching application.
^C/home/johanba/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
]]></description><link>https://forum.magicmirror.builders/topic/16735/module-not-found-error</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 23:23:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16735.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 May 2022 05:34:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Module not found error on Sun, 08 May 2022 09:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> said in <a href="/post/101715">Module not found error</a>:</p>
<p dir="auto">Error: Cannot find module ‘request’</p>
<p dir="auto">This is your error.  See below post to resolve.<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/101716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101716</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Sun, 08 May 2022 09:06:54 GMT</pubDate></item></channel></rss>
