<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen when starting MM...]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">So, it’s been a while since I’ve worked on MM.  So, I just recently upgraded my PI3 and updated MM as well to the latest version.  I’m getting a black screen whenever I’m starting MM.  This is what I’m getting after running /npm start…(any help is appreciated)</p>
<pre><code>&gt;magicmirror@2.21.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[17.10.2022 05:48.57.151] [LOG]   Starting MagicMirror: v2.21.0
[17.10.2022 05:48.57.182] [LOG]   Loading config ...
[17.10.2022 05:48.57.218] [LOG]   Loading module helpers ...
[17.10.2022 05:48.57.231] [LOG]   No helper found for module: alert.
[17.10.2022 05:48.57.307] [LOG]   Initializing new module helper ...
[17.10.2022 05:48.57.312] [LOG]   Module helper loaded: updatenotification
[17.10.2022 05:48.57.319] [LOG]   No helper found for module: clock.
[17.10.2022 05:48.57.350] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
Require stack:
- /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
[17.10.2022 05:48.57.356] [LOG]   Loading module helpers ...
[17.10.2022 05:48.57.362] [LOG]   No helper found for module: alert.
[17.10.2022 05:48.57.367] [LOG]   Initializing new module helper ...
[17.10.2022 05:48.57.370] [LOG]   Module helper loaded: updatenotification
[17.10.2022 05:48.57.374] [LOG]   No helper found for module: clock.
[17.10.2022 05:48.57.398] [ERROR] App threw an error during load
[17.10.2022 05:48.57.406] [ERROR] Error: Cannot find module 'valid-url'
Require stack:
    at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
    at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (node:internal/modules/cjs/loader:785:27)
    at c._load (node:electron/js2c/asar_bundle:5:13343)
    at Module.require (node:internal/modules/cjs/loader:1012:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)
    at Module._compile (node:internal/modules/cjs/loader:1118:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
[17.10.2022 05:48.57.413] [ERROR] Whoops! There was an uncaught exception...
[17.10.2022 05:48.57.445] [ERROR] Error: Cannot find module 'valid-url'
Require stack:
    at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js',
    '/home/pi/MagicMirror/js/app.js',
    '/home/pi/MagicMirror/js/electron.js',
    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[17.10.2022 05:48.57.458] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[17.10.2022 05:48.57.460] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[17.10.2022 05:48.58.962] [LOG]   Launching application.
[1049:1017/054900.709871:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1076:1017/054901.244060:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
<p dir="auto">Turtle</p>
]]></description><link>https://forum.magicmirror.builders/topic/17297/black-screen-when-starting-mm</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:20:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17297.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Oct 2022 10:37:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen when starting MM... on Mon, 17 Oct 2022 18:43:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/turtle" aria-label="Profile: Turtle">@<bdi>Turtle</bdi></a> while looking at the MM screen</p>
<p dir="auto">ctrl-r will reload<br />
ctrl-q will quit<br />
ctrl-m will minimize</p>
<p dir="auto">all same as on Windows for full screen apps</p>
]]></description><link>https://forum.magicmirror.builders/post/105300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105300</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Oct 2022 18:43:29 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen when starting MM... on Mon, 17 Oct 2022 18:39:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  - well, that explains it…I was using ctrl-r and wondering why it wasn’t working.  Eventually, I was just “x” out of the terminal window.  Again, thank you for the help.</p>
]]></description><link>https://forum.magicmirror.builders/post/105299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105299</guid><dc:creator><![CDATA[Turtle]]></dc:creator><pubDate>Mon, 17 Oct 2022 18:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen when starting MM... on Mon, 17 Oct 2022 18:36:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/turtle" aria-label="Profile: Turtle">@<bdi>Turtle</bdi></a>  ctrl-c  will stop the MM instance</p>
]]></description><link>https://forum.magicmirror.builders/post/105298</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105298</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Oct 2022 18:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen when starting MM... on Mon, 17 Oct 2022 18:35:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - thank you for the help.  It’s finally working with your help.  My calendar is up and running.  But another quick question, I’m using npm start to start the calendar.  How would I stop the calendar?  Again, Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/105297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105297</guid><dc:creator><![CDATA[Turtle]]></dc:creator><pubDate>Mon, 17 Oct 2022 18:35:26 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen when starting MM... on Mon, 17 Oct 2022 11:23:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/turtle" aria-label="Profile: Turtle">@<bdi>Turtle</bdi></a> see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105288</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Oct 2022 11:23:25 GMT</pubDate></item></channel></rss>
