<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Bulid]]></title><description><![CDATA[<p dir="auto">I’m planning a MM build in the coming weeks.<br />
I have a Pi 3 B+ on it way and am sourcing a monitor and mirror shortly.<br />
I’m trying to work out cables etc to run it all. Obviously I’ll need power for the monitor, but can I run the Pi somehow from it too or will it need it’s own supply.<br />
I really I’d love to hide all cables, but need to work out if I can get away with only one wall socket?<br />
Thanks in advance 🙏</p>
]]></description><link>https://forum.magicmirror.builders/topic/17363/new-bulid</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 17:15:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17363.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Nov 2022 22:07:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Bulid on Tue, 22 Nov 2022 18:17:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> I put a small power strip inside the frame and power the monitor, pi and anything else requiring 110v  and have one power cord out to an outlet…<br />
Dennis N6NG</p>
]]></description><link>https://forum.magicmirror.builders/post/106009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106009</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Tue, 22 Nov 2022 18:17:29 GMT</pubDate></item><item><title><![CDATA[Reply to New Bulid on Mon, 21 Nov 2022 06:53:05 GMT]]></title><description><![CDATA[<p dir="auto">I use a 12V power supply for the LCD screen. From the 12V power supply I have a step-down module which takes the 12V and puts 5V out for the Raspberry Pi. It runs perfectly fine for almost 5 years now.</p>
]]></description><link>https://forum.magicmirror.builders/post/105964</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105964</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Mon, 21 Nov 2022 06:53:05 GMT</pubDate></item><item><title><![CDATA[Reply to New Bulid on Sun, 20 Nov 2022 21:32:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> I decided to install power sockets inside the frame and power them with a normal plug. It required the frame to be slightly deeper, but not by much.</p>
]]></description><link>https://forum.magicmirror.builders/post/105955</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105955</guid><dc:creator><![CDATA[magmar]]></dc:creator><pubDate>Sun, 20 Nov 2022 21:32:25 GMT</pubDate></item><item><title><![CDATA[Reply to New Bulid on Sun, 20 Nov 2022 18:23:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickthebeer" aria-label="Profile: nickthebeer">@<bdi>nickthebeer</bdi></a> said in <a href="/post/105923">New Bulid</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> when I built my mirror I decided that I was never going to turn the monitor off so I removed all unnecessary peripherals from the pi and powered it via the monitors USB port so I have one cable from the power source which is to the monitor.</p>
<p dir="auto">I’ve tried this before and the problem I consistently have is that the USB ports on the monitor do not supply enough power to run a Raspberry Pi 3B+. That model is quite thirsty and requires 2.4 amps to run properly. It’s usually best to get a dedicated power supply (wall wart) for the Pi.</p>
<p dir="auto">Lately, I’ve been putting a <a href="https://smile.amazon.com/gp/product/B01JHWXL16/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">travel power strip</a> behind the monitor to power the monitor and Pi separately.</p>
]]></description><link>https://forum.magicmirror.builders/post/105940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105940</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sun, 20 Nov 2022 18:23:08 GMT</pubDate></item><item><title><![CDATA[Reply to New Bulid on Sun, 20 Nov 2022 07:27:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> when I built my mirror I decided that I was never going to turn the monitor off so I removed all unnecessary peripherals from the pi and powered it via the monitors USB port so I have one cable from the power source which is to the monitor.</p>
<p dir="auto">Alternatively you could get a small extension cord (maybe a 2-way) and then route that to the mirror and plug the monitor and pi into that.</p>
]]></description><link>https://forum.magicmirror.builders/post/105923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105923</guid><dc:creator><![CDATA[nickthebeer]]></dc:creator><pubDate>Sun, 20 Nov 2022 07:27:55 GMT</pubDate></item><item><title><![CDATA[Reply to New Bulid on Sun, 13 Nov 2022 22:47:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> typically the monitor will need a different voltage than the pi, 12/24 vs 5</p>
]]></description><link>https://forum.magicmirror.builders/post/105789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105789</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Nov 2022 22:47:15 GMT</pubDate></item></channel></rss>
