<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black Screen after installing fonts-noto-color-emoji]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/14337/emoji-support">🎂🥂Emoji support</a></p>
<p dir="auto">I tried <code>sudo apt install fonts-noto-color-emoji</code> and it installed fine. After the reboot I now just get a black screen.</p>
<p dir="auto">I then tried <code>npm run config:check</code> and I got this message:</p>
<pre><code>npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path /home/pi/package.json
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR!     /home/pi/.npm/_logs/2022-08-12T16_15_05_667Z-debug.log
<p dir="auto">Here is the error log file:</p>
<pre><code>0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
1 info using npm@7.21.0
2 info using node@v10.23.2
3 timing npm:load:whichnode Completed in 2ms
4 timing config:load:defaults Completed in 10ms
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 16ms
6 timing config:load:builtin Completed in 18ms
7 timing config:load:cli Completed in 12ms
8 timing config:load:env Completed in 3ms
9 timing config:load:project Completed in 7ms
10 timing config:load:file:/home/pi/.npmrc Completed in 3ms
11 timing config:load:user Completed in 4ms
12 timing config:load:file:/usr/etc/npmrc Completed in 1ms
13 timing config:load:global Completed in 2ms
14 timing config:load:validate Completed in 2ms
15 timing config:load:credentials Completed in 6ms
16 timing config:load:setEnvs Completed in 5ms
17 timing config:load Completed in 70ms
18 timing npm:load:configload Completed in 72ms
19 timing npm:load:setTitle Completed in 1ms
20 timing npm:load:setupLog Completed in 5ms
21 timing config:load:flatten Completed in 23ms
22 timing npm:load:cleanupLog Completed in 20ms
23 timing npm:load:configScope Completed in 0ms
24 timing npm:load:projectScope Completed in 1ms
25 timing npm:load Completed in 141ms
26 timing command:run-script Completed in 41ms
27 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
28 verbose cwd /home/pi
29 verbose Linux 5.4.83-v7+
30 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
31 verbose node v10.23.2
32 verbose npm  v7.21.0
33 error code ENOENT
34 error syscall open
35 error path /home/pi/package.json
36 error errno -2
37 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
38 error enoent This is related to npm not being able to find a file.
39 verbose exit -2
<p dir="auto">It appears I am missing the file package.json, but I don’t know what that is or how to make/get the file.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17094/black-screen-after-installing-fonts-noto-color-emoji</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:17:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17094.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Aug 2022 16:23:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:51:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am so sorry. I don’t know how I missed this from one installation to another but feel truly ashamed. What happened is that I used a copy of config.js that I thought was the one working from previous install. But it was missing the classes clause to show the modules.</p>
<p dir="auto">Again, so sorry and super grateful for putting me on the right track :)</p>
]]></description><link>https://forum.magicmirror.builders/post/105327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105327</guid><dc:creator><![CDATA[arosenhave]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:51:05 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 12:32:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arosenhave" aria-label="Profile: arosenhave">@<bdi>arosenhave</bdi></a> glad u found it!</p>
]]></description><link>https://forum.magicmirror.builders/post/105328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105328</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Oct 2022 12:32:27 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:51:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am so sorry. I don’t know how I missed this from one installation to another but feel truly ashamed. What happened is that I used a copy of config.js that I thought was the one working from previous install. But it was missing the classes clause to show the modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/105327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105327</guid><dc:creator><![CDATA[arosenhave]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:51:05 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:45:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arosenhave" aria-label="Profile: arosenhave">@<bdi>arosenhave</bdi></a> I would need to see the output of the npm start.</p>
<p dir="auto">black screen is usually a module crash or missing dependencies</p>
]]></description><link>https://forum.magicmirror.builders/post/105324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105324</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:45:58 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arosenhave" aria-label="Profile: arosenhave">@<bdi>arosenhave</bdi></a> yes, reco hides everything til u identify thru the camera yourself</p>
<p dir="auto">then it shows the modules marked as visible for your profile/module classes config</p>
