<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ERROR:node_controller.cc(585)] Trying to re-add dropped peer]]></title><description><![CDATA[<p dir="auto">My MagicMirror works fine for a few days and then the screen goes black. The errors in the log look like this:</p>
<pre><code>&lt;--- Last few GCs ---&gt;
[1:0x28003d0000] 209716297 ms: Mark-sweep (reduce) 611.5 (708.2) -&gt; 611.4 (686.2) MB, 2337.4 / 4.3 ms  (average mu = 0.625, current mu = 0.046) last resort GC in old space requested
[1:0x28003d0000] 209718766 ms: Mark-sweep (reduce) 611.4 (686.2) -&gt; 611.3 (680.0) MB, 2469.7 / 4.9 ms  (average mu = 0.444, current mu = 0.000) last resort GC in old space requested
&lt;--- JS stacktrace ---&gt;
[1971:0624/001659.568718:ERROR:node_controller.cc(585)] Trying to re-add dropped peer DCF39E05685563B4.545691B8F0544120
[1973:0624/001659.568999:ERROR:node_controller.cc(585)] Trying to re-add dropped peer DCF39E05685563B4.545691B8F0544120
<p dir="auto">Here is the pm2 info:</p>
<pre><code>┌───────────────────┬──────────────────────────────────────────┐
│ status            │ online                                   │
│ name              │ MagicMirror                              │
│ namespace         │ default                                  │
│ version           │ 2.19.0                                   │
│ restarts          │ 3                                        │
│ uptime            │ 36m                                      │
│ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
│ script args       │ N/A                                      │
│ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
│ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
│ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
│ interpreter       │ bash                                     │
│ interpreter args  │ N/A                                      │
│ script id         │ 0                                        │
│ exec cwd          │ /home/pi/MagicMirror                     │
│ exec mode         │ fork_mode                                │
│ node.js version   │ N/A                                      │
│ node env          │ N/A                                      │
│ watch &amp; reload    │ ✔                                        │
│ unstable restarts │ 0                                        │
│ created at        │ 2022-06-24T05:15:29.610Z                 │
 Revision control metadata
│ revision control │ git                                            │
│ remote url       │ https://github.com/MichMich/MagicMirror.git    │
│ repository root  │ /home/pi/MagicMirror                           │
│ last update      │ 2022-06-24T05:15:30.131Z                       │
│ revision         │ a2d7cdcfb425c2a51715bbaf663c2feb267a9798       │
│ comment          │ Merge pull request #2834 from MichMich/develop │
│                  │ Release v2.1                                   │
│ branch           │ master                                         │
 Divergent env variables from local env
│ PWD            │ /home/pi/MagicMirror                               │
│ SSH_CONNECTION │ 192.168.1.64 40866 192.168.1.14 22                 │
│ SHLVL          │ 2                                                  │
│ XDG_SESSION_ID │ 4                                                  │
│ SSH_CLIENT     │ 192.168.1.64 40866 22                              │
│ PATH           │ /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin: │
]]></description><link>https://forum.magicmirror.builders/topic/16917/error-node_controller-cc-585-trying-to-re-add-dropped-peer</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 04:05:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16917.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jun 2022 05:58:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Thu, 14 Jul 2022 02:53:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> long term update after trying a few things out, the MMM-GoogleMapsTraffic module was the culprit. I started going down the path of trying to update the javascript issues when I discovered that your fork fixed them already. I uninstalled the original and installed yours and I haven’t had the black screen once since.</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-GoogleMapsTraffic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-GoogleMapsTraffic</a></p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/102830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102830</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Thu, 14 Jul 2022 02:53:50 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Thu, 14 Jul 2022 02:55:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> cool</p>
]]></description><link>https://forum.magicmirror.builders/post/102831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102831</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Jul 2022 02:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Thu, 14 Jul 2022 02:53:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> long term update after trying a few things out, the MMM-GoogleMapsTraffic module was the culprit. I started going down the path of trying to update the javascript issues when I discovered that your fork fixed them already. I uninstalled the original and installed yours and I haven’t had the black screen once since.</p>
]]></description><link>https://forum.magicmirror.builders/post/102830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102830</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Thu, 14 Jul 2022 02:53:50 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 18:15:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> the console which you know and the browser console</p>
<p dir="auto">ctrl-shift-i, select the console tab and scroll up<br />
red text is typically errors</p>
]]></description><link>https://forum.magicmirror.builders/post/102579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102579</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jul 2022 18:15:46 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 17:18:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok, I’m starting with the google photos module and see how it goes. Are there any other logs that might be helpful for debugging?</p>
]]></description><link>https://forum.magicmirror.builders/post/102578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102578</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Fri, 01 Jul 2022 17:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 17:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> hm…not seen problems related to those, but time to run disabling one at a time</p>
<p dir="auto">add</p>
<pre><code>disabled:true,
<p dir="auto">after the</p>
<pre><code>  module:
<p dir="auto">line<br />
and restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/102577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102577</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jul 2022 17:14:13 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 16:24:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> MMM-GoogleMapsTraffic, MMM-MyGarbage, and MMM-GooglePhotos</p>
