<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pir sensor]]></title><description><![CDATA[<p dir="auto">Is there any working pir sensor exists? Pir sensor light is not working for me</p>
]]></description><link>https://forum.magicmirror.builders/topic/17263/pir-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 00:44:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17263.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Oct 2022 18:10:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pir sensor on Wed, 01 Feb 2023 12:49:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaoshunter" aria-label="Profile: kaoshunter">@<bdi>kaoshunter</bdi></a> see MMM-PIR-Sensor-Lite</p>
<p dir="auto">supports xrandr</p>
]]></description><link>https://forum.magicmirror.builders/post/107634</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107634</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 01 Feb 2023 12:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Wed, 01 Feb 2023 10:03:43 GMT]]></title><description><![CDATA[<p dir="auto">So I have my PIR working through a python script, from an old install but am  using xrandr, which if run in terminal works great,  I don’t know scripting well and would like to know if someone could make a module, utilising a PIR and xrandr codes below</p>
<p dir="auto">Monitor off:  xrandr --display :0.0 --output HDMI-1 --off<br />
Monitor on:  xrandr --display :0.0 --output HDMI-1 --rotate left --auto</p>
]]></description><link>https://forum.magicmirror.builders/post/107633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107633</guid><dc:creator><![CDATA[kaoshunter]]></dc:creator><pubDate>Wed, 01 Feb 2023 10:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Sun, 29 Jan 2023 18:08:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> didn’t worked for me either.  Recovered my old sd card with mm 1.19 and MMM-PIR-Sensor installed.  Not updating my mm now.</p>
]]></description><link>https://forum.magicmirror.builders/post/107594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107594</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Sun, 29 Jan 2023 18:08:12 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Sat, 07 Jan 2023 12:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mymirror" aria-label="Profile: MyMirror">@<bdi>MyMirror</bdi></a> unfortunately it does not work here.<br />
Pi3, Bullseye, MM2.22: PIR-Sensor does not work at all, PIR-Sensor-Light counts down from 15 minutes, but starts again without turning off the screen.<br />
No idea what to do.<br />
My MM has been working flawlessly for 5 years, but after the new fresh install with 2.22 I am having this problem.<br />
Can anybody help?<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/106985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106985</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Sat, 07 Jan 2023 12:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Mon, 12 Dec 2022 22:02:31 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Thanks will try soon</p>
]]></description><link>https://forum.magicmirror.builders/post/106569</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106569</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Mon, 12 Dec 2022 22:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Mon, 12 Dec 2022 13:44:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> said in <a href="/post/105004">Pir sensor</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it work like <a href="https://github.com/paviro/MMM-PIR-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/paviro/MMM-PIR-Sensor</a><br />
mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like</p>
<p dir="auto">But of course the module still works.7<br />
I have this running on my Pi 3b, Bullseye and MM 2.21.0 …</p>
]]></description><link>https://forum.magicmirror.builders/post/106552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106552</guid><dc:creator><![CDATA[MyMirror]]></dc:creator><pubDate>Mon, 12 Dec 2022 13:44:38 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Sun, 11 Dec 2022 16:39:07 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f  ah ?  So cool so! Give me a sample or tuto?</p>
]]></description><link>https://forum.magicmirror.builders/post/106540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106540</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sun, 11 Dec 2022 16:39:07 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Sun, 11 Dec 2022 14:40:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> no need to install Ext-Screen. You can use Ext-PIR on its own.</p>
]]></description><link>https://forum.magicmirror.builders/post/106539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106539</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 11 Dec 2022 14:40:10 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Tue, 06 Dec 2022 19:37:12 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Hi mate. Thinking to install EXT-Pir now. Just one question do I need EXT-Screen to make it work. If yes how can I configure both module? Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/106444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106444</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Tue, 06 Dec 2022 19:37:12 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Sat, 08 Oct 2022 00:04:22 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Feb… making another smart mirror soon. I’ll give it a try.  Thanks 😊</p>
]]></description><link>https://forum.magicmirror.builders/post/105042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105042</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Sat, 08 Oct 2022 00:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Fri, 07 Oct 2022 23:43:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> No need for google assistant.  Works fine without it.</p>
]]></description><link>https://forum.magicmirror.builders/post/105041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105041</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 07 Oct 2022 23:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Fri, 07 Oct 2022 23:38:58 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Hi do I need MMM-GoogleAssistant for this? Or works on its own?</p>
