<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RPI 3B keeps going to blank screen (cursor showing)]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/11052/new-script-for-screensaver-disable">new script for screensaver disable</a></p>
<p dir="auto">Hi all,<br />
I’m having a big problem with my magic mirror. It looks as though my RPI 3B keeps going into screensave. After a while I get a black screen with a white arrow cursor.<br />
I have gone through all the usual documented ways of turning off screen save ie<br />
consoleblank=0 in cmdline.txt,<br />
Screen Blanking’ option in the Raspberry Pi Configuration tool,<br />
Xscreensaver is not installed,<br />
Adding to /etc/xdg/lxsession/LXDE/autostart;-<br />
@xset s noblank<br />
@xset s off<br />
@xset -dpms,<br />
Adding to /etc/kbd/config;-<br />
BLANK_TIME=0<br />
POWERDOWN_TIME=0,<br />
Adding to ~/.bashrc;-   setterm -blank 0 -powerdown 0,<br />
Adding to  /etc/lightdm/lightdm.conf;-  xserver-command=X -s 0 -p 0 -dpms,<br />
etc etc…</p>
<p dir="auto">If I connect using VPN I still only see a black screen with cursor.</p>
<p dir="auto">Any help with this really frustrating problem would be greatly appreciated.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  - I found references to an old script of yours but could not access it to try it on my MM.</p>
<p dir="auto">Thanks</p>
<p dir="auto">BigTJ</p>
]]></description><link>https://forum.magicmirror.builders/topic/17128/rpi-3b-keeps-going-to-blank-screen-cursor-showing</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 11:17:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17128.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Aug 2022 14:26:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Fri, 30 Dec 2022 18:59:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> very cool detective work! glad you found a resolution!!</p>
]]></description><link>https://forum.magicmirror.builders/post/106768</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106768</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Dec 2022 18:59:41 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Fri, 30 Dec 2022 17:23:26 GMT]]></title><description><![CDATA[<p dir="auto">Finally resolved my black screen issue!<br />
After replacing the Pi 3B, the SD card, the OS, using the latest MM software, much internet searching and a great deal of help through this forum it appears the problem is being caused by the jpg photos being added to the wallpaper module. Changing the photos from large tif files into jpg files using Adobe lightroom creates a highly compressed jpg file that the wallpaper module cannot deal with properly.<br />
Reducing the resolution of the files during the conversion seems to create a less compressed jpg file that the Wallpaper module can deal with.<br />
Hope this helps others with the same issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/106767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106767</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Fri, 30 Dec 2022 17:23:26 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Fri, 16 Dec 2022 19:52:07 GMT]]></title><description><![CDATA[<p dir="auto">i have the same “problem” i think…New installation mirror works just fine for hours or even a day or two,then black screen with <a href="http://cursor.No" target="_blank" rel="noopener noreferrer nofollow ugc">cursor.No</a> network,so i cant restart it properly.I did disable gpu so no error massage anymore and i did the " npm init -y" thing inside every module <a href="http://folder.No" target="_blank" rel="noopener noreferrer nofollow ugc">folder.No</a> solution yet…</p>
]]></description><link>https://forum.magicmirror.builders/post/106625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106625</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Fri, 16 Dec 2022 19:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Mon, 28 Nov 2022 17:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for all your efforts and assistance. After many reloads of the OS and the MM software I still have the same issue. After searching for similar Pi problems outside of MM it appears that this can happen due to hardware failure. I am now going to purchase a new pi and start from the beginning. Will report back on success or failure in due course. Thanks to everyone that has offered help and assistance.</p>
]]></description><link>https://forum.magicmirror.builders/post/106229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106229</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Mon, 28 Nov 2022 17:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Wed, 26 Oct 2022 00:00:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> do it the same.  run-start does npm  run server</p>
<p dir="auto">but at that point, there is no electron…</p>
]]></description><link>https://forum.magicmirror.builders/post/105511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105511</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Oct 2022 00:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 25 Oct 2022 23:02:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Course, now begs the question… “What if there’s no npm start line?”</p>
