<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[More then one Grafana Chart]]></title><description><![CDATA[<p dir="auto">Hey there,</p>
<p dir="auto">is it possible to show more then one Grafana Chart on the MM.<br />
(preferably on another page)</p>
<p dir="auto">Mikel</p>
]]></description><link>https://forum.magicmirror.builders/topic/17346/more-then-one-grafana-chart</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 17:06:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17346.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Nov 2022 19:05:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to More then one Grafana Chart on Mon, 21 Nov 2022 12:01:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a></p>
<p dir="auto">Thank you very much - i will try this</p>
]]></description><link>https://forum.magicmirror.builders/post/105965</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105965</guid><dc:creator><![CDATA[michaelJoosten]]></dc:creator><pubDate>Mon, 21 Nov 2022 12:01:26 GMT</pubDate></item><item><title><![CDATA[Reply to More then one Grafana Chart on Sat, 05 Nov 2022 17:08:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michaeljoosten" aria-label="Profile: michaelJoosten">@<bdi>michaelJoosten</bdi></a><br />
I tried some things with Grafana the last days and developed a module called <a href="https://github.com/Tom-Hirschberger/MMM-EmbedURL" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-EmbedURL</a>.</p>
<p dir="auto">It is able to display multiple Grafana panels in Iframes or Webviews.  No matter what type of panel it can be displayed (Chart, Gauge, etc.).<br />
BUT: You will need to configure Grafana to allow anonymous access to the panels you like to embed. I added a <a href="https://github.com/Tom-Hirschberger/MMM-EmbedURL/blob/main/doc/grafana.md" target="_blank" rel="noopener noreferrer nofollow ugc">HowTo</a> of a possible Grafana configuration.<br />
All anonymous access will be mapped to one organization. If you configure two different organizations you can decide which panels should be visible without login and which ones require authentication.</p>
<p dir="auto">The module supports multi-instance. You can add it with different configuration to different positions.</p>
<p dir="auto">Edit: Depending of which module you use to realize the pages you may need to copy the module cause i.e. <a href="https://github.com/edward-shen/MMM-pages" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-pages</a> uses the module name as identifier. <a href="https://github.com/tosti007/MMM-ProfileSwitcher" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-ProfileSwitcher</a> instead uses “classes”.</p>
]]></description><link>https://forum.magicmirror.builders/post/105688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105688</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sat, 05 Nov 2022 17:08:40 GMT</pubDate></item></channel></rss>
