<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update fail]]></title><description><![CDATA[<p dir="auto">please Help.</p>
<p dir="auto">I just run the update tot V.2.20<br />
but now the mirror is brokken</p>
<pre><code>pi@raspberrypi:~ $ pm2 logs mm
[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
/home/pi/.pm2/logs/mm-out.log last 15 lines:
4|mm       | [03.07.2022 22:23.06.022] [LOG]   Starting MagicMirror: v2.20.0
4|mm       | [03.07.2022 22:23.06.033] [LOG]   Loading config ...
4|mm       | [03.07.2022 22:23.06.043] [LOG]   Loading module helpers ...
4|mm       | [03.07.2022 22:23.06.048] [LOG]   No helper found for module: alert.
4|mm       | [03.07.2022 22:23.06.067] [LOG]   Initializing new module helper ...
4|mm       | [03.07.2022 22:23.06.070] [LOG]   Module helper loaded: updatenotification
4|mm       | [03.07.2022 22:23.06.160] [LOG]   Initializing new module helper ...
4|mm       | [03.07.2022 22:23.06.161] [LOG]   Module helper loaded: MMM-Spotify
4|mm       | [03.07.2022 22:23.06.168] [LOG]   Loading module helpers ...
4|mm       | [03.07.2022 22:23.06.169] [LOG]   No helper found for module: alert.
4|mm       | [03.07.2022 22:23.06.170] [LOG]   Initializing new module helper ...
4|mm       | [03.07.2022 22:23.06.171] [LOG]   Module helper loaded: updatenotification
4|mm       | [03.07.2022 22:23.06.172] [LOG]   Initializing new module helper ...
4|mm       | [03.07.2022 22:23.06.173] [LOG]   Module helper loaded: MMM-Spotify
4|mm       | [03.07.2022 22:23.06.483] [LOG]   Launching application.
/home/pi/.pm2/logs/mm-error.log last 15 lines:
4|mm       |     '/home/pi/MagicMirror/js/electron.js',
4|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
4|mm       |     undefined
4|mm       |   ]
4|mm       | }
4|mm       | [03.07.2022 22:23.06.186] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
4|mm       | [03.07.2022 22:23.06.187] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
4|mm       | MESA-LOADER: failed to retrieve device information
4|mm       | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
4|mm       | failed to load driver: kms_swrast
4|mm       | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
4|mm       | failed to load swrast driver
4|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
<p dir="auto">What’s going wrong???</p>
]]></description><link>https://forum.magicmirror.builders/topic/16946/update-fail</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 14:15:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16946.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Jul 2022 20:29:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update fail on Sun, 10 Jul 2022 11:55:50 GMT]]></title><description><![CDATA[<p dir="auto">after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1">https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/102773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102773</guid><dc:creator><![CDATA[torte22]]></dc:creator><pubDate>Sun, 10 Jul 2022 11:55:50 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 20:02:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Yes see the custom.css above</p>
]]></description><link>https://forum.magicmirror.builders/post/102700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102700</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 20:02:02 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 17:03:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102695">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> I just copy the config.js.sample</p>
<p dir="auto">but language/locale codes are public</p>
<p dir="auto"><a href="https://www.science.co.il/language/Locale-codes.php" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.science.co.il/language/Locale-codes.php</a></p>
<p dir="auto">yes “nl-nl” that’s a check</p>
]]></description><link>https://forum.magicmirror.builders/post/102696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102696</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 17:03:24 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 16:58:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> I just copy the config.js.sample</p>
]]></description><link>https://forum.magicmirror.builders/post/102695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102695</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 16:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 16:47:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102692">Update fail</a>:<br />
in your script (new mirror setup)<br />
makes the scrip a new config.js.<br />
In that files stands</p>
<pre><code>locale: "en-US",
<p dir="auto">Where can I find the info for Netherland???</p>
]]></description><link>https://forum.magicmirror.builders/post/102694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102694</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 16:47:45 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 16:42:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102692">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> I don’t know for sure, did u have a custom.css that moved the position?</p>
<pre><code>MMM-RTSPStream .innerWrapper {
    border-style: none;
.MMM-SystemStats table {
        width: 350px;
        color: #666;
        font-size: 20px;
.MMM-SystemStats td {
    line-height: 20px;
.MMM-clock table {
        width: 450px;
        color: #666;
        font-size: 20px;
.MMM-MercedesMe #mercedesMain {
        zoom: 0.4;
.MMM-Formula1 .module-header {
display:none !important;
.MMM-MercedesMe .module-header {
.MMM-NetworkScanner .module-header {
.MMM-VolvoOnCall .module-header {
.MMM-Spotify .SPOTIFY_BACKGROUND {
border-style: none;
 zoom: 80%;
.MMM-MyVolvo .VOC .graphic {
        width: 50%;
        margin-right: 1px;
        margin-left: 10px;
        margin-top:  -4px;
        float: right;
<p dir="auto">Yes but not for the RTSP-stream</p>
