<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gît clone... Npm install needed ?]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/14031/weather-graph-calendar-with-custom-mmm-forecast-io">Weather graph &amp; calendar with custom MMM-forecast-io</a></p>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/flatpepsi" aria-label="Profile: FlatPepsi">@<bdi>FlatPepsi</bdi></a>,</p>
<p dir="auto">I am interested to use your weather forecast module with chart which seems very nice.</p>
<p dir="auto">As I did not find this information, is a “git clone …” and “npm install” command needed to install the files ? before configuring the config file?</p>
<p dir="auto">Thank in advance and thank you for your interest and your job!</p>
]]></description><link>https://forum.magicmirror.builders/topic/17116/gît-clone-npm-install-needed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 17:24:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17116.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Aug 2022 17:33:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Fri, 19 Aug 2022 12:52:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> perfect, thank you and have a good week-end.</p>
]]></description><link>https://forum.magicmirror.builders/post/103745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103745</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Fri, 19 Aug 2022 12:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Sun, 21 Aug 2022 12:42:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> please read the “how to add modules” link in my signature below</p>
]]></description><link>https://forum.magicmirror.builders/post/103743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103743</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Aug 2022 12:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Fri, 19 Aug 2022 08:52:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
hello Sam, could you please tell me the complete “git clone” command to get the files on “<a href="https://github.com/FlatPepsi17/MMM-forecast-io" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/FlatPepsi17/MMM-forecast-io</a>”</p>
<p dir="auto">sorry for the inconvenience, I am quite new on this topic and I really appreciate your help.</p>
<p dir="auto">Thanks a lot.</p>
]]></description><link>https://forum.magicmirror.builders/post/103742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103742</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Fri, 19 Aug 2022 08:52:13 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Thu, 18 Aug 2022 19:01:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Fair enough. I wasn’t aware of the others. Request is the one I’ve seen by far the most missed.</p>
]]></description><link>https://forum.magicmirror.builders/post/103738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103738</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 18 Aug 2022 19:01:59 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Thu, 18 Aug 2022 19:00:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> its not just request (there are 5 libs at least )<br />
point to the solution process<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">this module doesn’t have a node_helper, and no package.json, so this can’t be an issue…</p>
]]></description><link>https://forum.magicmirror.builders/post/103737</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103737</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Aug 2022 19:00:18 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Thu, 18 Aug 2022 18:58:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a></p>
<p dir="auto">One other thing, if you get a blank screen after installing a module, check the logs, if it mentions “Request” - you have to reinstall it.</p>
<p dir="auto">see <a href="https://forum.magicmirror.builders/topic/15666/add-request-to-modules/">https://forum.magicmirror.builders/topic/15666/add-request-to-modules/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/103736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103736</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 18 Aug 2022 18:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Thu, 18 Aug 2022 17:40:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hello, and thanks a lot. I will Try! Kind regards</p>
]]></description><link>https://forum.magicmirror.builders/post/103733</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103733</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Thu, 18 Aug 2022 17:40:28 GMT</pubDate></item><item><title><![CDATA[Reply to Gît clone... Npm install needed ? on Thu, 18 Aug 2022 17:38:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a>  1st git clone,</p>
<p dir="auto">see the links below in my signature, they will help a lot…    I didn’t write them</p>
<p dir="auto">npm install</p>
<p dir="auto">if the module has a file named package.json<br />
THEN you do npm install<br />
otherwise not needed</p>
]]></description><link>https://forum.magicmirror.builders/post/103732</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103732</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Aug 2022 17:38:25 GMT</pubDate></item></channel></rss>
