<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NPM run start cannot be used]]></title><description><![CDATA[<p dir="auto">After the third-party module is installed, NPM Run Server is normal, but NPM Run Start cannot be used</p>
]]></description><link>https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 22:19:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17093.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Aug 2022 14:21:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 15:36:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> Thank you very much. I will try it, but I need to start it in a few days because of me. Thank you for your guidance</p>
]]></description><link>https://forum.magicmirror.builders/post/103697</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103697</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 15:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 15:31:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry, I am not convenient for debugging today. Please allow me to come back to you for consultation in a few days</p>
]]></description><link>https://forum.magicmirror.builders/post/103696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103696</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 15:31:42 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 10:19:17 GMT]]></title><description><![CDATA[<p dir="auto">It seems like  electron and node.js version  issue.<br />
As far as I know, recent MM is depending  on newer node and electron, but during update, your electron and node’s version is not matched properly.<br />
I recommend you to reinstall your nodejs and electron cleanly.</p>
]]></description><link>https://forum.magicmirror.builders/post/103686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103686</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 15 Aug 2022 10:19:17 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:56:26 GMT]]></title><description><![CDATA[<p dir="auto">I am going to sleep now,sorry, long day.</p>
]]></description><link>https://forum.magicmirror.builders/post/103678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103678</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:56:26 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:51:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> on the pi keyboard, right?</p>
<p dir="auto">all keys at once<br />
with MagicMirror on the screen</p>
]]></description><link>https://forum.magicmirror.builders/post/103677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103677</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:47:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I pressed ctrl-shift-i, but the raspberry pie didn’t respond</p>
]]></description><link>https://forum.magicmirror.builders/post/103676</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103676</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:41:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> I just told you how</p>
]]></description><link>https://forum.magicmirror.builders/post/103675</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103675</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:41:05 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:40:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I don’t know how to open the developer window.</p>
]]></description><link>https://forum.magicmirror.builders/post/103674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103674</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:34:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> open the developers window.</p>
<p dir="auto">ctrl-shift-i on the keyboard<br />
select the console tab and enter weath<br />
in the filter field</p>
]]></description><link>https://forum.magicmirror.builders/post/103673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103673</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:34:59 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:30:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It is possible to use NPM run server<img src="/assets/uploads/files/1660534152960-2.png" alt="2.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1660534230253-1.png" alt="1.png" class=" img-fluid img-markdown" /> Using NPM run start will:</p>
]]></description><link>https://forum.magicmirror.builders/post/103672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103672</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:30:33 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 03:04:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a><br />
just the weather config</p>
<p dir="auto">ok, this module is stupid… requires parms, but then doesn’t use them…</p>
<pre><code>		{
			module: "weather",
			header: "Weather Forecast",
				updateInterval: 15*1000,
				initialLoadDelay: 2,
				weatherProvider: "weatherbit",
				weatherEndpoint:"/forecast/daily",
				type: "forecast",
				lat: 30.4548443,
				lon: -97.6222674,
				apiKey: "67f41759a9c74d8a917ac984155286f0",
<p dir="auto">also, forecast has a long old bug , make sure to set<br />
initialLoadDelay: 2,<br />
and a short interval for testing<br />
updateInterval: 15*1000,</p>
<p dir="auto">you can use this apikey… I will kill it in an hour or so…</p>
<p dir="auto">I opened this issue<br />
<a href="https://github.com/MichMich/MagicMirror/issues/2899" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/2899</a></p>
<p dir="auto">type: current (default) worked on with my apikey</p>
]]></description><link>https://forum.magicmirror.builders/post/103671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103671</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 03:04:06 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 02:24:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>		{
			module: "weather",
				weatherProvider:"weatherbit",
				type: "current",
				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				apiKey: "???"
			module: "weather",
				type: "forecast",
				apiKey: "???"
