<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Electron v20 will coming with next release but...]]></title><description><![CDATA[<p dir="auto">Hi, <a class="plugin-mentions-user plugin-mentions-a" href="/user/development" aria-label="Profile: development">@<bdi>development</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a></p>
<p dir="auto">That I see next release of MM² will received <code>Electron v20.x</code><br />
I just make a warn with this version.</p>
<p dir="auto">I just discover that:<br />
We are not able to use <code>electron-rebuild</code> with some  dependencies</p>
<p dir="auto">I tried to update many dependency for compiling but it’s failed on each time<br />
tested with <code>node-gyp</code> &gt;= 8.4.0 , <code>electron-rebuild</code> &gt;=3.2.8, <code>node</code> &gt;= 16.15.0</p>
<p dir="auto">Impact of this ?</p>
<p dir="auto">sample, if a user use PIR Sensor, Some hotwords for controling with vocal MM²<br />
Result: they can’t use it because they can’t rebuild the dedicated module</p>
<p dir="auto">Can you leave some time for correct this by leave electron v19.x in next release ?<br />
Naturaly, I (or we) will try solve this situation before the next next release (~2023-01)</p>
<p dir="auto">Or this forum will have many issue … unsolved !</p>
<p dir="auto">Thanks for reading,<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/topic/17174/electron-v20-will-coming-with-next-release-but</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 14:33:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17174.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Sep 2022 13:12:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Tue, 06 Sep 2022 00:34:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/104216">Electron v20 will coming with next release but...</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a> where do you see 12?</p>
<p dir="auto">all is ok to 19</p>
<p dir="auto"><a href="https://github.com/fivdi/epoll/issues/42" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fivdi/epoll/issues/42</a><br />
Top comment by David</p>
]]></description><link>https://forum.magicmirror.builders/post/104217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104217</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Tue, 06 Sep 2022 00:34:32 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Tue, 06 Sep 2022 00:20:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a> where do you see 12?</p>
]]></description><link>https://forum.magicmirror.builders/post/104216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104216</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 06 Sep 2022 00:20:13 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Tue, 06 Sep 2022 00:08:51 GMT]]></title><description><![CDATA[<p dir="auto">I saw on those github issues posed above that</p>
<p dir="auto">“This will result in applications that use epoll/onoff being broken after Electron 12.”</p>
<p dir="auto">That means most of the button and input sensor type magicmirror modules will probably break.</p>
<p dir="auto">So, I"m kinda glad I broke my new button module. and found this info  right after.  I think I"m going to go with a python based script and bypass the node on/off and epoll. So back to the drawing board.</p>
]]></description><link>https://forum.magicmirror.builders/post/104214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104214</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Tue, 06 Sep 2022 00:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Sun, 04 Sep 2022 14:37:40 GMT]]></title><description><![CDATA[<p dir="auto">at least in the case of PIR,  it appears<br />
MMM-PIR-Sensor-Lite works as it uses python for triggering</p>
<p dir="auto"><a href="https://github.com/grenagit/MMM-PIR-Sensor-Lite" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/grenagit/MMM-PIR-Sensor-Lite</a></p>
]]></description><link>https://forum.magicmirror.builders/post/104174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104174</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 04 Sep 2022 14:37:40 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Sun, 04 Sep 2022 14:28:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
<p dir="auto">I opened this MM issue</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/issues/2903" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/2903</a></p>
]]></description><link>https://forum.magicmirror.builders/post/104173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104173</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 04 Sep 2022 14:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Sun, 04 Sep 2022 20:41:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> I agree</p>
<p dir="auto">I opened this on epoll<br />
<a href="https://github.com/fivdi/epoll/issues/47" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fivdi/epoll/issues/47</a></p>
<p dir="auto">it was closed as a dup of<br />
<a href="https://github.com/fivdi/epoll/issues/42" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fivdi/epoll/issues/42</a>, about a year old</p>
<p dir="auto">but have little hope</p>
]]></description><link>https://forum.magicmirror.builders/post/104170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104170</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 04 Sep 2022 20:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Sun, 04 Sep 2022 14:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> said in <a href="/post/104165">Electron v20 will coming with next release but...</a>:</p>
<p dir="auto">Can you leave some time for correct this by leave electron v19.x in next release ?</p>
<p dir="auto">I think there is no choice so I will revert electron on <code>develop</code> branch back to v19 with next dependency update …</p>
]]></description><link>https://forum.magicmirror.builders/post/104168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104168</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sun, 04 Sep 2022 14:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to Electron v20 will coming with next release but... on Sun, 04 Sep 2022 14:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> yes, the issue is really here</p>
<p dir="auto"><a href="https://github.com/nodejs/nan/issues/922#issuecomment-974779085" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nodejs/nan/issues/922#issuecomment-974779085</a></p>
<p dir="auto">epoll uses nan</p>
]]></description><link>https://forum.magicmirror.builders/post/104167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104167</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 04 Sep 2022 14:08:20 GMT</pubDate></item></channel></rss>