]]></description><link>https://forum.magicmirror.builders/post/105323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105323</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:44:31 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:35:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This made no difference, I’m afraid :(<br />
<img src="/assets/uploads/files/1666092795221-mm.png" alt="mm.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The strange thing is that for a split second I can see the other modules loading and displaying and then it all goes black. Like the MMM-Face-Reco-DNN somehow loads in front of everything. If I remove this module from config.js everything displays fine. I have checked the config.js for syntax errors and it reports nothing.</p>
]]></description><link>https://forum.magicmirror.builders/post/105322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105322</guid><dc:creator><![CDATA[arosenhave]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:35:25 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:23:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arosenhave" aria-label="Profile: arosenhave">@<bdi>arosenhave</bdi></a> if u want to upgrade, use my script<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">and backup</p>
<p dir="auto">see  <a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105319</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:23:32 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:21:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arosenhave" aria-label="Profile: arosenhave">@<bdi>arosenhave</bdi></a> depends on which video driver is enabled in /boot/config.txt</p>
<p dir="auto">edit the script which starts MM<br />
and add</p>
<p dir="auto">export ELECTRON_DISABLE_GPU=1</p>
<p dir="auto">before the<br />
npm start<br />
line</p>
]]></description><link>https://forum.magicmirror.builders/post/105318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:21:33 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Tue, 18 Oct 2022 11:15:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> any luck resolving this issue?<br />
I have a fresh install of MM on an RPI4 (Rasbian OS 32bit) and get the same problem when installing MMM-Face-Reco-DNN. Only errors I have in the logs are the same GPU related ones.</p>
<p dir="auto">And the strange thing is that I have the exact same setup on a different SD card done 6 weeks ago. And that works perfectly. It reporst my MM is outdated, but I don’t dare updating it now.</p>
]]></description><link>https://forum.magicmirror.builders/post/105317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105317</guid><dc:creator><![CDATA[arosenhave]]></dc:creator><pubDate>Tue, 18 Oct 2022 11:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Mon, 15 Aug 2022 12:54:01 GMT]]></title><description><![CDATA[<p dir="auto">Ok I am going to try a new install on my raspberry pi 4, instead of the 3B I have been using.</p>
]]></description><link>https://forum.magicmirror.builders/post/103693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103693</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Mon, 15 Aug 2022 12:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 20:00:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> I do not know</p>
]]></description><link>https://forum.magicmirror.builders/post/103595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103595</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Aug 2022 20:00:16 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 19:58:28 GMT]]></title><description><![CDATA[<p dir="auto">I think it’s a GPU issue. Could it have been a bad install of the os? Should I reinstall?</p>
]]></description><link>https://forum.magicmirror.builders/post/103594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103594</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Sat, 13 Aug 2022 19:58:28 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 12:54:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am running the 32 bit raspi os. I used the official raspberry pi imager to create it.</p>
]]></description><link>https://forum.magicmirror.builders/post/103572</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103572</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Sat, 13 Aug 2022 12:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 11:34:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> are you running the 64 bit raspi os?</p>
<p dir="auto">this is a configuration problem when using the Vulcan video driver.</p>
]]></description><link>https://forum.magicmirror.builders/post/103569</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103569</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Aug 2022 11:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 03:54:08 GMT]]></title><description><![CDATA[<p dir="auto">I have been getting the following error mm-error.log:</p>
<pre><code>
[12.08.2022 22:50.16.819] [WARN]  [33mYou're using a full whitelist configuration to allow for all IPs[39m
[1707:0812/225020.891765:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1749:0812/225021.867756:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1768:0812/225022.360451:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
[12.08.2022 23:24.59.722] [WARN]  [33mYou're using a full whitelist configuration to allow for all IPs[39m
[1686:0812/232504.792579:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1735:0812/232505.286195:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[12.08.2022 23:46.19.653] [WARN]  [33mYou're using a full whitelist configuration to allow for all IPs[39m
