<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen/Text Size]]></title><description><![CDATA[<p dir="auto">New to the project, and a beginner with coding.</p>
<p dir="auto">When I start MM, it goes full screen, but shows the same thing in each location, and it is cut off as the text is displaying too large.  If I hit F11 and resize the window, I start to see the text at a more normal size and can finally see more than one module, but still doesn’t display as intended.</p>
<p dir="auto">How do I get it to show at full screen with the right dimensions when I start it?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16770/screen-text-size</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 06:40:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16770.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2022 13:46:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 17:52:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> ok</p>
]]></description><link>https://forum.magicmirror.builders/post/101901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101901</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 17:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 17:14:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Got it, I don’t believe it was setup. It wasn’t starting after reboot or after closing the window.</p>
]]></description><link>https://forum.magicmirror.builders/post/101900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101900</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 17:14:03 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 17:04:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> no… I was only asking about what you did on the manual install</p>
<p dir="auto">my script does PM2.</p>
]]></description><link>https://forum.magicmirror.builders/post/101899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101899</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 17:04:48 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 16:47:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It is on a hdmi to dvi adapter, but I actually have a different cable arriving today, so I’ll attempt again after it gets here. Thank you for all your help so far. The autostart feature asked be during the install if I wanted to use it, a y/N option, and I selected y. Should I change anything about that?</p>
]]></description><link>https://forum.magicmirror.builders/post/101898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101898</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 16:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 16:41:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a>   did you setup for autostart using the manual procedure?</p>
<p dir="auto">pm2 replaces that… so you should dlete that setup if you did it…  (as it looks like with 2 autostarts)</p>
]]></description><link>https://forum.magicmirror.builders/post/101897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101897</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 16:41:23 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 16:38:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> strange…</p>
<p dir="auto">ok, my guess is a bad cable from pi to display</p>
<p dir="auto">I had seen some flakiness on DVI-D display with an hdmi-&gt;DVI adapter…<br />
a different adapter had no trouble with the same cable</p>
]]></description><link>https://forum.magicmirror.builders/post/101896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101896</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 16:38:39 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 16:32:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Completed the steps you outlined. Moved the directory and then ran the install script your provided.  Looks like a similar problem is still popping up. The 2nd image is fullscreen screenshot with the 1st showing an example of how it changes if the size of the window is changed.</p>
<p dir="auto"><img src="/assets/uploads/files/1652804972794-2022-05-17-122733_1920x1080_scrot.png" alt="2022-05-17-122733_1920x1080_scrot.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1652804972709-2022-05-17-122609_1920x1080_scrot.png" alt="2022-05-17-122609_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here’s the log from the installers folder<br />
pm2 setup starting - Tue May 17 12:21:58 EDT 2022<br />
using parameter bash<br />
system is Linux raspberrypi 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux<br />
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster<br />
node version v16.5.0<br />
force installing latest npm version via npm<br />
npm version 8.10.0<br />
pm2 installed<br />
get the pm2 platform specific startup command<br />
startup command = sudo env PATH=$PATH:/usr/local/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi<br />
[PM2] Init System found: systemd<br />
Platform systemd<br />
Template<br />
[Unit]<br />
Description=PM2 process manager<br />
Documentation=<a href="https://pm2.keymetrics.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pm2.keymetrics.io/</a><br />
After=network.target</p>
<p dir="auto">[Service]<br />
Type=forking<br />
User=pi<br />
LimitNOFILE=infinity<br />
LimitNPROC=infinity<br />
LimitCORE=infinity<br />
Environment=PATH=$PATH:/usr/local/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin<br />
Environment=PM2_HOME=/home/pi/.pm2<br />
PIDFile=/home/pi/.pm2/pm2.pid<br />
Restart=on-failure</p>
<p dir="auto">ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect<br />
ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all<br />
ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill</p>
<p dir="auto">[Install]<br />
WantedBy=multi-user.target</p>
<p dir="auto">Target path<br />