]]></description><link>https://forum.magicmirror.builders/post/102693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102693</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 16:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 16:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> I don’t know for sure, did u have a custom.css that moved the position?</p>
]]></description><link>https://forum.magicmirror.builders/post/102692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102692</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 16:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 15:26:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in<br />
That’s oke now. Ctrl- on keyboard to zoom out</p>
<p dir="auto">But look the camera postion.<br />
Normal it was lower<br />
<img src="/assets/uploads/files/1657121084904-unknown.jpeg" alt="Unknown.jpeg" class=" img-fluid img-markdown" /></p>
<pre><code>{
		module: "MMM-RTSPStream",
		disabled: false, //false, true
		position: "upper_third",  // "middle_center" "upper_third"
			autoStart: true,
			rotateStreams: false,
			rotateStreamTimeout: 20,
			moduleWidth: 720,
			moduleHeight: 420,
			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
			remotePlayer: 'none',
			showSnapWhenPaused: false,
			remoteSnaps: false,
			  stream1: {***************
<p dir="auto">I put in the upper_third… But when I put in the middel_center i’ts at the bottom.</p>
<p dir="auto">So how can I lower the 4 camera feeds???</p>
<p dir="auto">Than the mirror is 100% back again.</p>
<p dir="auto">Thanks for the help so fare</p>
]]></description><link>https://forum.magicmirror.builders/post/102690</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102690</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 15:26:49 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 15:15:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> Ctrl- on keyboard to zoom out</p>
]]></description><link>https://forum.magicmirror.builders/post/102689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102689</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 15:15:23 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 15:09:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102685">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> add the word<br />
force<br />
to the end of the<br />
curl…<br />
statement</p>
<p dir="auto">just like the example using apply</p>
<p dir="auto">Yes Yes Yes that is the trick…<br />
Now al modules are working.</p>
<p dir="auto">Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.</p>
]]></description><link>https://forum.magicmirror.builders/post/102688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102688</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 15:09:36 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 11:24:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> add the word<br />
force<br />
curl…<br />
statement</p>
]]></description><link>https://forum.magicmirror.builders/post/102685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102685</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 11:24:55 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 11:01:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a></p>
<p dir="auto">so where must I force it</p>
]]></description><link>https://forum.magicmirror.builders/post/102684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102684</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 11:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 11:01:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
checking for modules with removed libraries</p>
<pre><code> require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
	  bypass installing request for module MMM-SystemStats , doing test run
 require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
	  bypass installing request for module MMM-MercedesMe , doing test run
<p dir="auto">processing dependency changes for active modules with package.json files</p>
]]></description><link>https://forum.magicmirror.builders/post/102683</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102683</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 11:01:28 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 10:58:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> also for upgrade you have to add</p>
<pre><code>apply
<p dir="auto">to actually DO  the upgrade</p>
<p dir="auto">and if u already did the upgrade, but want to redo, then you have to add</p>
<pre><code>force
]]></description><link>https://forum.magicmirror.builders/post/102682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102682</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 10:58:35 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 10:52:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> the ‘fix’ is to install the request library in EACH module that uses it</p>
]]></description><link>https://forum.magicmirror.builders/post/102681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102681</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jul 2022 10:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 10:44:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a></p>
<pre><code>bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
<p dir="auto">So this one is working. But the problem is still the same…</p>
]]></description><link>https://forum.magicmirror.builders/post/102680</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102680</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 10:44:52 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 10:36:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a> said in <a href="/post/102678">Update fail</a>:</p>
<p dir="auto">bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)”</p>
<p dir="auto">bash -c “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)”<br />
is not working</p>
