<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Errors with newest update]]></title><description><![CDATA[<p dir="auto">Would anyone be so kind to explain what I’ve done here?</p>
<p dir="auto">pi@raspberrypi:~ $ cd ~/MagicMirror<br />
pi@raspberrypi:~/MagicMirror $ git status<br />
On branch master<br />
Your branch is up to date with ‘origin/master’.</p>
<p dir="auto">Changes not staged for commit:<br />
(use “git add …” to update what will be committed)<br />
(use “git restore …” to discard changes in working directory)<br />
modified:   installers/mm.sh<br />
modified:   modules/default/clock/clock.js</p>
<p dir="auto">Untracked files:<br />
(use “git add …” to include in what will be committed)<br />
0<br />
Cron/<br />
core<br />
installers/pm2_MagicMirror.json<br />
<a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/16960/errors-with-newest-update</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 06:50:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16960.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jul 2022 16:22:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Errors with newest update on Fri, 15 Jul 2022 12:18:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> u may have changed clock.js, that’s ours</p>
<p dir="auto">you could</p>
<p dir="auto">figure out what changes were made</p>
<p dir="auto">git diff,</p>
<p dir="auto">then git stash to save the changes, git pull<br />
then npm install</p>
<p dir="auto">or run my upgrade script which will help do all that and advise you…</p>
]]></description><link>https://forum.magicmirror.builders/post/102720</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102720</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 15 Jul 2022 12:18:17 GMT</pubDate></item><item><title><![CDATA[Reply to Errors with newest update on Fri, 08 Jul 2022 17:30:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you Sam</p>
]]></description><link>https://forum.magicmirror.builders/post/102728</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102728</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Fri, 08 Jul 2022 17:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to Errors with newest update on Fri, 15 Jul 2022 12:18:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> u may have changed clock.js, that’s ours</p>
]]></description><link>https://forum.magicmirror.builders/post/102720</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102720</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 15 Jul 2022 12:18:17 GMT</pubDate></item></channel></rss>