/etc/systemd/system/pm2-pi.service<br />
Command list<br />
[ ‘systemctl enable pm2-pi’ ]<br />
[PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service<br />
[PM2] Making script booting at startup…<br />
</p><div class="plugin-markdown"><input type="checkbox" />Executing: systemctl enable pm2-pi…</div><br />
[PM2] [v] Command successfully executed.<br />
±--------------------------------------+<br />
[PM2] Freeze a process list on reboot via:<br />
$ pm2 save<p></p>
<p dir="auto">[PM2] Remove init script via:<br />
$ pm2 unstartup systemd<br />
pm2 startup command done<br />
configure the pm2 config file for MagicMirror<br />
start MagicMirror via pm2 now<br />
save MagicMirror pm2 config now<br />
pm2 setup completed - Tue May 17 12:22:06 EDT 2022</p>
]]></description><link>https://forum.magicmirror.builders/post/101895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101895</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 16:32:50 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 15:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> rename the MM folder</p>
<pre><code>cd  ~
mv MagicMirror MagicMirror.old
<p dir="auto">then run my install script , see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/101889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101889</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 15:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Correct, didn’t get any output. I did it manually, maybe try reinstalling?</p>
]]></description><link>https://forum.magicmirror.builders/post/101888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101888</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 14:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:57:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> weird…</p>
<p dir="auto">did u get any output from the command? should not have</p>
<p dir="auto">I assume you had a good desktop  after boot…  with the temples…</p>
<p dir="auto">how did you install MM?  manual or scripted?</p>
]]></description><link>https://forum.magicmirror.builders/post/101887</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101887</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 14:57:17 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:53:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1652799149956-2022-05-17-105158_1920x1080_scrot.png" alt="2022-05-17-105158_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Followed your instructions again. This came up. The repeated forecast doesn’t seem to change, but the two bigger texts were popping up and changing.</p>
]]></description><link>https://forum.magicmirror.builders/post/101886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101886</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 14:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:46:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> ok, stop MagicMirror again</p>
<p dir="auto">and then do</p>
<pre><code>rm -rf ~/.config/Electron
<p dir="auto">then restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/101885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101885</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 14:46:49 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:42:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> The screen is attached to the hardware and is intended to be the screen I will be using for the project.  It’s a Pi 4</p>
<p dir="auto"><img src="/assets/uploads/files/1652798475512-2022-05-17-104051_1920x1080_scrot.png" alt="2022-05-17-104051_1920x1080_scrot.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1652798475407-2022-05-17-103832_1920x1080_scrot.png" alt="2022-05-17-103832_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101884</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 14:42:48 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:23:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> what OS is this? on what hardware? PI?   is that view on the screen attached to hardware, or over VNC?</p>
<p dir="auto">can u do, from the commandline while MM is running</p>
<pre><code>ps -ef | grep -i magicmirror
<p dir="auto">you should get a list of things…</p>
]]></description><link>https://forum.magicmirror.builders/post/101883</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101883</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 14:23:32 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the response. Yes I do want it full screen, my apologies, I just meant that it wasn’t displaying properly when in full screen.</p>
<p dir="auto">I followed your instructions, and this is what I am currently getting<br />
<img src="/assets/uploads/files/1652796558876-2022-05-17-100410_1920x1080_scrot.png" alt="2022-05-17-100410_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101882</guid><dc:creator><![CDATA[mrdger]]></dc:creator><pubDate>Tue, 17 May 2022 14:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to Screen/Text Size on Tue, 17 May 2022 14:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdger" aria-label="Profile: mrdger">@<bdi>mrdger</bdi></a> sorry, not quite sure I understand</p>
<p dir="auto">said it goes full screen, yes that is what its supposed to do</p>
<p dir="auto">but shows the same thing in each location</p>
<p dir="auto">eh?  what does that mean?  if its full screen then what is location?</p>
<p dir="auto">try this , maybe,</p>
<p dir="auto">stop magicMirror</p>
<pre><code>cd ~
rm -rf .config/electron
<p dir="auto">note the . in front of config<br />
restart MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/101881</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101881</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 May 2022 14:00:46 GMT</pubDate></item></channel></rss>
