<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Calendar Troubleshooting - "No Upcoming Events"]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am having some trouble with the default calendar module. I have the config set up <em>I believe</em> correctly and the secret iCal link downloads a file so I know that is working.</p>
<p dir="auto">Config:</p>
<pre><code>		{
			header: "Skaggs Family Calendar",
			position: "bottom_right", // This can be any of the regions. Best results in left or right regions.
				maximumEntries: 365, // Total Maximum Entries
				maximumNumberOfDays: 365,
				fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
				getRelative: 6,
				fadePoint: 0.25, // Start on 1/4th of the list.
				colored: true,
				coloredSymbolOnly: false,
				customEvents: [], // Array of {keyword: "", symbol: "", color: ""} where Keyword is a regexp and symbol/color are to be applied for matched
				tableClass: "small",
					symbol: "calendar-alt",
					url: "https://calendar.google.com/calendar/ical/curlyq12391%40gmail.com/private-**xxxxxxxxx**/basic.ics",
				broadcastEvents: true,
				sliceMultiDayEvents: false,
				broadcastPastEvents: true,
				nextDaysRelative: false,
				selfSignedCert: false
<p dir="auto">I am able to see that the calendar IS broadcasting events through the log, so I assume that is functioning correctly…</p>
<p dir="auto">Logs:</p>
<pre><code>0|mm     | &gt; magicmirror@2.20.0 start
0|mm     | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|mm     | [28.09.2022 07:29.56.841] [LOG]
0|mm     | Starting MagicMirror: v2.20.0
0|mm     | [28.09.2022 07:29.56.850] [LOG]
0|mm     | Loading config ...
0|mm     | [28.09.2022 07:29.56.858] [LOG]
0|mm     | Loading module helpers ...
0|mm     | [28.09.2022 07:29.56.863] [LOG]
0|mm     | No helper found for module: MMM-pages.
0|mm     | [28.09.2022 07:29.56.867] [LOG]
0|mm     | No helper found for module: MMM-page-indicator.
0|mm     | [28.09.2022 07:29.56.871] [LOG]
0|mm     | No helper found for module: alert.
0|mm     | [28.09.2022 07:29.56.891] [LOG]
0|mm     | Initializing new module helper ...
0|mm     | [28.09.2022 07:29.56.894] [LOG]
0|mm     | Module helper loaded: updatenotification
0|mm     | [28.09.2022 07:29.56.898] [LOG]
0|mm     | No helper found for module: clock.
0|mm     | [28.09.2022 07:29.57.195] [LOG]   Initializing new module helper ...
0|mm     | [28.09.2022 07:29.57.197] [LOG]   Module helper loaded: calendar
0|mm     | [28.09.2022 07:29.57.198] [LOG]
0|mm     | No helper found for module: MMM-CalendarExt3.
0|mm     | [28.09.2022 07:29.57.232] [LOG]
0|mm     | [28.09.2022 07:29.57.234] [LOG]
0|mm     | Module helper loaded: newsfeed
0|mm     | [28.09.2022 07:29.57.334] [LOG]
0|mm     | [28.09.2022 07:29.57.335] [LOG]
0|mm     | Module helper loaded: MMM-OpenWeatherForecast
0|mm     | [28.09.2022 07:29.59.336] [LOG]
0|mm     | [28.09.2022 07:29.59.337] [LOG]   Module helper loaded: MMM-RemoteCompliments
0|mm     | [28.09.2022 07:29.59.339] [LOG]
0|mm     | No helper found for module: MMM-Cursor.
0|mm     | [28.09.2022 07:29.59.342] [LOG]
0|mm     | [28.09.2022 07:29.59.342] [LOG]   Module helper loaded: MMM-Touch
0|mm     | [28.09.2022 07:29.59.343] [LOG]   All module helpers loaded.
0|mm     | [28.09.2022 07:29.59.468] [LOG]
0|mm     | Starting server on port 8080 ...
0|mm     | [28.09.2022 07:29.59.483] [LOG]
0|mm     | Server started ...
0|mm     | [28.09.2022 07:29.59.485] [LOG]   Connecting socket for: updatenotification
0|mm     | [28.09.2022 07:29.59.486] [LOG]
0|mm     | Starting module helper: updatenotification
0|mm     | [28.09.2022 07:29.59.487] [LOG]   Connecting socket for: calendar
0|mm     | [28.09.2022 07:29.59.488] [LOG]   Starting node helper for: calendar
0|mm     | [28.09.2022 07:29.59.489] [LOG]   Connecting socket for: newsfeed
0|mm     | [28.09.2022 07:29.59.490] [LOG]   Starting node helper for: newsfeed
0|mm     | [28.09.2022 07:29.59.491] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
0|mm     | [28.09.2022 07:29.59.493] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
0|mm     | [28.09.2022 07:29.59.494] [LOG]   Connecting socket for: MMM-RemoteCompliments
0|mm     | [28.09.2022 07:29.59.497] [LOG]   Starting node helper for: MMM-RemoteCompliments
0|mm     | [28.09.2022 07:29.59.497] [LOG]   Connecting socket for: MMM-Touch
0|mm     | [28.09.2022 07:29.59.498] [LOG]   Starting module helper: MMM-Touch
0|mm     | [28.09.2022 07:29.59.498] [LOG]   Sockets connected &amp; modules started ...
