<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extra Text in Weather Module Header]]></title><description><![CDATA[<p dir="auto">I am very much new to Magic Mirror, been running for about 2 weeks.  I have it mostly setup the way I want, but there is on thing that I have not been able to figure out.  On the weather module it displays AMERICA/DENVER to the right of the header I have set and can’t see to figure out how to make that go away.</p>
<p dir="auto"><img src="/assets/uploads/files/1665466283554-8bd979fa-e90d-43c2-b1eb-97059519785f-image.png" alt="8bd979fa-e90d-43c2-b1eb-97059519785f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Below is the code for the weather modules.  If anyone has any assistance it would be great.</p>
<p dir="auto"><img src="/assets/uploads/files/1665466444660-5bf49720-c68b-4e5f-9936-fa3b1da6471d-image.png" alt="5bf49720-c68b-4e5f-9936-fa3b1da6471d-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/17283/extra-text-in-weather-module-header</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 06:54:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17283.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Oct 2022 05:45:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 18:50:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ehelberg88" aria-label="Profile: EHelberg88">@<bdi>EHelberg88</bdi></a> no. you have it set to ‘false’, not false</p>
<p dir="auto">quotes make it a string, which is always true</p>
<p dir="auto">true, false and numbers do not use quotes</p>
]]></description><link>https://forum.magicmirror.builders/post/105135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105135</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Oct 2022 18:50:38 GMT</pubDate></item><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 20:54:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ehelberg88" aria-label="Profile: EHelberg88">@<bdi>EHelberg88</bdi></a> ‘true’ is a string which evaluates to true… boolean 1</p>
<p dir="auto">‘false’ is also a string which evaluates to true, boolean 1</p>
<p dir="auto">false, no quotes, is a boolean , 0</p>
]]></description><link>https://forum.magicmirror.builders/post/105141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105141</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Oct 2022 20:54:35 GMT</pubDate></item><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 18:53:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I will also have to go through and remove the quotes from the other lines, but the other lines I work with the quotes, which is why I was confused.  Removal of the quotes worked and the location disappears.  Thank you so much!</p>
]]></description><link>https://forum.magicmirror.builders/post/105140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105140</guid><dc:creator><![CDATA[EHelberg88]]></dc:creator><pubDate>Tue, 11 Oct 2022 18:53:43 GMT</pubDate></item><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 18:50:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ehelberg88" aria-label="Profile: EHelberg88">@<bdi>EHelberg88</bdi></a> no. you have it set to ‘false’, not false</p>
]]></description><link>https://forum.magicmirror.builders/post/105135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105135</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Oct 2022 18:50:38 GMT</pubDate></item><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 18:43:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> the appendLocationNameToHeader is set to false in my code as shown above.</p>
]]></description><link>https://forum.magicmirror.builders/post/105133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105133</guid><dc:creator><![CDATA[EHelberg88]]></dc:creator><pubDate>Tue, 11 Oct 2022 18:43:01 GMT</pubDate></item><item><title><![CDATA[Reply to Extra Text in Weather Module Header on Tue, 11 Oct 2022 12:59:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ehelberg88" aria-label="Profile: EHelberg88">@<bdi>EHelberg88</bdi></a> in the documentation for the module is a setting to display (or not) the location</p>
<p dir="auto">true by default</p>
<p dir="auto"><img src="/assets/uploads/files/1665493150252-screenshot_20221011-075810_chrome.jpg" alt="Screenshot_20221011-075810_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/105122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105122</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Oct 2022 12:59:14 GMT</pubDate></item></channel></rss>
