<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM and Shelly relay integration request - switch TV Off]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am the “lucky” owner of a tv which shows ugly “no signal” when hdmi goes “sleep mode”.</p>
<p dir="auto">I was wondering if anyone has managed to control a shelly relay to fully turn on/off the tv, when e.g. motion is detected on webcam.</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-SleepWake" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-SleepWake</a><br />
<a href="https://shelly.cloud/products/shelly-1-smart-home-automation-relay/" target="_blank" rel="noopener noreferrer nofollow ugc">https://shelly.cloud/products/shelly-1-smart-home-automation-relay/</a></p>
<p dir="auto">many thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/17091/mm-and-shelly-relay-integration-request-switch-tv-off</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 23:19:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17091.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Aug 2022 23:48:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM and Shelly relay integration request - switch TV Off on Fri, 12 Aug 2022 15:27:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes I’m aware 😊 I tried that first but system won’t allow after certain time apparently. I got an error message.</p>
<p dir="auto">Thanks for the suggestion and the continuos support in this forum!</p>
]]></description><link>https://forum.magicmirror.builders/post/103532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103532</guid><dc:creator><![CDATA[sforza]]></dc:creator><pubDate>Fri, 12 Aug 2022 15:27:46 GMT</pubDate></item><item><title><![CDATA[Reply to MM and Shelly relay integration request - switch TV Off on Fri, 12 Aug 2022 11:27:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sforza" aria-label="Profile: sforza">@<bdi>sforza</bdi></a> u can edit posts.</p>
]]></description><link>https://forum.magicmirror.builders/post/103525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103525</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 11:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to MM and Shelly relay integration request - switch TV Off on Fri, 12 Aug 2022 09:29:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sforza" aria-label="Profile: sforza">@<bdi>sforza</bdi></a> said in <a href="/post/103521">MM and Shelly relay integration request - switch TV Off</a>:</p>
<p dir="auto">Not sure if the relays in the smart plugs would share same API methods.</p>
<p dir="auto">if the relays <em>and</em> the smart plugs - typo</p>
]]></description><link>https://forum.magicmirror.builders/post/103522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103522</guid><dc:creator><![CDATA[sforza]]></dc:creator><pubDate>Fri, 12 Aug 2022 09:29:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM and Shelly relay integration request - switch TV Off on Fri, 12 Aug 2022 07:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I don’t own any shelly relay at the moment. Just trying to explore options to plan my actual mirror build 😊.</p>
<p dir="auto">Your link seems to be going in the right direction. Not sure if the relays in the smart plugs would share same API methods. Will consider buying one and trying.</p>
<p dir="auto">Thanks a lot!</p>
]]></description><link>https://forum.magicmirror.builders/post/103521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103521</guid><dc:creator><![CDATA[sforza]]></dc:creator><pubDate>Fri, 12 Aug 2022 07:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to MM and Shelly relay integration request - switch TV Off on Fri, 12 Aug 2022 01:20:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sforza" aria-label="Profile: sforza">@<bdi>sforza</bdi></a> does this script work from the terminal window?</p>
<p dir="auto"><a href="https://forums.raspberrypi.com/viewtopic.php?t=331355" target="_blank" rel="noopener noreferrer nofollow ugc">https://forums.raspberrypi.com/viewtopic.php?t=331355</a></p>
]]></description><link>https://forum.magicmirror.builders/post/103517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103517</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 01:20:49 GMT</pubDate></item></channel></rss>