]]></description><link>https://forum.magicmirror.builders/post/102576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102576</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Fri, 01 Jul 2022 16:24:17 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 03:00:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> looks like there may be a module eating storage</p>
<p dir="auto">what do you have installed beyond the base?</p>
]]></description><link>https://forum.magicmirror.builders/post/102571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102571</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jul 2022 03:00:33 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 01 Jul 2022 00:49:21 GMT]]></title><description><![CDATA[<p dir="auto">Well nuts, I thought I was good but it’s black screen again:</p>
<pre><code>0|MagicMir |
0|MagicMir | &lt;--- Last few GCs ---&gt;
0|MagicMir |
0|MagicMir | [1:0x2dd94000] 359113688 ms: Scavenge 882.9 (978.3) -&gt; 879.5 (978.5) MB, 4.7 / 0.0 ms  (average mu = 0.974, current mu = 0.583) task
0|MagicMir | [1:0x2dd94000] 359113908 ms: Scavenge 883.0 (978.5) -&gt; 879.7 (978.8) MB, 5.4 / 0.0 ms  (average mu = 0.974, current mu = 0.583) allocation failure
0|MagicMir | [1:0x2dd94000] 359114166 ms: Scavenge 883.4 (978.8) -&gt; 880.0 (986.8) MB, 16.4 / 0.1 ms  (average mu = 0.974, current mu = 0.583) allocation failure
0|MagicMir |
0|MagicMir |
0|MagicMir | &lt;--- JS stacktrace ---&gt;
0|MagicMir |
]]></description><link>https://forum.magicmirror.builders/post/102568</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102568</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Fri, 01 Jul 2022 00:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Mon, 27 Jun 2022 14:27:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> the backup folder has a specific name  which u can override with parameters to the scripts</p>
]]></description><link>https://forum.magicmirror.builders/post/102482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102482</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Jun 2022 14:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Mon, 27 Jun 2022 13:15:57 GMT]]></title><description><![CDATA[<p dir="auto">The backup didn’t restore my custom.css, mmpm, or some of the configuration files for 2 of my plugins but luckily I had those backed up elsewhere. I’m back up and running again though and so far so good! I’ll post back with logs if I get black screens again. Thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/102480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102480</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Mon, 27 Jun 2022 13:15:57 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sun, 26 Jun 2022 16:16:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> said in <a href="/post/102450">ERROR:node_controller.cc(585)] Trying to re-add dropped peer</a>:</p>
<p dir="auto">is there an easy way to back-up/restore my current config</p>
<p dir="auto">I have a backup/restore tool that will save the config, css and the location of all the installed modules (github links)<br />
and tghen on restore downloads and re-installs the modules from the links</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/102466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102466</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jun 2022 16:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sun, 26 Jun 2022 16:15:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I tried to update the error in the first message with the first line. I posted as new reply in case someone is searching for that.</p>
<p dir="auto">I just found your scripts here so I’m going to try this today, thanks!<br />
]]></description><link>https://forum.magicmirror.builders/post/102465</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102465</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Sun, 26 Jun 2022 16:15:12 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sun, 26 Jun 2022 16:11:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> when is that from?</p>
<p dir="auto">did u do manual install or my script?</p>
<p dir="auto">have seen that error before.</p>
]]></description><link>https://forum.magicmirror.builders/post/102464</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102464</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jun 2022 16:11:30 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sun, 26 Jun 2022 16:03:43 GMT]]></title><description><![CDATA[<pre><code>/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
[1:0x24003c4000] 207008094 ms: Mark-sweep (reduce) 475.8 (523.7) -&gt; 475.7 (523.7) MB, 1993.6 / 3.9 ms  (average mu = 0.920, current mu = 0.050) last resort GC in old space requested
[1:0x24003c4000] 207010245 ms: Mark-sweep (reduce) 475.7 (523.7) -&gt; 475.6 (523.2) MB, 2150.4 / 6.2 ms  (average mu = 0.846, current mu = 0.000) last resort GC in old space requested
[38327:0626/104544.125499:ERROR:node_controller.cc(585)] Trying to re-add dropped peer 46DBA04CA2320621.3742B9BD63F3CD94
]]></description><link>https://forum.magicmirror.builders/post/102463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102463</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Sun, 26 Jun 2022 16:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sat, 25 Jun 2022 03:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> is there an easy way to back-up/restore my current config? I don’t think there’s a way to switch to 32 bit without reinstalling the OS is there?</p>
]]></description><link>https://forum.magicmirror.builders/post/102450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102450</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Sat, 25 Jun 2022 03:59:22 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sat, 25 Jun 2022 02:59:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> ah, 64 bit version, aarch64</p>
<p dir="auto">please fall back to the 32 bit version, armv7l</p>
<p dir="auto">lots of untested things on aarch64</p>
]]></description><link>https://forum.magicmirror.builders/post/102448</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102448</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Jun 2022 02:59:48 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Sat, 25 Jun 2022 02:56:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Raspberry Pi 4 Model B Rev 1.2, 4GB</p>
<pre><code>pi@smartmirror:~ $ node --version
v16.15.1
pi@smartmirror:~ $ npm --version
8.11.0
pi@smartmirror:~ $ uname -a
Linux smartmirror 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
]]></description><link>https://forum.magicmirror.builders/post/102447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102447</guid><dc:creator><![CDATA[travishardiman]]></dc:creator><pubDate>Sat, 25 Jun 2022 02:56:33 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:node_controller.cc(585)] Trying to re-add dropped peer on Fri, 24 Jun 2022 11:27:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/travishardiman" aria-label="Profile: travishardiman">@<bdi>travishardiman</bdi></a> this is an electron error. I don’t see it fixed.</p>
<p dir="auto">can u tell me more about your environment.</p>
<p dir="auto">what pi, node --version,npm --version</p>
]]></description><link>https://forum.magicmirror.builders/post/102439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102439</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Jun 2022 11:27:30 GMT</pubDate></item></channel></rss>
