<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Eye Candy Reinstall - Config Doesn&#x27;t Work]]></title><description><![CDATA[<p dir="auto">Uninstalled Eye Candy as described at MM site, then reinstalled as directed at MM site. Here are the two config files as edited:</p>
<p dir="auto"><strong>In directory: home/pi/MagicMirror/modules/MMM-EyeCandy</strong></p>
<p dir="auto">/* Magic Mirror</p>
<ul>
<li>Module: MMM-EyeCandy</li>
<li></li>
<li>By Mykle1</li>
<li>MIT Licensed.<br />
*/<br />
Module.register(“MMM-EyeCandy”, {<br />
// Default module config.<br />
defaults: {<br />
style: ‘1’, // 1-52<br />
maxWidth: “100%”, // Adjusts size of images. Retains aspect ratio.<br />
ownImagePath: ‘<a href="https://radar.weather.gov/ridge/lite/KCLE_loop.gif" target="_blank" rel="noopener noreferrer nofollow ugc">https://radar.weather.gov/ridge/lite/KCLE_loop.gif</a>’<br />
updateInterval: 5 * 60 * 1000, // set in config.js<br />
animationSpeed: 3000,<br />
},</li>
</ul>
<p dir="auto"><strong>In directory: home/pi/MagicMirror/config</strong><br />
{<br />
module: “MMM-EyeCandy”,<br />
position: “top_right”,<br />
config: {<br />
maxWidth: “75%”,       // Sizes the images. Retains aspect ratio.<br />
style: ‘1’,            ‘<a href="https://radar.weather.gov/ridge/lite/KCLE_loop.gif" target="_blank" rel="noopener noreferrer nofollow ugc">https://radar.weather.gov/ridge/lite/KCLE_loop.gif</a>’<br />
ownImagePath: ‘’,      ‘<a href="https://radar.weather.gov/ridge/lite/KCLE_loop.gif" target="_blank" rel="noopener noreferrer nofollow ugc">https://radar.weather.gov/ridge/lite/KCLE_loop.gif</a>’<br />
}<br />
},</p>
<p dir="auto">I’ve looked and tweeked trying to figure out why I can’t boot because the MM says there is no config file, but can’t.  Appreciate any guidance. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17056/eye-candy-reinstall-config-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 20:30:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17056.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Aug 2022 15:03:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Sun, 07 Aug 2022 16:32:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for the assistance. I was able to clean up the config file with what you provide and MM boots. However, I’ll need to figure out why the weather radar gif didn’t populate onscreen. Perhaps more posts are coming, but is config file question is now solved. Thank you for your time, expertise and help!</p>
]]></description><link>https://forum.magicmirror.builders/post/103387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103387</guid><dc:creator><![CDATA[MMNewby]]></dc:creator><pubDate>Sun, 07 Aug 2022 16:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Mon, 08 Aug 2022 09:35:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a> Strange. I get the Radar image to show.</p>
<p dir="auto"><img src="/assets/uploads/files/1659951305744-71bf93b0-7403-41b6-a42b-cdc34c9ddcb9-image.png" alt="71bf93b0-7403-41b6-a42b-cdc34c9ddcb9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/103407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103407</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 08 Aug 2022 09:35:10 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Sun, 07 Aug 2022 16:32:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for the assistance. I was able to clean up the config file with what you provide and MM boots. However, I’ll need to figure out why the weather radar gif didn’t populate onscreen. Perhaps more posts are coming, but is config file question is now solved. Thank you for your time, expertise and help!</p>
]]></description><link>https://forum.magicmirror.builders/post/103387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103387</guid><dc:creator><![CDATA[MMNewby]]></dc:creator><pubDate>Sun, 07 Aug 2022 16:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Fri, 05 Aug 2022 19:40:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Eye Candy doesn’t have a node_helper so no modules to install.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a>  However, the config entry was incorrect.  Below is the correct config.</p>
<pre><code class="language-{">module: "MMM-EyeCandy",
maxWidth: "75%", // Sizes the images. Retains aspect ratio.
style: '1',
ownImagePath: 'https://radar.weather.gov/ridge/lite/KCLE_loop.gif'
},````</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/103329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103329</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Fri, 05 Aug 2022 19:40:10 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Fri, 05 Aug 2022 15:56:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a> as I said before  show us the rest of the messages.</p>
<p dir="auto">I suspect this<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/103318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 15:56:42 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Fri, 05 Aug 2022 14:29:30 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the suggestion. I changed the quotes in both files, save and started MM. What I continue to get the a black screen that says Magic Mirror2  Please create a config file. See README for more information. If you get this message while your config file is already created, your config file probably contains an error. Use a JavaScript linter to validate your file.</p>
<p dir="auto">When I use // before the command lines (the lines turn red), and restart, the MM operates normally with the other modules working, but the upper right where Eye Candy is assigned is blank. It’s only when the command lines are “live” for Eye Candy (i.e. the URL for the gif) that the black screen error shows up. Thanks again for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/103317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103317</guid><dc:creator><![CDATA[MMNewby]]></dc:creator><pubDate>Fri, 05 Aug 2022 14:29:30 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Fri, 05 Aug 2022 01:27:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> I believe you’re correct. <a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a> From now on, use a editor such as geany so that correct quotes won’t be an issue, unless you copy and paste from bad source.</p>
]]></description><link>https://forum.magicmirror.builders/post/103315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103315</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Fri, 05 Aug 2022 01:27:18 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Thu, 04 Aug 2022 16:38:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a> Looks like the quotes need to be replaced with the correct ones. When copy and paste from the web the quotes change. Just delete the quotes and add new ones.</p>
]]></description><link>https://forum.magicmirror.builders/post/103297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103297</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 04 Aug 2022 16:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Eye Candy Reinstall - Config Doesn&#x27;t Work on Thu, 04 Aug 2022 15:58:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a> show the error messages</p>
<p dir="auto">maybe a missing library?</p>
]]></description><link>https://forum.magicmirror.builders/post/103291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103291</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 04 Aug 2022 15:58:36 GMT</pubDate></item></channel></rss>