[1623:0812/234649.995261:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1766:0812/234650.598873:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
]]></description><link>https://forum.magicmirror.builders/post/103559</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103559</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Sat, 13 Aug 2022 03:54:08 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 03:30:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I think when I tried to install mmpm that it didn’t install correctly. I did it again and everything seems fine except I still have a black screen. But somehow in the web using the ip address it loads fine. Why would I get a black screen on the pi but everything working on the web? I even made a change to make sure it wasn’t cached and the change showed up so it’s new.</p>
]]></description><link>https://forum.magicmirror.builders/post/103558</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103558</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Sat, 13 Aug 2022 03:30:44 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 01:39:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> yep</p>
<p dir="auto">the link I gave u had the instructions in the 1st post</p>
<p dir="auto">find the message, get the name, install it in the module folder</p>
<p dir="auto">there are more than one library file missing. depends on the module…  so I have to teach you the process.</p>
<p dir="auto"><img src="/assets/uploads/files/1660354623493-screenshot_20220812-203617_chrome.jpg" alt="Screenshot_20220812-203617_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/103557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103557</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Aug 2022 01:39:49 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Sat, 13 Aug 2022 01:03:12 GMT]]></title><description><![CDATA[<p dir="auto">I did a clean install of mm, added my modules, copied the saved config from the previous install to the new install. Everything looked fine, then I rebooted and now I again have a black screen!!!</p>
<p dir="auto">The npm log says:</p>
<pre><code> verbose cli /usr/bin/node /usr/bin/npm
1 info using npm@8.11.0
2 info using node@v16.16.0
4 timing config:load:defaults Completed in 12ms
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 7ms
6 timing config:load:builtin Completed in 9ms
7 timing config:load:cli Completed in 9ms
9 timing config:load:file:/home/pi/MagicMirror/.npmrc Completed in 0ms
10 timing config:load:project Completed in 26ms
11 timing config:load:file:/home/pi/.npmrc Completed in 0ms
12 timing config:load:user Completed in 3ms
13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
14 timing config:load:global Completed in 2ms
15 timing config:load:validate Completed in 2ms
16 timing config:load:credentials Completed in 19ms
17 timing config:load:setEnvs Completed in 7ms
18 timing config:load Completed in 96ms
19 timing npm:load:configload Completed in 97ms
20 timing npm:load:mkdirpcache Completed in 5ms
21 timing npm:load:mkdirplogs Completed in 5ms
22 verbose title npm start
23 verbose argv "start"
24 timing npm:load:setTitle Completed in 6ms
25 timing config:load:flatten Completed in 18ms
26 timing npm:load:display Completed in 23ms
27 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs
28 verbose logfile /home/pi/.npm/_logs/2022-08-13T00_05_23_038Z-debug-0.log
29 timing npm:load:logFile Completed in 36ms
30 timing npm:load:timers Completed in 1ms
31 timing npm:load:configScope Completed in 1ms
32 timing npm:load Completed in 182ms
33 silly logfile start cleaning logs, removing 1 files
34 silly logfile done cleaning log files
<p dir="auto">The pm2 error log says:</p>
<pre><code>[8711:0812/191224.893179:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[8764:0812/191225.738183:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[8716:0812/191225.822559:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[1644:0812/194324.158131:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1694:0812/194325.043000:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1718:0812/194325.555134:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[1672:0812/194325.644795:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[12.08.2022 19:54.36.872] [ERROR] [31mWARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'[39m
[31mRequire stack:[39m
[31m- /home/pi/MagicMirror/modules/MMM-Tools/node_helper.js[39m
[31m- /home/pi/MagicMirror/js/app.js[39m
[31m- /home/pi/MagicMirror/js/electron.js[39m
[31m- /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js[39m
[31m- [39m
[12.08.2022 19:54.36.913] [ERROR] App threw an error during load
[12.08.2022 19:54.36.926] [ERROR] Error: Cannot find module 'async'
Require stack:
    at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
    at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (node:internal/modules/cjs/loader:785:27)
    at c._load (node:electron/js2c/asar_bundle:5:13343)
    at Module.require (node:internal/modules/cjs/loader:1012:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:6:13)
    at Module._compile (node:internal/modules/cjs/loader:1118:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
[12.08.2022 19:54.36.929] [ERROR] Whoops! There was an uncaught exception...
