<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Generating token for MMM-GooglePhotos]]></title><description><![CDATA[<p dir="auto">when generating the token for google photos in local pi terminal, the Chromium browser opens and  i go through the verification and consent to access and then the browser attempts to access “localhost” with what I am assuming will be the auth code and fails with “Site can’t be reached” localhost refused to connect. Am i missing something? Please advise.</p>
<p dir="auto">thx much</p>
]]></description><link>https://forum.magicmirror.builders/topic/17021/generating-token-for-mmm-googlephotos</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 22:15:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17021.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jul 2022 23:03:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Generating token for MMM-GooglePhotos on Tue, 26 Jul 2022 15:36:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks again. also auth_and_test.js and auth.js were missing in theMMM-GooglePhotos directory. Deleted node_modules and ran npm install again but no luck. i downloaded them to the directory. auth.js was referencing the old opn module since renamed to open. Changed to open and ran auth_and_test with the proper results. Kinda messy.</p>
]]></description><link>https://forum.magicmirror.builders/post/103074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103074</guid><dc:creator><![CDATA[tacotaco]]></dc:creator><pubDate>Tue, 26 Jul 2022 15:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to Generating token for MMM-GooglePhotos on Tue, 26 Jul 2022 19:35:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tacotaco" aria-label="Profile: tacotaco">@<bdi>tacotaco</bdi></a> thanks much for you assistance!!</p>
]]></description><link>https://forum.magicmirror.builders/post/103080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103080</guid><dc:creator><![CDATA[tacotaco]]></dc:creator><pubDate>Tue, 26 Jul 2022 19:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to Generating token for MMM-GooglePhotos on Tue, 26 Jul 2022 15:46:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tacotaco" aria-label="Profile: tacotaco">@<bdi>tacotaco</bdi></a> not my module. never run test…</p>
]]></description><link>https://forum.magicmirror.builders/post/103075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103075</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 26 Jul 2022 15:46:48 GMT</pubDate></item><item><title><![CDATA[Reply to Generating token for MMM-GooglePhotos on Tue, 26 Jul 2022 15:36:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks again. also auth_and_test.js and auth.js were missing in theMMM-GooglePhotos directory. Deleted node_modules and ran npm install again but no luck. i downloaded them to the directory. auth.js was referencing the old opn module since renamed to open. Changed to open and ran auth_and_test with the proper results. Kinda messy.</p>
]]></description><link>https://forum.magicmirror.builders/post/103074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103074</guid><dc:creator><![CDATA[tacotaco]]></dc:creator><pubDate>Tue, 26 Jul 2022 15:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to Generating token for MMM-GooglePhotos on Tue, 26 Jul 2022 01:59:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tacotaco" aria-label="Profile: tacotaco">@<bdi>tacotaco</bdi></a> step 11, a code will appear 4/…</p>
<p dir="auto">I see this in the url , code=<br />
<img src="/assets/uploads/files/1658800732950-screenshot_2022-07-25_20-57-27.png" alt="Screenshot_2022-07-25_20-57-27.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/103061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103061</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 26 Jul 2022 01:59:15 GMT</pubDate></item></channel></rss>
