<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best bet for those not technically inclined?]]></title><description><![CDATA[<p dir="auto">I’m building a Magic Mirror for a family that is not technically inclined and I want to proactively minimize the tech support they will need to keep this going.</p>
<p dir="auto">What are my best bets?</p>
<p dir="auto">Maybe write a script that updates all modules as was as magic mirror on every reboot?</p>
<p dir="auto">Maybe run a client and setup a server in my home and point the client to that?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16872/best-bet-for-those-not-technically-inclined</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 01:29:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16872.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jun 2022 01:19:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Thu, 16 Jun 2022 07:17:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah, I totally agree with that.<br />
But it really depends on the modules. Thus, some sort of endurance test might be useful before shipping the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/102301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102301</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Thu, 16 Jun 2022 07:17:16 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Wed, 15 Jun 2022 19:26:53 GMT]]></title><description><![CDATA[<p dir="auto">I recommend dataplicity (<a href="https://www.dataplicity.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dataplicity.com/</a>). Easy to connect remotely without DDNS or Portforwarding setup.</p>
]]></description><link>https://forum.magicmirror.builders/post/102297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102297</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Wed, 15 Jun 2022 19:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Wed, 15 Jun 2022 13:07:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> SD cards are not suited to all the disk writes caused by daily reboot…</p>
<p dir="auto">no more than weekly…</p>
<p dir="auto">I don’t reboot mine months on end.<br />
admittedly I don’t have lots of modules</p>
]]></description><link>https://forum.magicmirror.builders/post/102290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102290</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 15 Jun 2022 13:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Wed, 15 Jun 2022 12:07:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sifuhall" aria-label="Profile: sifuhall">@<bdi>sifuhall</bdi></a> I’d second <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s recommendation. If it works, it works. But I still would prepare some kind of remote access, just in case.<br />
What I would add, too, is a cronjob that reboots the mirror once a day at night. Depending on number and sort of modules, you might get into RAM issues or crashes, which decreases the user experience.</p>
]]></description><link>https://forum.magicmirror.builders/post/102289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102289</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Wed, 15 Jun 2022 12:07:15 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Tue, 14 Jun 2022 19:11:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sifuhall" aria-label="Profile: sifuhall">@<bdi>sifuhall</bdi></a> - What I do for the mirrors I give as gifts is I set up a reverse SSH connection to a URL that I control. Whenever I need to connect to the mirrors, I start up a cloud VM and have that VM change the DNS entry for that URL to point to itself. Alternately, you could set up a dynamic DNS entry to your home and have the mirror connect directly to your house.</p>
<p dir="auto">With the cloud VMs, this allows me to spin up a machine, wait 5 minutes for the mirrors to connect to it, then SSH to the machine and then down to each mirror. At that point, I can change the <code>config.js</code> or run updates as necessary.</p>
]]></description><link>https://forum.magicmirror.builders/post/102284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102284</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 14 Jun 2022 19:11:04 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Tue, 14 Jun 2022 10:45:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks for the reply.</p>
<p dir="auto">I don’t live there, and I will take your advice and leave it alone if it is working.</p>
]]></description><link>https://forum.magicmirror.builders/post/102279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102279</guid><dc:creator><![CDATA[sifuhall]]></dc:creator><pubDate>Tue, 14 Jun 2022 10:45:19 GMT</pubDate></item><item><title><![CDATA[Reply to Best bet for those not technically inclined? on Tue, 14 Jun 2022 01:41:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sifuhall" aria-label="Profile: sifuhall">@<bdi>sifuhall</bdi></a> you live there?</p>
<p dir="auto">turn off the notifications module<br />
disabled:true</p>
<p dir="auto">then maybe create a script that will check for module updates.  altho if it’s working I would leave it alone.</p>
<p dir="auto">I have an updates script for the base.<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a><br />
but again you f it’s working don’t fiddle w it.</p>
<p dir="auto">no reason to remote the system, it’s the same stuff either way. no point having two of them to deal with.</p>
<p dir="auto">backup, backup , backup</p>
<p dir="auto">test it once…  at least</p>
]]></description><link>https://forum.magicmirror.builders/post/102273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102273</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jun 2022 01:41:04 GMT</pubDate></item></channel></rss>