<p dir="auto"><a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> is used. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/105510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105510</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 25 Oct 2022 23:02:49 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 25 Oct 2022 22:25:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I’ll give that a go in the next few days.<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/105509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105509</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Tue, 25 Oct 2022 22:25:58 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sun, 23 Oct 2022 11:34:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> no. not really. 2.18 is fairly old and we have upgraded electron in each of the last releases</p>
<p dir="auto">I would use my upgrade script, see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">it will complain about package.json as we made the  disable-gpu change</p>
<p dir="auto">so restore it first, before running the upgrade</p>
<pre><code>cd ~/MagicMirror
git checkout package.json
<p dir="auto">there is a new way to disable gpu use without editing that package.json  file</p>
<p dir="auto">edit the ~/MagicMirror/installers/mm.sh</p>
<p dir="auto">and add</p>
<pre><code>export ELECTRON_DISABLE_GPU
<p dir="auto">before the npm start line</p>
]]></description><link>https://forum.magicmirror.builders/post/105422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105422</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Oct 2022 11:34:27 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sun, 23 Oct 2022 10:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi,<br />
Did you have any further thoughts on this problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/105420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105420</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sun, 23 Oct 2022 10:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 11 Oct 2022 10:48:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the response</p>
<p dir="auto">I amended the package.json as follows;-</p>
<p dir="auto">“start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron --disable-gpu js/electron.js”,<br />
“start:dev”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron --disable-gpu js/electron.js”,</p>
<p dir="auto">Is this correct?</p>
<p dir="auto">Yes the mouse still works. Cursor is a black arrow with a white outline. No it does wake up.<br />
Control M works<br />
Control R Works<br />
Control Q works</p>
<p dir="auto">The start up report of the  mirror with minimal content shows;-</p>
<p dir="auto">magicmirror@2.18.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron --disable-gpu js/electron.js “run”</p>
<p dir="auto">[11.10.2022 11:45.29.988] [LOG]   Starting MagicMirror: v2.18.0<br />
[11.10.2022 11:45.30.003] [LOG]   Loading config …<br />
[11.10.2022 11:45.30.030] [LOG]   Loading module helpers …<br />
[11.10.2022 11:45.31.926] [LOG]   Initializing new module helper …<br />
[11.10.2022 11:45.31.930] [LOG]   Module helper loaded: MMM-Wallpaper<br />
[11.10.2022 11:45.31.935] [LOG]   No helper found for module: weather.<br />
[11.10.2022 11:45.31.936] [LOG]   All module helpers loaded.<br />
[11.10.2022 11:45.32.214] [LOG]   Starting server on port 8080 …<br />
[11.10.2022 11:45.32.258] [LOG]   Server started …<br />
[11.10.2022 11:45.32.261] [LOG]   Connecting socket for: MMM-Wallpaper<br />
[11.10.2022 11:45.32.268] [LOG]   Starting node helper for: MMM-Wallpaper<br />
[11.10.2022 11:45.32.270] [LOG]   Sockets connected &amp; modules started …<br />
[11.10.2022 11:45.32.942] [LOG]   Launching application.<br />
[6000:1011/114533.695740:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.</p>
<p dir="auto">Any further ideas?</p>
<p dir="auto">Thanks for your continued assistance</p>
]]></description><link>https://forum.magicmirror.builders/post/105115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105115</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Tue, 11 Oct 2022 10:48:05 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sun, 02 Oct 2022 16:42:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> if u did --disable-gpu, then u shouldnt be getting those messages</p>
<p dir="auto">u can use all the default modules multiple times</p>
<p dir="auto">when the screen goes black, does the mouse work?  does it wake up?</p>
]]></description><link>https://forum.magicmirror.builders/post/104861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104861</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Oct 2022 16:42:59 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sun, 02 Oct 2022 15:50:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi, I have changed the line as your suggestion.<br />
The mirror screen is still going blank after a short random period of time.</p>
<p dir="auto">I have installed the ‘example’ mirror as per your suggestion to a previous query. The mirror works OK and (appears) not to go to black screen. Currently I am commenting out each module in config.js to try to identify if it is a particular module that is causing the problem.</p>
