<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bring Forward&#x2F;Send Back]]></title><description><![CDATA[<p dir="auto">If I have two modules , each of which occupies a different zone is there a way to set which module overlays the other?<br />
I have iframe module set top_center then stock ticker in bottom bar.<br />
Ticker runs behind iframe but I want to run it in front of iframe.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16775/bring-forward-send-back</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 22:47:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16775.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 May 2022 20:06:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bring Forward&#x2F;Send Back on Wed, 18 May 2022 20:26:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> use the z-index in css on the module content</p>
<p dir="auto">use the dev window to test</p>
<p dir="auto">more positive is closer to the user on top of things  more negative is away from the user, behind things</p>
]]></description><link>https://forum.magicmirror.builders/post/101923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101923</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 May 2022 20:26:44 GMT</pubDate></item></channel></rss>
