<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 and MagicMirror stopped]]></title><description><![CDATA[<p dir="auto">I don’t think I did anything to cause it but all of a sudden when I do pm2 start MagicMirror it says that pm2 has started MagicMirror but that is as far as it gets.   The panel says status is online and memory using 2.6mb but the mirror never starts. I’ve rebooted, I’ve shutdown and started from scratch and nothing seems to help…  I tried to do a search on not starting but must not have asked the right question.<br />
Anyone ever have this problem?<br />
Dennis</p>
]]></description><link>https://forum.magicmirror.builders/topic/17061/pm2-and-magicmirror-stopped</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 11:23:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17061.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Aug 2022 22:33:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Sat, 06 Aug 2022 00:17:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> you had to do the grep exactly Iike it I typed it, else it will return nothing…</p>
]]></description><link>https://forum.magicmirror.builders/post/103363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103363</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Aug 2022 00:17:24 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Sat, 06 Aug 2022 00:08:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  When I did the grep "electron":package.json it just sat and looked back at me for 5 minutes. So I canceled it and just did the npm install electron@19.0.0  and it installed just fine.  Then I did npm start and it started the MagigMirror properly.   So I’m guessing Iost  the electron somehow. but I stopped MagicMirror and started it again with pm2 start MagicMirror and it worked fine…<br />
Thank you Sam… I thought I had you there for a moment… I should have known better…<br />
Dennis :)<br />
I see the \ mark got dropped from my message after the word electron but it was there when I typed it .</p>
]]></description><link>https://forum.magicmirror.builders/post/103362</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103362</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Sat, 06 Aug 2022 00:08:00 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:41:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> fun</p>
<p dir="auto">do</p>
<pre><code>cd ~/MagicMirror
grep \"electron\": package.json
<p dir="auto">it will display line like</p>
<pre><code>	"electron": "^19.0.6"
<p dir="auto">then do</p>
<pre><code>npm install electron@19.0.6
<p dir="auto">whatever the number is</p>
<p dir="auto">then test with npm start again</p>
]]></description><link>https://forum.magicmirror.builders/post/103361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103361</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:35:48 GMT]]></title><description><![CDATA[<p dir="auto">/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.20.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">/tmp/start-adaafac7.sh: 1: /tmp/start-adaafac7.sh: ./node_modules/.bin/electron: not found<br />
pi@raspberrypi:~/MagicMirror $</p>
]]></description><link>https://forum.magicmirror.builders/post/103360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103360</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:21:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> no, you pasted that you did npm stop all, which is not valid</p>
<p dir="auto">pm2<br />
is not the same as<br />
npm</p>
]]></description><link>https://forum.magicmirror.builders/post/103359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103359</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:21:45 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:19:31 GMT]]></title><description><![CDATA[<p dir="auto">That is what I got when i did a pm2 stop all.</p>
]]></description><link>https://forum.magicmirror.builders/post/103358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103358</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:19:31 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:11:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> pm2 stop all</p>
]]></description><link>https://forum.magicmirror.builders/post/103357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103357</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:11:37 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 23:01:46 GMT]]></title><description><![CDATA[<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm stop all<br />
npm ERR! Missing script: “stop”<br />
npm ERR!<br />
npm ERR! To see a list of scripts, run:<br />
npm ERR!   npm run</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/pi/.npm/_logs/2022-08-05T23_00_11_817Z-debug-0.log<br />
]]></description><link>https://forum.magicmirror.builders/post/103354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103354</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Fri, 05 Aug 2022 23:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 22:57:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> also, do</p>
<p dir="auto">pm2 stop all</p>
<p dir="auto">then</p>
<p dir="auto">cd ~/MagicMirror<br />
npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/103352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103352</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 22:57:24 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 and MagicMirror stopped on Fri, 05 Aug 2022 22:54:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> show the messages</p>
<p dir="auto">pm2 logs --lines=50</p>
]]></description><link>https://forum.magicmirror.builders/post/103351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103351</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Aug 2022 22:54:30 GMT</pubDate></item></channel></rss>
