<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new MM Version]]></title><description><![CDATA[<p dir="auto">Hello together,</p>
<p dir="auto">if I take the command here, I automatically have the latest MagicMirror version?</p>
<pre><code>https://github.com/sdetweil/MagicMirror_scripts
]]></description><link>https://forum.magicmirror.builders/topic/17276/new-mm-version</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 14:51:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17276.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Oct 2022 15:15:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new MM Version on Mon, 10 Oct 2022 15:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kusselin" aria-label="Profile: kusselin">@<bdi>kusselin</bdi></a> upgrade is a two step process</p>
<p dir="auto">test (no changes)</p>
<p dir="auto">and if u find troubles, allow u to fix or not upgrade</p>
<p dir="auto">then upgrade</p>
<p dir="auto">same script without or with parameter (‘apply’)</p>
<p dir="auto">then you will upgrade from your version to latest<br />
if script fails I will fix it</p>
]]></description><link>https://forum.magicmirror.builders/post/105090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105090</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Oct 2022 15:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to new MM Version on Mon, 10 Oct 2022 15:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kusselin" aria-label="Profile: kusselin">@<bdi>kusselin</bdi></a> there are multiple things on that page</p>
]]></description><link>https://forum.magicmirror.builders/post/105091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105091</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Oct 2022 15:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to new MM Version on Mon, 10 Oct 2022 15:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kusselin" aria-label="Profile: kusselin">@<bdi>kusselin</bdi></a> upgrade is a two step process</p>
]]></description><link>https://forum.magicmirror.builders/post/105090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105090</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Oct 2022 15:22:04 GMT</pubDate></item></channel></rss>
