<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry Pi display not autostarting magic mirror]]></title><description><![CDATA[<p dir="auto">My Raspberry Pi isn’t autostarting Magic Mirror with the 7 inch display connected. It autostarts correctly when connected to a monitor however. Is there something in the pm2 script that I have to do?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17010/raspberry-pi-display-not-autostarting-magic-mirror</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 20:16:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17010.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jul 2022 12:51:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 16:36:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ephraimb" aria-label="Profile: EphraimB">@<bdi>EphraimB</bdi></a> I got it to work now. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/103002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103002</guid><dc:creator><![CDATA[EphraimB]]></dc:creator><pubDate>Fri, 22 Jul 2022 16:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 17:53:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ephraimb" aria-label="Profile: EphraimB">@<bdi>EphraimB</bdi></a> what did u change?</p>
]]></description><link>https://forum.magicmirror.builders/post/103005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103005</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 Jul 2022 17:53:06 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 16:36:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ephraimb" aria-label="Profile: EphraimB">@<bdi>EphraimB</bdi></a> I got it to work now. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/103002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103002</guid><dc:creator><![CDATA[EphraimB]]></dc:creator><pubDate>Fri, 22 Jul 2022 16:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 13:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ephraimb" aria-label="Profile: EphraimB">@<bdi>EphraimB</bdi></a> <a href="https://youtu.be/7VVcJsOaJJc" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/7VVcJsOaJJc</a></p>
]]></description><link>https://forum.magicmirror.builders/post/102997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102997</guid><dc:creator><![CDATA[EphraimB]]></dc:creator><pubDate>Fri, 22 Jul 2022 13:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 13:10:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>/home/ephraimb/.pm2/logs/mm-error.log last 15 lines:
0|mm       | [8401:0722/083808.387458:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|mm       | [8449:0722/083808.554707:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
0|mm       | [8410:0722/083808.663954:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
0|mm       | /home/ephraimb/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
0|mm       | [8816:0722/083948.777454:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|mm       | [8860:0722/083948.944901:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
0|mm       | [8825:0722/083949.008201:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
0|mm       | [9539:0722/084423.587492:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|mm       | [9583:0722/084423.754159:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
0|mm       | [9546:0722/084423.836816:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
0|mm       | [1692:0722/090756.740898:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|mm       | [1734:0722/090757.250763:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
^C
ephraimb@raspberrypi:~ $ echo $DISPLAY
]]></description><link>https://forum.magicmirror.builders/post/102996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102996</guid><dc:creator><![CDATA[EphraimB]]></dc:creator><pubDate>Fri, 22 Jul 2022 13:10:49 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi display not autostarting magic mirror on Fri, 22 Jul 2022 13:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ephraimb" aria-label="Profile: EphraimB">@<bdi>EphraimB</bdi></a> when the 7 in is used  open a terminal session ctrl-alt-t</p>
<p dir="auto">and do</p>
<p dir="auto">echo $DISPLAY</p>
<p dir="auto">the line in package.json used for npm start, checks for DISPLAY set in the env, and if not uses :0</p>
<p dir="auto">this is needed by x-windows</p>
<p dir="auto">you might need to add</p>
<pre><code>export DISPLAY=:?
<p dir="auto">to the installers/mm.sh, before the npm start line</p>
<p dir="auto">where ? is the display number used for the 7in</p>
]]></description><link>https://forum.magicmirror.builders/post/102995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102995</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 Jul 2022 13:00:44 GMT</pubDate></item></channel></rss>