]]></description><link>https://forum.magicmirror.builders/post/103670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103670</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 02:24:33 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:59:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> ‘loading’ is the default message, until some data arrives.</p>
<p dir="auto">can u show me what you did</p>
]]></description><link>https://forum.magicmirror.builders/post/103669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103669</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I tried it just now, but it didn’t work. It will always show that it is loading</p>
]]></description><link>https://forum.magicmirror.builders/post/103668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103668</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:39:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> there are two options current weather and forecast</p>
<p dir="auto">the new module eliminates having to use a lot of parms…</p>
<p dir="auto">just try it my way, for a test</p>
]]></description><link>https://forum.magicmirror.builders/post/103667</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103667</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:36:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Different weather configurations should be configured in different ways。<a href="https://docs.magicmirror.builders/modules/weather.html#configuration-options" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/weather.html#configuration-options</a><br />
The way I learned from here</p>
]]></description><link>https://forum.magicmirror.builders/post/103666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103666</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:33:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> either, both, whatever</p>
<p dir="auto">just trying to get it to work</p>
]]></description><link>https://forum.magicmirror.builders/post/103665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103665</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:33:52 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:28:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1660526837277-1.png" alt="1.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1660526837173-2.png" alt="2.png" class=" img-fluid img-markdown" /><br />
The first or the second?</p>
]]></description><link>https://forum.magicmirror.builders/post/103664</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103664</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:28:05 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> no. in the weather config…  that is the issue we are working on</p>
<p dir="auto">make it look like mine, use your apikey<br />
and your provider<br />
<a href="https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873">https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873</a></p>
]]></description><link>https://forum.magicmirror.builders/post/103663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103663</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:11:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1660525894325-2.png" alt="2.png" class=" img-fluid img-markdown" /><br />
Is that so?</p>
]]></description><link>https://forum.magicmirror.builders/post/103661</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103661</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:11:51 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 01:07:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> remove the weatherEndpoint<br />
add</p>
<pre><code>type:'current'
]]></description><link>https://forum.magicmirror.builders/post/103660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103660</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Aug 2022 01:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Mon, 15 Aug 2022 00:58:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Good evening. I just woke up</p>
<pre><code>/* MagicMirror² Config Sample
* By Michael Teeuw https://michaelteeuw.nl
* MIT Licensed.
* see https://docs.magicmirror.builders/configuration/introduction.html
* and https://docs.magicmirror.builders/modules/configuration.html
let config = {
   address: "localhost", 	// Address to listen on, can be:
   port: 8080,
   basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
   ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
   language: "zh-cn",
   locale: "zh",
   timeFormat: 24,
   units: "metric",
   		module: "alert",
   		module: "updatenotification",
   		position: "top_bar"
   		module: "clock",
   		position: "top_left"
   		header: "US Holidays",
   					symbol: "calendar-check",
   					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
   //		module: "compliments",
   //		position: "lower_third"
   	module: "weather",
   		weatherEndpoint:"/current/forecast/daily",
   		apiKey:"aa03f670e4944ac3a086f92482a5e25e",
   		lat:"40.5",
   		lon:"116.5",
   		showSun:"true",
   		colored:"true",
   		maxNumberOfDays:"5"
   	/*  显示图片
   			module: "MMM-ImagesPhotos",
   			position: "middle_center",
   				opacity: 0.5,
   				animationSpeed: 1000,
   				updateInterval: 5000,
   				maxWidth:"500px",
   				maxHeight:"200px",
   				backgroundColor: 'grey',  // not used if fill is true
   				fill: false,   // fill around image with blurred copy of image
   				blur: 10,   // only used if fill is true
   	module: "helloworld",
   	position: "bottom_bar",	// This can be any of the regions.
   		text: "Hi! May I help you?"
	module: 'MMM-SimpleText',
	position: 'bottom_right',
   		fontURL: {
   		  'value': 'Tahoma, Geneva, sans-serif'
   		fontSize: {
   		  'value': 'small'
   		fontStyle: {
   		  'value': 'italic'
   		color: {
   		  'value': '#FFFFFF'
   		refreshMs: {
   		  'value': '10000'
   		filePath: {
   		  'value': '123.txt'
]]></description><link>https://forum.magicmirror.builders/post/103659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103659</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Mon, 15 Aug 2022 00:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Sun, 14 Aug 2022 16:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E5%8F%B2%E6%96%B0%E7%91%9E" aria-label="Profile: 史新瑞">@<bdi>史新瑞</bdi></a> no opinion of you.   just working on problems.    many new users come and we work thru things…</p>
<p dir="auto">see u later</p>
]]></description><link>https://forum.magicmirror.builders/post/103647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103647</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Aug 2022 16:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to NPM run start cannot be used on Sun, 14 Aug 2022 16:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I mean only the weather API, that is, the key of your openweather. I will come back to you for advice in nine hours, that is, around 8:00 p.m. us time. I hope you have time, and I hope you don’t hate me. Thank you again. I wish you good health and good luck. I’ll be with you all the time</p>
]]></description><link>https://forum.magicmirror.builders/post/103646</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103646</guid><dc:creator><![CDATA[史新瑞]]></dc:creator><pubDate>Sun, 14 Aug 2022 16:48:21 GMT</pubDate></item></channel></rss>