0|mm     | [28.09.2022 07:29.59.855] [LOG]
0|mm     | Launching application.
0|mm     | MESA-LOADER: failed to retrieve device information
0|mm     | MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
0|mm     | failed to load driver: kms_swrast
0|mm     | MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
0|mm     | failed to load swrast driver
0|mm     | [28.09.2022 07:30.03.015] [LOG]
0|mm     | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/curlyq12391%40gmail.com/private-**xxxxxxxxx**/basic.ics - Interval: 300000
0|mm     | [28.09.2022 07:30.03.112] [LOG]
0|mm     | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
0|mm     | [28.09.2022 07:30.03.147] [INFO]
0|mm     | Checking git for module: MMM-pages
0|mm     | [28.09.2022 07:30.03.210] [INFO]
0|mm     | Checking git for module: MMM-page-indicator
0|mm     | [28.09.2022 07:30.03.243] [INFO]
0|mm     | Checking git for module: MMM-CalendarExt3
0|mm     | [28.09.2022 07:30.03.301] [INFO]
0|mm     | Checking git for module: MMM-OpenWeatherForecast
0|mm     | [28.09.2022 07:30.03.331] [INFO]
0|mm     | Checking git for module: MMM-RemoteCompliments
0|mm     | [28.09.2022 07:30.03.362] [INFO]
0|mm     | Checking git for module: MMM-Cursor
0|mm     | [28.09.2022 07:30.03.400] [INFO]
0|mm     | Checking git for module: MMM-Touch
0|mm     | [28.09.2022 07:30.03.432] [INFO]
0|mm     | Checking git for module: default
0|mm     | [28.09.2022 07:30.03.760] [INFO]
0|mm     | Newsfeed-Fetcher: Broadcasting 38 items.
0|mm     | [28.09.2022 07:30.08.243] [INFO]
0|mm     | Calendar-Fetcher: Broadcasting 365 events.
<p dir="auto">However, when MM renders the module just says “No Upcoming Events”.</p>
<p dir="auto">is there anything that I seem to be missing or something I can try? I can get the calendar to load with <a href="https://github.com/randomBrainstormer/MMM-GoogleCalendar" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GoogleCalendar</a>, but that module doesn’t broadcast past events so it makes <a href="https://github.com/MMRIZE/MMM-CalendarExt3" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-CalendarExt3</a> pointless…which is why I was trying to use the default calendar module instead.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17237/default-calendar-troubleshooting-no-upcoming-events</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 14:22:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17237.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Sep 2022 15:08:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Calendar Troubleshooting - "No Upcoming Events" on Wed, 28 Sep 2022 15:50:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/curlyq12391" aria-label="Profile: CurlyQ12391">@<bdi>CurlyQ12391</bdi></a> this is probably due to the bug i introduced in 2.20.    it chops off the collection of old+new events at maxEntries</p>
<p dir="auto">looks like u have lots of old events ( I see crap from 2017 in my list of old)</p>
<p dir="auto">anyhow.  fix coming in 2.21 (on Saturday), or make maxEntries bigger in the short term</p>
<p dir="auto">365 events broadcast and none showing means there are all old. we don’t display old.</p>
]]></description><link>https://forum.magicmirror.builders/post/104783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104783</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Sep 2022 15:50:46 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Troubleshooting - "No Upcoming Events" on Wed, 28 Sep 2022 16:39:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/curlyq12391" aria-label="Profile: CurlyQ12391">@<bdi>CurlyQ12391</bdi></a> maxEntries applies only to today forward.  past are broadcast too<br />
only today forward are used in cal module</p>
]]></description><link>https://forum.magicmirror.builders/post/104786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104786</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Sep 2022 16:39:36 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Troubleshooting - "No Upcoming Events" on Wed, 28 Sep 2022 16:15:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/curlyq12391" aria-label="Profile: CurlyQ12391">@<bdi>CurlyQ12391</bdi></a> you should decrease it. let me look at the fix to see what it does</p>
]]></description><link>https://forum.magicmirror.builders/post/104785</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104785</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Sep 2022 16:15:43 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Troubleshooting - "No Upcoming Events" on Wed, 28 Sep 2022 16:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> omg you are amazing!</p>
<p dir="auto">I increassed the maximumEntries value to “1000000” and viola everything populated into  MMM-CalendarExt3. I had previously increased it to “10000”, but apparently I just had too many old events.</p>
<p dir="auto">After the fix is rolled out should I decrease the maximumEntries value to a smaller number or can I leave it as is? I dont want to break mine after you fix it (haha).</p>
]]></description><link>https://forum.magicmirror.builders/post/104784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104784</guid><dc:creator><![CDATA[CurlyQ12391]]></dc:creator><pubDate>Wed, 28 Sep 2022 16:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Troubleshooting - "No Upcoming Events" on Wed, 28 Sep 2022 15:50:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/curlyq12391" aria-label="Profile: CurlyQ12391">@<bdi>CurlyQ12391</bdi></a> this is probably due to the bug i introduced in 2.20.    it chops off the collection of old+new events at maxEntries</p>
]]></description><link>https://forum.magicmirror.builders/post/104783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104783</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Sep 2022 15:50:46 GMT</pubDate></item></channel></rss>
