<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing days when in portrait orientation CalendarExt3]]></title><description><![CDATA[<p dir="auto">I’m having trouble using this module. It works perfect when it’s in landscape mode, but when I turn my monitor to portrait mode using custom css, I am losing Monday and Sunday on my calendar. Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17204/missing-days-when-in-portrait-orientation-calendarext3</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 09:44:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17204.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Sep 2022 13:54:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing days when in portrait orientation CalendarExt3 on Thu, 15 Sep 2022 08:26:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fguido" aria-label="Profile: fguido">@<bdi>fguido</bdi></a><br />
And I need more detail info about <code>‘rotating’ with custom css</code> meaning. Because this module would use ‘vw’ things, so with ‘transform 2D’ to rotate, this will make an issue.<br />
Simply you can assign physical real metrics (00px) instead of relative/dynamic metrics(vw, % ) by your manual calculations. Or considering transformed result, adjust values to fit with it.</p>
]]></description><link>https://forum.magicmirror.builders/post/104536</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104536</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 15 Sep 2022 08:26:42 GMT</pubDate></item><item><title><![CDATA[Reply to Missing days when in portrait orientation CalendarExt3 on Thu, 15 Sep 2022 08:10:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fguido" aria-label="Profile: fguido">@<bdi>fguido</bdi></a><br />
I need your custom.css and config.js and screenshot.</p>
<p dir="auto">To make things simpler, remove all other modules except original calendar and CX3, then excute MM. show me the result and the files of that moment.</p>
]]></description><link>https://forum.magicmirror.builders/post/104535</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104535</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 15 Sep 2022 08:10:56 GMT</pubDate></item><item><title><![CDATA[Reply to Missing days when in portrait orientation CalendarExt3 on Thu, 15 Sep 2022 02:16:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fguido" aria-label="Profile: fguido">@<bdi>fguido</bdi></a> I edited the title</p>
]]></description><link>https://forum.magicmirror.builders/post/104532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104532</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Sep 2022 02:16:56 GMT</pubDate></item><item><title><![CDATA[Reply to Missing days when in portrait orientation CalendarExt3 on Thu, 15 Sep 2022 02:12:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh Jeeze. I was trying to reply to the mmm-calandarext3 post.</p>
]]></description><link>https://forum.magicmirror.builders/post/104531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104531</guid><dc:creator><![CDATA[fguido]]></dc:creator><pubDate>Thu, 15 Sep 2022 02:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to Missing days when in portrait orientation CalendarExt3 on Tue, 13 Sep 2022 13:56:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fguido" aria-label="Profile: fguido">@<bdi>fguido</bdi></a> said in <a href="/post/104502">Missing days when in portrait orientation</a>:</p>
<p dir="auto">I’m having trouble using this module</p>
<p dir="auto">what module?</p>
]]></description><link>https://forum.magicmirror.builders/post/104503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104503</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Sep 2022 13:56:26 GMT</pubDate></item></channel></rss>
