<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 errors]]></title><description><![CDATA[<p dir="auto">Lets try try this again… I  now see the calendar errors and can probably figure tose out but the pm2 is another story.<br />
1|mm       | /tmp/start-dcfcac42.sh: 1: /tmp/start-dcfcac42.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-1274b738.sh: 1: /tmp/start-1274b738.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-c2007b47.sh: 1: /tmp/start-c2007b47.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-32dcf27c.sh: 1: /tmp/start-32dcf27c.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-132c9b31.sh: 1: /tmp/start-132c9b31.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-11e3e2b7.sh: 1: /tmp/start-11e3e2b7.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-54d113c7.sh: 1: /tmp/start-54d113c7.sh: ./node_modules/.bin/electron: not found<br />
1|mm       | /tmp/start-8e8129ea.sh: 1: /tmp/start-8e8129ea.sh: ./node_modules/.bin/electron: not found</p>
<p dir="auto">/home/pi/.pm2/logs/MagicMirror-error.log last 30 lines:<br />
3|MagicMir | [13.08.2022 13:38.28.480] [ERROR] Calendar Error. Could not fetch calendar:  <a href="https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics</a> Error: Not Found<br />
3|MagicMir |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)<br />
3|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)<br />
3|MagicMir | [13.08.2022 13:43.28.887] [ERROR] Calendar Error. Could not fetch calendar:  <a href="https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics</a> Error: Not Found<br />
3|MagicMir | [13.08.2022 13:48.29.118] [ERROR] Calendar Error. Could not fetch calendar:  <a href="https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics</a> Error: Not Found<br />
3|MagicMir | [13.08.2022 13:53.29.385] [ERR</p>
]]></description><link>https://forum.magicmirror.builders/topic/17105/pm2-errors</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 22:00:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17105.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Aug 2022 21:48:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 23:06:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> no. not yet… too many issues</p>
]]></description><link>https://forum.magicmirror.builders/post/103658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103658</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Aug 2022 23:06:09 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 22:05:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> No 64?</p>
]]></description><link>https://forum.magicmirror.builders/post/103657</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103657</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Sun, 14 Aug 2022 22:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 20:30:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> said in <a href="/post/103650">pm2 errors</a>:</p>
<p dir="auto">What is the recommended O.S to load MM</p>
<p dir="auto">either the latest 32 bit full desktop<br />
or if using video streams with MM, then the legacy 32 bit image</p>
]]></description><link>https://forum.magicmirror.builders/post/103654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103654</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Aug 2022 20:30:23 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 20:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> said in <a href="/post/103650">pm2 errors</a>:</p>
<p dir="auto">Module.require</p>
<p dir="auto">this indicates a down level version of npm</p>
<p dir="auto">please use use my script, it does everything.<br />
start from fresh SD card flash, cause I don’t know what you’ve got now, but it’s a mess</p>
]]></description><link>https://forum.magicmirror.builders/post/103651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103651</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Aug 2022 20:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 19:22:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I did the list as you said twice… With the same results.  I think it will just be easier to start from scratch.  What is the recommended O.S to load MM on now?<br />
Here is the result after I did the pm2 reset and you listed.</p>
<p dir="auto">1|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)<br />
1|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)<br />
1|MagicMir |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)<br />
1|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26<br />
1|MagicMir | [1143:0814/120009.873359:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
1|MagicMir | [1219:0814/120011.296500:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
1|MagicMir | [1246:0814/120011.766627:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.<br />
1|MagicMir | [14.08.2022 12:00.20.655] [ERROR] Calendar Error. Could not fetch calendar:  <a href="https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics</a> Error: Not Found<br />
1|MagicMir |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)<br />
1|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)<br />
1|MagicMir | [14.08.2022 12:01.53.089] [WARN]  You’re using a full whitelist configuration to allow for all IPs<br />
1|MagicMir | [14.08.2022 12:01.55.581] [ERROR] ERROR! Could not validate main module js file.<br />
1|MagicMir | [14.08.2022 12:01.55.596] [ERROR] ReferenceError: Log is not defined<br />
1|MagicMir |     at Object. (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:151216)<br />
1|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1118:14)<br />
1|MagicMir |     at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)<br />
1|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)<br />
1|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)<br />
1|MagicMir |     at c._load (node:electron/js2c/asar_bundle:5:13343)<br />
1|MagicMir | [2074:0814/120156.172072:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
1|MagicMir | [2166:0814/120200.161965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
1|MagicMir | [2204:0814/120200.457971:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.<br />
1|MagicMir | [14.08.2022 12:02.13.913] [WARN]  You’re using a full whitelist configuration to allow for all IPs</p>
<p dir="auto">/home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:<br />
1|MagicMir | [14.08.2022 12:02.00.537] [LOG]   Shutting down server…<br />
1|MagicMir | [14.08.2022 12:02.00.552] [LOG]   Stopping module helper: MMM-Wallpaper<br />
1|MagicMir | [14.08.2022 12:02.00.559] [LOG]   Stopping module helper: MMM-3Day-Forecast</p>
]]></description><link>https://forum.magicmirror.builders/post/103650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103650</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Sun, 14 Aug 2022 19:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sun, 14 Aug 2022 01:00:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - At a guess,  something went wrong during his installation that is preventing electron from loading. But the failed calls to Google for the calendar worry me. I suspect that he has two issues: failed installation and a Google calendar configuration error that is preventing Google from serving up his calendar.</p>
<p dir="auto">You gave good advice, getting the electron issue sorted. But I think <a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> is still going to have calendar problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/103602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103602</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sun, 14 Aug 2022 01:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 errors on Sat, 13 Aug 2022 22:25:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> I have no idea what u are looking at</p>
<p dir="auto">is MagicMirror installed  in ~/MagicMirror<br />
like normal?</p>
<p dir="auto">if so,  then</p>
<p dir="auto">pm2 stop all<br />
pm2 status</p>
<p dir="auto">take the number of the entry</p>
<p dir="auto">pm2 delete xx<br />
pm2 save force</p>
<p dir="auto">xx is the number</p>
<p dir="auto">then run the fixuppm2 script from my scripts</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">last entry on the page</p>
]]></description><link>https://forum.magicmirror.builders/post/103599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103599</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Aug 2022 22:25:49 GMT</pubDate></item></channel></rss>
