<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error: object_proxy]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Has anybody seen the below error before?</p>
<pre><code>[05.09.2022 14:56.10.632] [LOG]   Starting node helper for: calendar
[05.09.2022 14:56.10.636] [LOG]   Sockets connected &amp; modules started ...
[05.09.2022 14:56.12.960] [LOG]   Launching application.
[1795:0905/145613.398359:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
[1831:0905/145616.499054:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1986:0905/145625.126377:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[2044:0905/145627.535447:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[2067:0905/145628.319236:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[1868:0905/145628.436569:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
]]></description><link>https://forum.magicmirror.builders/topic/17179/error-object_proxy</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 01:44:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17179.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Sep 2022 16:56:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 19:35:30 GMT]]></title><description><![CDATA[<p dir="auto">see <a href="https://github.com/MichMich/MagicMirror/issues/2831" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/2831</a></p>
]]></description><link>https://forum.magicmirror.builders/post/104211</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104211</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Mon, 05 Sep 2022 19:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 18:31:47 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> much appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/104206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104206</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 05 Sep 2022 18:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 18:01:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> cool…</p>
<p dir="auto">one could set that in <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">export ELECTRON_DISABLE_GPU=true</p>
]]></description><link>https://forum.magicmirror.builders/post/104202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104202</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 05 Sep 2022 18:01:06 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 17:58:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a><br />
I think it could be applied permanently by <code>process.env.ELECTRON_DISABLE_GPU</code> setting.</p>
]]></description><link>https://forum.magicmirror.builders/post/104201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104201</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 05 Sep 2022 17:58:03 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 17:24:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> upgrade? mm  yes, package.json  is replaced</p>
]]></description><link>https://forum.magicmirror.builders/post/104197</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104197</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 05 Sep 2022 17:24:54 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 17:17:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks Sam. I had the gpu previously. Could have been overridden by upgrade?</p>
<p dir="auto">First time I see the first error though. Anyway, I will google a bit.</p>
]]></description><link>https://forum.magicmirror.builders/post/104196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104196</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 05 Sep 2022 17:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to Error: object_proxy on Mon, 05 Sep 2022 17:11:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> not the top ones  add</p>
<p dir="auto">–disable-gpu</p>
<p dir="auto">to the package.json start clause</p>
<pre><code>"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable-gpu js/electron.js
]]></description><link>https://forum.magicmirror.builders/post/104194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104194</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 05 Sep 2022 17:11:37 GMT</pubDate></item></channel></rss>