]]></description><link>https://forum.magicmirror.builders/post/102679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102679</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 10:36:48 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 09:31:02 GMT]]></title><description><![CDATA[<p dir="auto">this great scripts from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> work :<br />
bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)” apply</p>
<p dir="auto">Thanks alot <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/102678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102678</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Wed, 06 Jul 2022 09:31:02 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Wed, 06 Jul 2022 05:56:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102667">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> the two modules failing are because of the black screen issue.</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
/home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
/home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
/home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
/home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
<p dir="auto">SO MMM-screencast is working and MMM-Spotify is working.</p>
]]></description><link>https://forum.magicmirror.builders/post/102677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102677</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 06 Jul 2022 05:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Tue, 05 Jul 2022 21:00:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> the two modules failing are because of the black screen issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/102667</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102667</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Jul 2022 21:00:01 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Tue, 05 Jul 2022 20:12:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102658">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> black screen see</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">if you had run the upgrade script from the old version, then I would have fixed these for you</p>
<p dir="auto">So that was not the fix.<br />
I’ts not the black screen that makes the problemen. It.s hangingang on the electron… I think</p>
]]></description><link>https://forum.magicmirror.builders/post/102666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102666</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Tue, 05 Jul 2022 20:12:22 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Tue, 05 Jul 2022 12:38:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> black screen see</p>
]]></description><link>https://forum.magicmirror.builders/post/102658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102658</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Jul 2022 12:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Tue, 05 Jul 2022 12:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/102637">Update fail</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> and try my script?</p>
<p dir="auto">Yesterday I have made a new install whit your script.<br />
After that i’ts was running fine (Standard module)</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a> (That was good)</p>
<p dir="auto">When I’m trying to put my own module back whit al git clone and install I run in to trouble.</p>
<ul>
<li>
<p dir="auto"><a href="https://github.com/skuethe/MMM-Spotify" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/skuethe/MMM-Spotify</a> (check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/mazim-co/MMM-MyVolvo" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mazim-co/MMM-MyVolvo</a> (Check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/ianperrin/MMM-NetworkScanner" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ianperrin/MMM-NetworkScanner</a> (Check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/darickc/MMM-BackgroundSlideshow" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/darickc/MMM-BackgroundSlideshow</a> (Check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/shbatm/MMM-RTSPStream" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/shbatm/MMM-RTSPStream</a> (Check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/ianperrin/MMM-Formula1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ianperrin/MMM-Formula1</a> (Check)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/BenRoe/MMM-SystemStats" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/BenRoe/MMM-SystemStats</a> (Trouble black screen)</p>
</li>
<li>
<p dir="auto"><a href="https://github.com/ashishtank/MMM-MercedesMe" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ashishtank/MMM-MercedesMe</a> (Trouble black screen)</p>
</li>
</ul>
<pre><code>		{
			module: "MMM-MercedesMe",
			position: "bottom_right",
				client_id: '************',
				client_secret: '************',
				vehicleType: 'Electric',
				vehicleId: 'WDD**************',
				displayStyle: 'singledial',  //# twodial &amp; singledial
				//updateInterval: 300000, // 10 Minutes,
				maxRange: 175,
				debug: false,
				logsInFile: false,
		module: 'MMM-SystemStats',
		position: 'top_center',
			updateInterval: 10000, // every 10 seconds
			align: 'right', // align labels
			units: 'metric', // default, metric, imperial
			view: 'textAndIcon',
<p dir="auto">And the total mirror is look like i’ts zoom-in for 20% or something.</p>
<p dir="auto">So that’s the status for now. Its running on 75% hahahah (Smile)</p>
]]></description><link>https://forum.magicmirror.builders/post/102656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102656</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Tue, 05 Jul 2022 12:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to Update fail on Mon, 04 Jul 2022 14:59:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
No Not yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/102638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102638</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Mon, 04 Jul 2022 14:59:14 GMT</pubDate></item></channel></rss>
