<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PIR sensor problem after restart Raspi]]></title><description><![CDATA[<p dir="auto">Hello,<br />
i restarted my Raspi yesterday, since then the monitor hasn’t gone into standby anymore. I think some Raspian updates have been installed, could it be related to that? Nothing was changed in the MM configuration. Does somebody has any idea?</p>
<p dir="auto">Greetings Joerg</p>
]]></description><link>https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 14:07:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17185.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Sep 2022 05:07:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Tue, 13 Sep 2022 17:28:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> It is probably because of the current firmware 5.15<br />
With</p>
<pre><code>rpi-update b976c54917e240630c05a9b383010f1492bc61b4
<p dir="auto">I installed version 5.10. It now works again with the standby on the HDMI connection.</p>
<p dir="auto">Greetings Joerg<br />
edited due to wrong quotes outside code block</p>
]]></description><link>https://forum.magicmirror.builders/post/104506</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104506</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Tue, 13 Sep 2022 17:28:25 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sun, 11 Sep 2022 16:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Nothing happens in the window. :-( PIR sensor broken?</p>
<p dir="auto"><img src="/assets/uploads/files/1662912494173-bildschirmfoto-2022-09-11-um-18.05.41.png" alt="Bildschirmfoto 2022-09-11 um 18.05.41.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/104443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104443</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 11 Sep 2022 16:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sun, 11 Sep 2022 11:56:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> ok, it’s not a second process getting in the way</p>
<p dir="auto">next to test the sensor w the python script</p>
<p dir="auto">stop mm</p>
]]></description><link>https://forum.magicmirror.builders/post/104415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104415</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 11 Sep 2022 11:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sun, 11 Sep 2022 07:23:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ┌─────┬────────────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐<br />
│ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │<br />
├─────┼────────────────┼─────────────┼─────────┼─────────┼──────────┼────────┼──────┼───────────┼──────────┼──────────┼──────────┼──────────┤<br />
│ 0   │ MagicMirror    │ default     │ 2.20.0  │ fork    │ 12738    │ 64s    │ 0    │ online    │ 0%       │ 2.6mb    │ pi       │ disabled │<br />
└─────┴────────────────┴─────────────┴─────────┴─────────┴──────────┴────────┴──────┴───────────┴──────────┴──────────┴──────────┴──────────┘<br />
pi@raspberrypi:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/104405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104405</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 11 Sep 2022 07:23:35 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 13:47:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> well, its shouldn’t go off by itself… as then u would have two things fighting for on or off…</p>
<p dir="auto">do this, i assume you have pm2 controlling mm at boot</p>
<p dir="auto">so, do</p>
<p dir="auto">pm2 status</p>
<p dir="auto">should only be one thing…  defined</p>
]]></description><link>https://forum.magicmirror.builders/post/104377</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104377</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 10 Sep 2022 13:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 12:55:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ok, that tests the PIR sensor. But since the Raspi doesn’t even let the monitor go into standby, I suspect that it’s due to Raspian. Screen blanking is activated in Raspi-Config, so the monitor should switch off after 10 minutes, right? But that doesn’t work either. Or does that have nothing to do with the PIR function of MM?</p>
]]></description><link>https://forum.magicmirror.builders/post/104376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104376</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sat, 10 Sep 2022 12:55:04 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 12:33:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> Google search is your friend</p>
<p dir="auto"><a href="https://github.com/raspberrypilearning/physical-computing-guide/blob/master/test-pir-python.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/raspberrypilearning/physical-computing-guide/blob/master/test-pir-python.md</a></p>
]]></description><link>https://forum.magicmirror.builders/post/104375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104375</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 10 Sep 2022 12:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 12:21:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> How can I test this?</p>
]]></description><link>https://forum.magicmirror.builders/post/104374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104374</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sat, 10 Sep 2022 12:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 10:44:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> and does it works correctly outside mm?</p>
<p dir="auto">there are python scripts that will show it working</p>
]]></description><link>https://forum.magicmirror.builders/post/104372</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104372</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 10 Sep 2022 10:44:50 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Sat, 10 Sep 2022 06:15:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> The sensor is correctly connected</p>
]]></description><link>https://forum.magicmirror.builders/post/104367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104367</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sat, 10 Sep 2022 06:15:16 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Fri, 09 Sep 2022 17:40:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> said in <a href="/post/104357">PIR sensor problem after restart Raspi</a>:</p>
<p dir="auto">I did it according to this guide (in German) have the same pir sensor as in the guide.</p>
<p dir="auto">Have you checked that the PIR is on the correct pins of the GPIO?</p>
]]></description><link>https://forum.magicmirror.builders/post/104358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104358</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Fri, 09 Sep 2022 17:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Fri, 09 Sep 2022 13:52:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> I did it according to this guide (in German) have the same pir sensor as in the guide.</p>
]]></description><link>https://forum.magicmirror.builders/post/104357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104357</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Fri, 09 Sep 2022 13:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Fri, 09 Sep 2022 13:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> have you tried to run the two modules following this guide written by <a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> ?<br />
<a href="https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md</a></p>
<p dir="auto">Which PIR sensor do you have?</p>
]]></description><link>https://forum.magicmirror.builders/post/104355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104355</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Fri, 09 Sep 2022 13:29:03 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Fri, 09 Sep 2022 13:24:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> Doesn’t work either, the monitor doesn’t go into standby :-( The Raspbian screensaver function does not seem to work. Can this be reinstalled?</p>
]]></description><link>https://forum.magicmirror.builders/post/104354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104354</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Fri, 09 Sep 2022 13:24:17 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Fri, 09 Sep 2022 09:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> I can recommend these two modules for the PIR (I just installed them, they also work with the S.O. bullseye):</p>
<p dir="auto">MMM-GPIO-Notifications: <a href="https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications</a><br />
MMM-Screen-Powersave-Notification: <a href="https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification</a></p>
]]></description><link>https://forum.magicmirror.builders/post/104347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104347</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Fri, 09 Sep 2022 09:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Thu, 08 Sep 2022 14:27:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> MMM-PIR-Sensor</p>
]]></description><link>https://forum.magicmirror.builders/post/104337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104337</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Thu, 08 Sep 2022 14:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Thu, 08 Sep 2022 12:29:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> which pir module are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/104333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104333</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Sep 2022 12:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Thu, 08 Sep 2022 04:59:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a> There are no errors in the logs, nothing was changed in MM. Otherwise the screen was always black when MM started, and the monitor only came on after there was movement in front of the PIR sensor. Now the picture is there right after the start and the monitor no longer goes into standby. So I think it must be something to do with Raspian. Or maybe Electron? I have no idea what happened there… :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/104326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104326</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Thu, 08 Sep 2022 04:59:57 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor problem after restart Raspi on Thu, 08 Sep 2022 00:32:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> have you checked the logs and see whats throwing errors? That is where I would start.</p>
]]></description><link>https://forum.magicmirror.builders/post/104317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104317</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Thu, 08 Sep 2022 00:32:48 GMT</pubDate></item></channel></rss>
