<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Voice-Control - only black screen after installation.]]></title><description><![CDATA[<p dir="auto">After I installed the module, the display remains completely black when the MM2 started.</p>
<p dir="auto">Can someone help me?</p>
<p dir="auto">npm start -dev<br />
magicmirror@2.1.0 start /home/pi/MagicMirror<br />
electron js/electron.js<br />
Starting MagicMirror: v2.1.0<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: MMM-Voice-Control.<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
No helper found for module: clock.<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
All module helpers loaded.<br />
Starting server op port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: MMM-DWD-WarnWeather<br />
MMM-DWD-WarnWeather helper started…<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Connecting socket for: MMM-WatchDog<br />
Staring module helper: MMM-WatchDog<br />
Connecting socket for: MMM-FRITZ-Box-Callmonitor<br />
Starting module: MMM-FRITZ-Box-Callmonitor<br />
Connecting socket for: MMM-Remote-Control<br />
Starting node helper for: MMM-Remote-Control<br />
Connecting socket for: MMM-Admin-Interface<br />
Starting node helper for: MMM-Admin-Interface<br />
Connecting socket for: MMM-Fuel<br />
Starting module: MMM-Fuel<br />
Sockets connected &amp; modules started …<br />
Launching application.</p>
<p dir="auto">/home/pi/.pm2/logs/mm-error-0.log<br />
without content</p>
]]></description><link>https://forum.magicmirror.builders/topic/1690/mmm-voice-control-only-black-screen-after-installation</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 02:41:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1690.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Feb 2017 20:50:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:21:54 GMT]]></title><description><![CDATA[<p dir="auto">In the module is an error.<br />
The annyang.js file must be manually copied from the directory “dist” to the directory of the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/13916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13916</guid><dc:creator><![CDATA[Q14siX]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:21:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:15:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/q14six" aria-label="Profile: Q14siX">@<bdi>Q14siX</bdi></a> the second should fix your issue</p>
]]></description><link>https://forum.magicmirror.builders/post/13915</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13915</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:15:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:14:40 GMT]]></title><description><![CDATA[<p dir="auto">Yes, already several times.</p>
<p dir="auto">But:</p>
<p dir="auto">npm install<br />
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’<br />
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’<br />
npm WARN modules No description<br />
npm WARN modules No repository field.<br />
npm WARN modules No README data<br />
npm WARN modules No license field.</p>
<p dir="auto">And:</p>
<p dir="auto">~/MagicMirror/modules/MMM-Voice-Control $ npm install<br />
Magic-Mirror-Module-Voice-Control@1.0.0 /home/pi/MagicMirror/modules/MMM-Voice-Control<br />
└── annyang@2.6.0</p>
]]></description><link>https://forum.magicmirror.builders/post/13914</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13914</guid><dc:creator><![CDATA[Q14siX]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/q14six" aria-label="Profile: Q14siX">@<bdi>Q14siX</bdi></a> did you run <code>npm install</code> in the module directory?</p>
]]></description><link>https://forum.magicmirror.builders/post/13913</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13913</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:10:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Initializing MagicMirror.<br />
translator.js:182 Loading core translation file: translations/de.json<br />
translator.js:204 Loading core translation fallback file: translations/en.json<br />
loader.js:182 Load script: modules/MMM-Voice-Control//MMM-Voice-Control.js<br />
module.js:415 Module registered: MMM-Voice-Control<br />
loader.js:152 Bootstrapping module: MMM-Voice-Control<br />
loader.js:182 Load script: modules/MMM-Voice-Control//node_modules/annyang/annyang.js<br />
annyang.js Failed to load resource: the server responded with a status of 404 (Not Found)</p>
]]></description><link>https://forum.magicmirror.builders/post/13912</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13912</guid><dc:creator><![CDATA[Q14siX]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 21:06:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/q14six" aria-label="Profile: Q14siX">@<bdi>Q14siX</bdi></a> you are posting the terminal log but when you start with npm start dev you have a window on the side which has also a console log</p>
]]></description><link>https://forum.magicmirror.builders/post/13911</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13911</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 07 Feb 2017 21:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 20:59:18 GMT]]></title><description><![CDATA[<p dir="auto">No changes…</p>
<p dir="auto">npm start dev<br />
electron js/electron.js “dev”<br />
Connecting socket for: MMM-SystemStats<br />
]]></description><link>https://forum.magicmirror.builders/post/13910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13910</guid><dc:creator><![CDATA[Q14siX]]></dc:creator><pubDate>Tue, 07 Feb 2017 20:59:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Voice-Control - only black screen after installation. on Tue, 07 Feb 2017 20:54:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/q14six" aria-label="Profile: Q14siX">@<bdi>Q14siX</bdi></a> can you start the mirror with <code>npm start dev</code> and check if you can spot an error in the console there? the log you posted looks fine cant see an issue here</p>
]]></description><link>https://forum.magicmirror.builders/post/13909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13909</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 07 Feb 2017 20:54:47 GMT</pubDate></item></channel></rss>
