<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Fuel shorten text]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">why the shorten text function in the module leave just one letter? I want to shorten the text but I need mor then one letter. It is possible to change this somewhere?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1726/mmm-fuel-shorten-text</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 04:57:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1726.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Feb 2017 18:02:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Fuel shorten text on Wed, 08 Mar 2017 17:11:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi, have another issue with the shortenText functionality. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.</p>
]]></description><link>https://forum.magicmirror.builders/post/16836</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16836</guid><dc:creator><![CDATA[sindbad6]]></dc:creator><pubDate>Wed, 08 Mar 2017 17:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel shorten text on Sun, 12 Feb 2017 13:35:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> That’s it! Thanks a lot.</p>
]]></description><link>https://forum.magicmirror.builders/post/14328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14328</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Sun, 12 Feb 2017 13:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel shorten text on Sun, 12 Feb 2017 12:06:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> you have to define the characters you want to sghow like <code>shortenText: 10</code> which will give you the ten first characters</p>
]]></description><link>https://forum.magicmirror.builders/post/14319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14319</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 12 Feb 2017 12:06:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel shorten text on Sun, 12 Feb 2017 09:09:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> it looks like this…</p>
<pre><code>{
			module: "MMM-Fuel",
			position: "top_center",
				api_key: "xxxxxxxxxxxxxx",
				lat: 51.3912304,
				lng: 10.1903639,
				types: [
					"e10"
				shortenText: true,
				showAddress: false
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/14306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14306</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Sun, 12 Feb 2017 09:09:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel shorten text on Sun, 12 Feb 2017 01:06:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> can you post your config?</p>
]]></description><link>https://forum.magicmirror.builders/post/14288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14288</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 12 Feb 2017 01:06:21 GMT</pubDate></item></channel></rss>
