<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dynamic change in the size and position of modules]]></title><description><![CDATA[<p dir="auto">I’m looking for a module with which you can change the position and size of modules dynamically. The MMM-ModulePosition  has a very similar functionality, but there you need to restart the mirror and rewrite the css file. I also want me to save the new location and size of the modules and the mirror continues to work, does such a module exist at the moment?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17315/dynamic-change-in-the-size-and-position-of-modules</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 14:26:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17315.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Oct 2022 20:18:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Sun, 16 Feb 2025 13:23:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lucifer6669" aria-label="Profile: lucifer6669">@<bdi>lucifer6669</bdi></a>  Hi, thanks for using the module. Could you share a few more details about what is still working and what isn’t ?  (i.e. which module you can move, does it still save the CSS to your computer, what happens when you try to move other ones, when you save, do you see the pop up ? Can you clear the pop up before moving other Modules , try running with the config set like this:</p>
<pre><code>	{
		module: "MMM-ModulePosition",
		position: "fullscreen_below",
		config: { showAlerts: false, },
<p dir="auto">If you have a github account then you can respond to the issue I raised here: <a href="https://github.com/TheBodger/MMM-ModulePosition/issues/6" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/TheBodger/MMM-ModulePosition/issues/6</a>  Thanks and i will help sort this out for you</p>
]]></description><link>https://forum.magicmirror.builders/post/124083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124083</guid><dc:creator><![CDATA[TheBodger]]></dc:creator><pubDate>Sun, 16 Feb 2025 13:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Sun, 09 Feb 2025 16:13:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thebodger" aria-label="Profile: TheBodger">@<bdi>TheBodger</bdi></a> I am actually using your module, and it was working great until the the most recent update and now there is only one module i can move around the others wont let me. any suggestions would be helpful thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/123885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123885</guid><dc:creator><![CDATA[lucifer6669]]></dc:creator><pubDate>Sun, 09 Feb 2025 16:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Fri, 23 Feb 2024 16:38:15 GMT]]></title><description><![CDATA[<p dir="auto">In case anyone comes by here, please let me know what improvements can be made to the MMM-ModulePosition tool, and I will see if i can incorporate them into it.  TheBodger</p>
]]></description><link>https://forum.magicmirror.builders/post/115853</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115853</guid><dc:creator><![CDATA[TheBodger]]></dc:creator><pubDate>Fri, 23 Feb 2024 16:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:19:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
:_(<br />
MMM-ModulePosition almost perfect, except for the impossibility of making changes without restarting and rewriting the file. Although I would put up with the fact that you need to restart the program, if only it was automatic</p>
]]></description><link>https://forum.magicmirror.builders/post/105474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105474</guid><dc:creator><![CDATA[Azazlo]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:19:15 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:18:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/azazlo" aria-label="Profile: Azazlo">@<bdi>Azazlo</bdi></a> ok, you didn’t say that… no module provides drag/drop positioning of other modules</p>
<p dir="auto">maybe you can merge them together</p>
]]></description><link>https://forum.magicmirror.builders/post/105472</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105472</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:14:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
That’s the point. I need to be able to modify directly with the mouse on the screen, as in the module that I gave as an example. It is very convenient and looks nice, but it does not have a save function without restarting and overwriting the file</p>
]]></description><link>https://forum.magicmirror.builders/post/105471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105471</guid><dc:creator><![CDATA[Azazlo]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:14:47 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:14:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/105473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105473</guid><dc:creator><![CDATA[Azazlo]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:14:47 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:10:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/azazlo" aria-label="Profile: Azazlo">@<bdi>Azazlo</bdi></a> some other app (mmm-remotecontrol maybe)  has to send it a message to move module x to position y</p>
<p dir="auto">here are the available positions<br />
<a href="https://docs.magicmirror.builders/modules/configuration.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/configuration.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105470</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:10:44 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 22:10:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I saw this module, but honestly I could not figure out how it works.</p>
<p dir="auto">I don’t really understand where to insert the line “this.sendNotification(CHANGE_POSITIONS_DEFAULTS);” from this module</p>
]]></description><link>https://forum.magicmirror.builders/post/105469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105469</guid><dc:creator><![CDATA[Azazlo]]></dc:creator><pubDate>Mon, 24 Oct 2022 22:10:41 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic change in the size and position of modules on Mon, 24 Oct 2022 21:18:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/azazlo" aria-label="Profile: Azazlo">@<bdi>Azazlo</bdi></a>  maybe (from 3rd party list)</p>
<p dir="auto"><a href="https://github.com/Toreke/MMM-Dynamic-Modules.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Toreke/MMM-Dynamic-Modules.git</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105467</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Oct 2022 21:18:14 GMT</pubDate></item></channel></rss>
