<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Troubleshooting Steps?]]></title><description><![CDATA[<p dir="auto">Hi, I’ve been looking for a good reference for troubleshooting and haven’t found one.  I’ve been having some issues with MM resource usage building over time (slowdowns, TOP output showing CPU usage &gt; 100%, etc).  The standard clock module gets slow and it starts skipping 5-10 seconds at a time (not that it’s jumping in time, it’s just taking that long for that particular module to update).  This will usually start happening within 24 hours of a MM restart, and resets when I reset MM (pm2 reset MM).</p>
<p dir="auto">I’d like to do the work myself, but where to start?  No meaningful output in the logs.  Nothing useful in the developer console on the browser when looking at MM in a browser window, unless I’m not looking in the right place here.</p>
<p dir="auto">Some other weirdness - when MM is running slowly on my directly attached monitor, a browser on a network connected computer rendering the same MM will not be running slowly.</p>
<p dir="auto">Any general troubleshooting steps to look at?  I see there are a number of electron processes running but I don’t know how many there should be.</p>
<pre><code>uname -a
Linux innsmouth 5.13.0-40-generic #45~20.04.1-Ubuntu SMP Mon Apr 4 09:38:31 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
<p dir="auto">Running the following modules:</p>
<ul>
<li>MMM-CalendarExt2</li>
<li>MMM-EveryNews</li>
<li>MMM-GoogleTasks</li>
<li>MMM-Jast</li>
<li>MMM-MoonPhase</li>
<li>MMM-OpenWeatherMapForecast</li>
<li>MMM-pages</li>
</ul>
<p dir="auto">Looking to get into module development but trying to figure some other stuff out before I do that.  Appreciate the help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/16741/troubleshooting-steps</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 05:58:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16741.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 May 2022 23:23:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Troubleshooting Steps? on Sat, 14 May 2022 00:09:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/themox" aria-label="Profile: themox">@<bdi>themox</bdi></a> I don’t know. been quite a while since I’ve seen any spam posting issues.</p>
]]></description><link>https://forum.magicmirror.builders/post/101822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101822</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 14 May 2022 00:09:30 GMT</pubDate></item><item><title><![CDATA[Reply to Troubleshooting Steps? on Fri, 13 May 2022 22:23:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/themox" aria-label="Profile: themox">@<bdi>themox</bdi></a> <img src="/assets/uploads/files/1652480528847-screen-shot-2022-05-13-at-6.21.22-pm.png" alt="Screen Shot 2022-05-13 at 6.21.22 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This forum is the worst.  I can’t write a useful response because it gets flagged as spam.  I can’t attach any document with copy &amp; paste able text in it because only pictures are allowed.  See attached for a screenshot of the response I wrote originally.</p>
<p dir="auto">What am I doing that is getting flagged as spam?  I think the spam bot AI needs some tweaking.</p>
]]></description><link>https://forum.magicmirror.builders/post/101821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101821</guid><dc:creator><![CDATA[themox]]></dc:creator><pubDate>Fri, 13 May 2022 22:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to Troubleshooting Steps? on Fri, 13 May 2022 22:18:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> My reply keeps getting flagged as spam so I can’t write a longer response.  Bottom line, yes.</p>
]]></description><link>https://forum.magicmirror.builders/post/101820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101820</guid><dc:creator><![CDATA[themox]]></dc:creator><pubDate>Fri, 13 May 2022 22:18:36 GMT</pubDate></item><item><title><![CDATA[Reply to Troubleshooting Steps? on Mon, 09 May 2022 23:44:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/themox" aria-label="Profile: themox">@<bdi>themox</bdi></a> do you have pages set to auto rotate?</p>
]]></description><link>https://forum.magicmirror.builders/post/101741</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101741</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 May 2022 23:44:02 GMT</pubDate></item><item><title><![CDATA[Reply to Troubleshooting Steps? on Mon, 09 May 2022 23:41:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/themox" aria-label="Profile: themox">@<bdi>themox</bdi></a> the fact that the remote browser is ok  means that is some issue with the local browser.</p>
<p dir="auto">top should show chromium tasks as the busiest.<br />
if you look at the logs, both the terminal session where npm start is done  and the browser side console u might see something.</p>
<p dir="auto">after 24 hours seems to indicate an update refresh kind of thing</p>
]]></description><link>https://forum.magicmirror.builders/post/101740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101740</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 May 2022 23:41:02 GMT</pubDate></item></channel></rss>
