<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use of Samsung „The Frame“ with MM]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">did anyone use Samsungs The Frame together with MM?</p>
<p dir="auto">From what I had read the TV sounds like a good solution for my dashboard screen idea. My MM will be 80% of the time show all my pictures and 20% of the time weather, news and calendar.</p>
<p dir="auto">It will not have a mirror and sit in the living room.</p>
<p dir="auto">Happy to get any feedback from you.</p>
<p dir="auto">Christian</p>
]]></description><link>https://forum.magicmirror.builders/topic/16785/use-of-samsung-the-frame-with-mm</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 18:55:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16785.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 May 2022 06:28:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sun, 22 May 2022 11:33:21 GMT]]></title><description><![CDATA[<p dir="auto">It looks like there are different firmware features. Depending on the hardware.</p>
<p dir="auto">Great thx Samsung. Now I have to find out when this option is available. I’m not really willing to spend 500€ for a picture frame. Then I can rather buy a monitor and have a nice wooden frame built by a carpenter.</p>
]]></description><link>https://forum.magicmirror.builders/post/101986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101986</guid><dc:creator><![CDATA[MajorC]]></dc:creator><pubDate>Sun, 22 May 2022 11:33:21 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sun, 22 May 2022 07:06:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/majorc" aria-label="Profile: MajorC">@<bdi>MajorC</bdi></a><br />
I did not find this option as a setting on my Frame (latest Firmware). Unfortunately, I also can‘t test this because I don’t have a Anynet device</p>
]]></description><link>https://forum.magicmirror.builders/post/101983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101983</guid><dc:creator><![CDATA[Jalibu]]></dc:creator><pubDate>Sun, 22 May 2022 07:06:05 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sun, 22 May 2022 05:39:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Following the comments in your link, Samsung has made it possible by a firmware update.</p>
<p dir="auto">Maybe <a class="plugin-mentions-user plugin-mentions-a" href="/user/jalibu" aria-label="Profile: Jalibu">@<bdi>Jalibu</bdi></a> can double-check the behavior.</p>
]]></description><link>https://forum.magicmirror.builders/post/101982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101982</guid><dc:creator><![CDATA[MajorC]]></dc:creator><pubDate>Sun, 22 May 2022 05:39:07 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 15:33:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/majorc" aria-label="Profile: MajorC">@<bdi>MajorC</bdi></a> said in <a href="/post/101979">Use of Samsung „The Frame“ with MM</a>:</p>
<p dir="auto">If no one is in front of the frame, it should switch to “frame mode” and display a picture.</p>
<p dir="auto">that is a good question…</p>
<p dir="auto">looks like not<br />
<a href="https://us.community.samsung.com/t5/QLED-and-The-Frame/Feature-Request-CEC-Anynet-options-to-prevent-Frame-switching/td-p/1287539" target="_blank" rel="noopener noreferrer nofollow ugc">https://us.community.samsung.com/t5/QLED-and-The-Frame/Feature-Request-CEC-Anynet-options-to-prevent-Frame-switching/td-p/1287539</a></p>
<p dir="auto">looks like if u turn it off with CEC then its ‘off’, not frame mode</p>
]]></description><link>https://forum.magicmirror.builders/post/101980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101980</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 21 May 2022 15:33:29 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 15:25:34 GMT]]></title><description><![CDATA[<p dir="auto">My idea was to run MM via HDMI and a Raspberry when I am in the room.</p>
<p dir="auto">But do not know if it works that way. Or if I just take a normal monitor and have a frame built.</p>
]]></description><link>https://forum.magicmirror.builders/post/101979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101979</guid><dc:creator><![CDATA[MajorC]]></dc:creator><pubDate>Sat, 21 May 2022 15:25:34 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 13:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jalibu" aria-label="Profile: Jalibu">@<bdi>Jalibu</bdi></a> i don’t think that was what he was asking…  but maybe he will chime in…</p>
<p dir="auto">I have a precursor to the frame, 82in samsung with the external hdmi ports…   MM works fine over hdmi<br />
(google ChromeCast does the same thing)</p>
]]></description><link>https://forum.magicmirror.builders/post/101977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101977</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 21 May 2022 13:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 12:58:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
haha, of course it works with HDMI ;-)</p>
<p dir="auto">But I think this question is about Samsung The Frame specific features and not TVs in general 🙃</p>
]]></description><link>https://forum.magicmirror.builders/post/101976</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101976</guid><dc:creator><![CDATA[Jalibu]]></dc:creator><pubDate>Sat, 21 May 2022 12:58:40 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 11:30:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jalibu" aria-label="Profile: Jalibu">@<bdi>Jalibu</bdi></a> not running ON/IN the TV, but thru a separate HDMI port. you should be able to do anything u want</p>
<p dir="auto">HDMI signal is  an HDMI signal. TV doesn’t know what is being displayed</p>
]]></description><link>https://forum.magicmirror.builders/post/101973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101973</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 21 May 2022 11:30:48 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 10:39:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/majorc" aria-label="Profile: MajorC">@<bdi>MajorC</bdi></a><br />
I have a Samsung the Frame, but you can only display photos in the power-saving Art Mode and not a browser. This is also not possible in Ambient Mode.</p>
]]></description><link>https://forum.magicmirror.builders/post/101971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101971</guid><dc:creator><![CDATA[Jalibu]]></dc:creator><pubDate>Sat, 21 May 2022 10:39:18 GMT</pubDate></item><item><title><![CDATA[Reply to Use of Samsung „The Frame“ with MM on Sat, 21 May 2022 10:11:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/majorc" aria-label="Profile: MajorC">@<bdi>MajorC</bdi></a><br />
Samsung’s tizen os has sonehow outdated chromium, so some of modern 3rd party modules might not work, but I think default modules ok.</p>
]]></description><link>https://forum.magicmirror.builders/post/101970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101970</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Sat, 21 May 2022 10:11:03 GMT</pubDate></item></channel></rss>
