<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WARNING! Could not load config file.]]></title><description><![CDATA[<p dir="auto">Getting these error messages for any weather module i try to use. This one happens to be Weather-Now. The error messages states that it cannot find the “request” module. I when to the Weather-Now directory and issued “npm install request” thinking a dependency is missing however the module is there. Any thoughts (see below)?</p>
<p dir="auto">Thx</p>
<p dir="auto">[24.07.2022 11:07.00.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/simdo01/MagicMirror/modules/MMM-Weather-Now/node_helper.js</li>
<li>/home/simdo01/MagicMirror/js/app.js</li>
<li>/home/simdo01/MagicMirror/js/electron.js</li>
<li>/home/simdo01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/17015/warning-could-not-load-config-file</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 02:36:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17015.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Jul 2022 16:14:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WARNING! Could not load config file. on Sun, 24 Jul 2022 23:16:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thx much!</p>
]]></description><link>https://forum.magicmirror.builders/post/103040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103040</guid><dc:creator><![CDATA[tacotaco]]></dc:creator><pubDate>Sun, 24 Jul 2022 23:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to WARNING! Could not load config file. on Sun, 24 Jul 2022 16:36:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tacotaco" aria-label="Profile: tacotaco">@<bdi>tacotaco</bdi></a> see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/103030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103030</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Jul 2022 16:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to WARNING! Could not load config file. on Sun, 24 Jul 2022 16:29:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tacotaco" aria-label="Profile: tacotaco">@<bdi>tacotaco</bdi></a> re-installed the module completely and it works. Ah the software Gods!</p>
]]></description><link>https://forum.magicmirror.builders/post/103029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103029</guid><dc:creator><![CDATA[tacotaco]]></dc:creator><pubDate>Sun, 24 Jul 2022 16:29:41 GMT</pubDate></item></channel></rss>