<p dir="auto">My original set up uses the Calendar module twice (for 2 different  users). Is this a possible cause of the problem? ie do I need to have independent modules one per user?</p>
<p dir="auto">The following lines occur each time I start the mirror. Could this be relevant to my problem?</p>
<p dir="auto">“[24055:0824/184036.476041:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization<br />
[24096:0824/184036.932766:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.”</p>
]]></description><link>https://forum.magicmirror.builders/post/104856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104856</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sun, 02 Oct 2022 15:50:50 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 06 Sep 2022 12:29:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the suggestion.</p>
<p dir="auto">I’ll give it a go and let you know if it is successful.</p>
]]></description><link>https://forum.magicmirror.builders/post/104237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104237</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Tue, 06 Sep 2022 12:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 06 Sep 2022 11:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> said in <a href="/post/103920">RPI 3B keeps going to blank screen (cursor showing)</a>:</p>
<p dir="auto">4067:0824/230903.755884:ERROR:broker_posix.cc(46)] Received unexpected number of handles</p>
<p dir="auto">this is the error</p>
<p dir="auto">we don’t really know the cause.<br />
u can try disabling the use of gpu</p>
<p dir="auto">change package.json line to look like this</p>
<pre><code>		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable-gpu js/electron.js",
]]></description><link>https://forum.magicmirror.builders/post/104235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104235</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 06 Sep 2022 11:44:31 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 06 Sep 2022 10:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi,<br />
Were the displayed messages of any help in narrowing down the issue?</p>
<p dir="auto">BigTj</p>
]]></description><link>https://forum.magicmirror.builders/post/104233</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104233</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Tue, 06 Sep 2022 10:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sat, 27 Aug 2022 19:53:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a></p>
<p dir="auto">I have another MM running on a Pi 4B that uses all the same modules without a problem.</p>
<p dir="auto">But I will  give your suggestion a try.  Thanks for the tip</p>
<p dir="auto">Big TJ</p>
]]></description><link>https://forum.magicmirror.builders/post/103929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103929</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sat, 27 Aug 2022 19:53:05 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sat, 27 Aug 2022 19:19:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a></p>
<p dir="auto">I asked because I had problems with some modules which needed to much memory which results also in a black screen with white cursor.</p>
<p dir="auto">You could try to run without the 3 foreign modules to see if the problem persists.</p>
]]></description><link>https://forum.magicmirror.builders/post/103928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103928</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 27 Aug 2022 19:19:02 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sat, 27 Aug 2022 09:59:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a>  The modules of the MM are listed below in shortened form.  Thanks for your interest.</p>
<p dir="auto">“alert”<br />
“updatenotification”<br />
“MMM-Wallpaper”<br />
“clock”<br />
“calendar_monthly”<br />
“calendar”<br />
header: “Steve’s Upcoming Items”<br />
“MMM-GoogleSheets”<br />
“calendar”<br />
— header: “Angela’s Upcoming Items”<br />
“weather”<br />
— position: “top_left”<br />
— header: "Currently: "<br />
— location: “Doncaster”<br />
“weather”,<br />
— header: “Forecast”<br />
“weather”,<br />
— location: “Pickering”<br />
‘MMM-WiFiPassword’<br />
“newsfeed”</p>
]]></description><link>https://forum.magicmirror.builders/post/103921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103921</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sat, 27 Aug 2022 09:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Sat, 27 Aug 2022 09:54:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi, the messages of note from starting MM are as below</p>
<p dir="auto">setterm: terminal xterm-256color does not support --blank<br />
pi@raspberrypi:~ $ cd MagicMirror<br />
pi@raspberrypi:~/MagicMirror $ npm start run</p>
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”</p>
<p dir="auto">[24.08.2022 18:40.30.154] [LOG]   Starting MagicMirror: v2.18.0<br />
[24.08.2022 18:40.30.166] [LOG]   Loading config …<br />
[24.08.2022 18:40.30.198] [LOG]   Loading module helpers …<br />
[24.08.2022 18:40.30.206] [LOG]   No helper found for module: alert.<br />
[24.08.2022 18:40.31.907] [LOG]   Initializing new module helper …<br />