[12.08.2022 19:54.36.978] [ERROR] Error: Cannot find module 'async'
Require stack:
    at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js',
    '/home/pi/MagicMirror/js/app.js',
    '/home/pi/MagicMirror/js/electron.js',
    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[12.08.2022 19:54.36.981] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[12.08.2022 19:54.36.982] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[1635:0812/195502.091221:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1743:0812/195503.364570:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1769:0812/195503.879521:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[12.08.2022 20:06.05.090] [WARN]  [33mYou're using a full whitelist configuration to allow for all IPs[39m
[1676:0812/200609.075206:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1730:0812/200610.010984:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1749:0812/200610.493257:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
]]></description><link>https://forum.magicmirror.builders/post/103556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103556</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Sat, 13 Aug 2022 01:03:12 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 20:43:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> after upgrading, you have to reinstall mm<br />
and maybe any modules</p>
<p dir="auto">still black screen maybe this<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">show is the messages at mm start</p>
<p dir="auto">if using pm2 then</p>
<p dir="auto">pm2 --lines=50</p>
]]></description><link>https://forum.magicmirror.builders/post/103548</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103548</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 20:43:49 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 20:00:41 GMT]]></title><description><![CDATA[<p dir="auto">I have updated npm and node (in MagicMirror directory). I still have a black screen (I have done a reboot). When I run the config check I get a message saying there is no errors.</p>
<pre><code>
&gt; magicmirror@2.20.0 config:check
&gt; node js/check_config.js
[12.08.2022 15:58.52.189] [INFO]  Checking file...  /home/pi/MagicMirror/config/                                       config.js
[12.08.2022 15:58.52.486] [INFO]  Your configuration file doesn't contain syntax                                        errors :)
]]></description><link>https://forum.magicmirror.builders/post/103547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103547</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Fri, 12 Aug 2022 20:00:41 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 19:02:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> said in <a href="/post/103540">Black Screen after installing fonts-noto-color-emoji</a>:</p>
<p dir="auto">Didn’t realize the path mattered</p>
<p dir="auto">mm is just an app installed on the system</p>
]]></description><link>https://forum.magicmirror.builders/post/103546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103546</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 19:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 18:58:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> see</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/issues/2772" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/2772</a></p>
<p dir="auto">you need to upgrade node and npm to minimum levels</p>
<p dir="auto">use my install script next time</p>
]]></description><link>https://forum.magicmirror.builders/post/103545</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103545</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 18:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 18:17:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> did you run?<br />
first switch to the MagicMirror folder like this</p>
<pre><code>cd /home/pi/MagicMirror/
<p dir="auto">then run this command</p>
<pre><code>npm run config:check
]]></description><link>https://forum.magicmirror.builders/post/103543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103543</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Fri, 12 Aug 2022 18:17:25 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 18:02:07 GMT]]></title><description><![CDATA[<p dir="auto">Didn’t realize the path mattered.</p>
<pre><code>&gt; magicmirror@2.20.0 config:check
/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383
const require$1 = Module.createRequire(require('url').pathToFileURL(__filename).toString());
TypeError: Module.createRequire is not a function
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383:26)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
<p dir="auto">I don’t understand this.</p>
]]></description><link>https://forum.magicmirror.builders/post/103540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103540</guid><dc:creator><![CDATA[aunrea]]></dc:creator><pubDate>Fri, 12 Aug 2022 18:02:07 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after installing fonts-noto-color-emoji on Fri, 12 Aug 2022 17:49:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aunrea" aria-label="Profile: aunrea">@<bdi>aunrea</bdi></a> you are in the wrong folder</p>
<pre><code>cd ~/MagicMirror
]]></description><link>https://forum.magicmirror.builders/post/103538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103538</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Aug 2022 17:49:30 GMT</pubDate></item></channel></rss>
