<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Camera via browser]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Just wondering the plausibility of the following scenario. I have MM running on my homelab and connect into it via an old PC (soon will be an old phone for power reasons, fml). Essentially this PC has a webcam connected to it for the intended use taking pictures of course.</p>
<p dir="auto">So the current solutions come down to modules such as SelfieShoot that uses local resources to the MM instance or deploy my webcam as a IP cam and then use a remoting module to display that feed… If there is another way please please let me know! Also yes the SelfieShoot moudule is likely not to work but I’m hopeful.</p>
<p dir="auto">The ideal scenario is if theres a way for the MM to request webcam access via the browser and then store that result locally on the MM container.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17355/camera-via-browser</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 04:23:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17355.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Nov 2022 21:32:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Camera via browser on Thu, 24 Nov 2022 18:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> Hello, just following up on this and if you happened to have found the time?</p>
]]></description><link>https://forum.magicmirror.builders/post/106090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106090</guid><dc:creator><![CDATA[Alyx]]></dc:creator><pubDate>Thu, 24 Nov 2022 18:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to Camera via browser on Sun, 13 Nov 2022 19:46:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> You would be forever amazing if you could do this  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/105787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105787</guid><dc:creator><![CDATA[Alyx]]></dc:creator><pubDate>Sun, 13 Nov 2022 19:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to Camera via browser on Thu, 10 Nov 2022 17:20:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alyx" aria-label="Profile: Alyx">@<bdi>Alyx</bdi></a> maybe it’s your chance… I code it with extra plug-in<br />
Just wait a little days and i will finish</p>
]]></description><link>https://forum.magicmirror.builders/post/105744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105744</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Thu, 10 Nov 2022 17:20:47 GMT</pubDate></item></channel></rss>