]]></description><link>https://forum.magicmirror.builders/post/105040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105040</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 07 Oct 2022 23:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Fri, 07 Oct 2022 23:36:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> might be the os firmware, which has reported problems w gpio interrupts</p>
]]></description><link>https://forum.magicmirror.builders/post/105039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105039</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 07 Oct 2022 23:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Fri, 07 Oct 2022 21:31:05 GMT]]></title><description><![CDATA[<p dir="auto">If you’re still looking for a working PIR sensor module, I’m using EXT-Pir and it has been great<br />
<a href="https://github.com/bugsounet/EXT-Pir" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/EXT-Pir</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105034</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105034</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 07 Oct 2022 21:31:05 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Fri, 07 Oct 2022 21:09:19 GMT]]></title><description><![CDATA[<p dir="auto">Thanks guys for your help.  But I recovered  my old sd card which had magicmirror 2.19 installed.  Pir sensor work with that version.  I’m back on truck.</p>
]]></description><link>https://forum.magicmirror.builders/post/105033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105033</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 07 Oct 2022 21:09:19 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:46:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks mate. Will check this in detail once I go home</p>
]]></description><link>https://forum.magicmirror.builders/post/105011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105011</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:45:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pugsly" aria-label="Profile: pugsly">@<bdi>pugsly</bdi></a> I’ll give it a try tomorrow.  Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/105010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105010</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:45:14 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:41:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pugsly" aria-label="Profile: pugsly">@<bdi>pugsly</bdi></a> right, just trying to help w the debug. lots of things can go wrong, so, it’s best to start at the beginning before getting MM involved.</p>
]]></description><link>https://forum.magicmirror.builders/post/105009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105009</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:41:49 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:32:01 GMT]]></title><description><![CDATA[<p dir="auto">This is what I use to put my monitor to sleep using a PIR sensor.  I have a 3D printed case for the sensor that hangs under the mirror itself.  The sensor does not have anything to do with the magic mirror software at all, in fact it just puts the monitor to sleep when no one is in the area.</p>
<p dir="auto"><a href="https://github.com/cowboysdude/Pir-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/Pir-Sensor</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105008</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:32:01 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:18:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> <a href="https://projects.raspberrypi.org/en/projects/parent-detector/3" target="_blank" rel="noopener noreferrer nofollow ugc">https://projects.raspberrypi.org/en/projects/parent-detector/3</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105007</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 21:03:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi mate. Sorry I don’t know how to do that.  I’m not a programming person.  I’m copy past person actually 🤣</p>
]]></description><link>https://forum.magicmirror.builders/post/105006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105006</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Thu, 06 Oct 2022 21:03:35 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 19:32:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> no, my question was , if u test the PIR connection/setup outside of MM does it work</p>
<p dir="auto">using a python script?</p>
<p dir="auto">I undertstand how it is SUPPOSED to work , and have tested modules on one of my systems before, but don’t<br />
use PIR daily</p>
]]></description><link>https://forum.magicmirror.builders/post/105005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105005</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Oct 2022 19:32:32 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 19:30:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it work like <a href="https://github.com/paviro/MMM-PIR-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/paviro/MMM-PIR-Sensor</a><br />
]]></description><link>https://forum.magicmirror.builders/post/105004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105004</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Thu, 06 Oct 2022 19:30:23 GMT</pubDate></item><item><title><![CDATA[Reply to Pir sensor on Thu, 06 Oct 2022 19:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> said in <a href="/post/105002">Pir sensor</a>:</p>
<p dir="auto">and the .js is</p>
<p dir="auto">never edit the module js file</p>
<p dir="auto">all config goes in config.js</p>
<p dir="auto">I don’t know the module</p>
<p dir="auto">does the PIR work outside MM?</p>
]]></description><link>https://forum.magicmirror.builders/post/105003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105003</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Oct 2022 19:14:40 GMT</pubDate></item></channel></rss>
