<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-forecast-io migration to OpenWeatherMap from DarkSky]]></title><description><![CDATA[<p dir="auto">I’ve just updated my fork of MMM-forecast-io</p>
<p dir="auto">DarkSky, the source of data for this module is shutting down!   Dark Sky API will end on March 31st, 2023 as per: <a href="https://blog.darksky.net/" target="_blank" rel="noopener noreferrer nofollow ugc">https://blog.darksky.net/</a></p>
<p dir="auto">I’ve looked around, and OpenWeather seems to be the easiest alternative.  I’ve ported my fork to the new data source.  Bug reports welcome, but seems to be running well so far.</p>
<p dir="auto">The screen and display are essentially the same, only the data source has changed.</p>
<p dir="auto"><a href="https://github.com/FlatPepsi17/MMM-forecast-io" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/FlatPepsi17/MMM-forecast-io</a></p>
<p dir="auto">Enjoy - and feel free to steal my code changes to update other forks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/16888/mmm-forecast-io-migration-to-openweathermap-from-darksky</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 02:21:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16888.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jun 2022 19:33:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Tue, 28 Jun 2022 03:48:34 GMT]]></title><description><![CDATA[<p dir="auto">Felt inspired, added full metric support.  Units set via the config file.</p>
<ul>
<li>‘imperial’ for Fahrenheit temp and MPH wind</li>
<li>‘metric’ for Celsius temp and Meters Per Second wind</li>
</ul>
<p dir="auto">Graph now should scale appropriately when using non-default widths.</p>
]]></description><link>https://forum.magicmirror.builders/post/102496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102496</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Tue, 28 Jun 2022 03:48:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Sat, 25 Jun 2022 16:34:22 GMT]]></title><description><![CDATA[<p dir="auto">I’m still squashing bugs here and there - big update today. This one should be stable.</p>
]]></description><link>https://forum.magicmirror.builders/post/102456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102456</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Sat, 25 Jun 2022 16:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Mon, 20 Jun 2022 01:54:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doctorwhen" aria-label="Profile: doctorwhen">@<bdi>doctorwhen</bdi></a> Haven’t explored that one yet.  The community really needs multiple weather sources - not a fan of being limited to just one resource!</p>
]]></description><link>https://forum.magicmirror.builders/post/102383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102383</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Mon, 20 Jun 2022 01:54:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Mon, 20 Jun 2022 01:53:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> See the first link of the first post.</p>
]]></description><link>https://forum.magicmirror.builders/post/102382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102382</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Mon, 20 Jun 2022 01:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Sun, 19 Jun 2022 14:48:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flatpepsi" aria-label="Profile: FlatPepsi">@<bdi>FlatPepsi</bdi></a> Good to see you are ahead of the game as DarkSky is shutting down next year. Did you consider the successor to DarkSky, <a href="https://developer.apple.com/weatherkit/" target="_blank" rel="noopener noreferrer nofollow ugc">WeatherKit</a> ? I have not yet checked it out and it is currently in Beta. I am happy with OpenWeather, just curious about WeatherKit.</p>
]]></description><link>https://forum.magicmirror.builders/post/102359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102359</guid><dc:creator><![CDATA[doctorwhen]]></dc:creator><pubDate>Sun, 19 Jun 2022 14:48:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Sun, 19 Jun 2022 05:28:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flatpepsi" aria-label="Profile: FlatPepsi">@<bdi>FlatPepsi</bdi></a> Hi, can you please send me your changes or upload them here? Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/post/102349</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102349</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Sun, 19 Jun 2022 05:28:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-forecast-io migration to OpenWeatherMap from DarkSky on Fri, 17 Jun 2022 19:43:58 GMT]]></title><description><![CDATA[<p dir="auto">For anyone else using Dark Sky, Open Weather has a nice migration page with a table of field name changes between the two.</p>
<p dir="auto">The overall data format is very close to the same, making migration easier.</p>
<p dir="auto"><a href="https://openweathermap.org/darksky-openweather" target="_blank" rel="noopener noreferrer nofollow ugc">https://openweathermap.org/darksky-openweather</a></p>
]]></description><link>https://forum.magicmirror.builders/post/102325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102325</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Fri, 17 Jun 2022 19:43:58 GMT</pubDate></item></channel></rss>