[24.08.2022 18:40.31.911] [LOG]   Module helper loaded: MMM-Wallpaper<br />
[24.08.2022 18:40.31.917] [LOG]   No helper found for module: clock.<br />
[24.08.2022 18:40.31.922] [LOG]   No helper found for module: calendar_monthly.<br />
[24.08.2022 18:40.32.330] [LOG]   Initializing new module helper …<br />
[24.08.2022 18:40.32.332] [LOG]   Module helper loaded: calendar<br />
[24.08.2022 18:40.32.336] [LOG]   No helper found for module: weather.<br />
[24.08.2022 18:40.32.341] [LOG]   No helper found for module: MMM-WiFiPassword.<br />
[24.08.2022 18:40.32.421] [LOG]   Initializing new module helper …<br />
[24.08.2022 18:40.32.422] [LOG]   Module helper loaded: newsfeed<br />
[24.08.2022 18:40.32.425] [LOG]   All module helpers loaded.<br />
[24.08.2022 18:40.32.697] [LOG]   Starting server on port 8080 …<br />
[24.08.2022 18:40.32.740] [LOG]   Server started …<br />
[24.08.2022 18:40.32.743] [LOG]   Connecting socket for: MMM-Wallpaper<br />
[24.08.2022 18:40.32.745] [LOG]   Starting node helper for: MMM-Wallpaper<br />
[24.08.2022 18:40.32.746] [LOG]   Connecting socket for: calendar<br />
[24.08.2022 18:40.32.748] [LOG]   Starting node helper for: calendar<br />
[24.08.2022 18:40.32.749] [LOG]   Connecting socket for: newsfeed<br />
[24.08.2022 18:40.32.750] [LOG]   Starting node helper for: newsfeed<br />
[24.08.2022 18:40.32.751] [LOG]   Sockets connected &amp; modules started …<br />
[24.08.2022 18:40.33.378] [LOG]   Launching application.<br />
[24096:0824/184036.932766:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.<br />
[24.08.2022 18:40.40.506] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics</a> - Interval: 3000000<br />
[24.08.2022 18:40.40.693] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics</a> - Interval: 3000000<br />
[24.08.2022 18:40.40.703] [LOG]   Create new newsfetcher for url: <a href="http://feeds.bbci.co.uk/news/uk/rss.xml" target="_blank" rel="noopener noreferrer nofollow ugc">http://feeds.bbci.co.uk/news/uk/rss.xml</a> - Interval: 300000</p>
<p dir="auto">[24.08.2022 23:05.55.239] [INFO]  Newsfeed-Fetcher: Broadcasting 38 items.<br />
[24067:0824/230903.755884:ERROR:broker_posix.cc(46)] Received unexpected number of handles<br />
[24.08.2022 23:10.55.583] [INFO]  Newsfeed-Fetcher: Broadcasting 38 items.</p>
<p dir="auto">I don’t know exactly when the black screen occurred.<br />
Hope this helps</p>
<p dir="auto">Thanks BigTJ</p>
]]></description><link>https://forum.magicmirror.builders/post/103920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103920</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sat, 27 Aug 2022 09:54:45 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Wed, 24 Aug 2022 18:06:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a></p>
<p dir="auto">which modules have you installed?</p>
]]></description><link>https://forum.magicmirror.builders/post/103876</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103876</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 24 Aug 2022 18:06:22 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Wed, 24 Aug 2022 11:36:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> show the messages from where u start MagicMirror at the time of the failure</p>
]]></description><link>https://forum.magicmirror.builders/post/103870</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103870</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 24 Aug 2022 11:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Wed, 24 Aug 2022 09:47:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Unfortunately I am still getting the black screen with mouse cursor.</p>
<p dir="auto">I’ve installed a new OS from scratch and Installed a clean version of MM, installed the modules from scratch but the problem persists.</p>
<p dir="auto">When the MM has gone to black screen I cannot use CtrlM to minimise the MM window but I can use CtrlR to force a re-read and this brings the MM back on. Any ideas what can be causing this?</p>
]]></description><link>https://forum.magicmirror.builders/post/103866</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103866</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Wed, 24 Aug 2022 09:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 23 Aug 2022 13:48:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks for your help.</p>
<p dir="auto">This has been a problem for a long time. The mirror is being used headless so having to restart over and over again has spoilt the usefulness of the mirror. Hopefully that is all sorted.</p>
<p dir="auto">Will let you know after testing.</p>
<p dir="auto">Thanks again.</p>
]]></description><link>https://forum.magicmirror.builders/post/103854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103854</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to RPI 3B keeps going to blank screen (cursor showing) on Tue, 23 Aug 2022 12:27:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: BigTJ">@<bdi>BigTJ</bdi></a> script has disabled</p>
]]></description><link>https://forum.magicmirror.builders/post/103853</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103853</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Aug 2022 12:27:09 GMT</pubDate></item></channel></rss>
