<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Keep having same error]]></title><description><![CDATA[<p dir="auto">Can someone help this newbie with what I’m doing wrong:</p>
<p dir="auto">magicmirror@2.21.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[20.11.2022 19:53.11.052] [LOG]   Starting MagicMirror: v2.21.0<br />
[20.11.2022 19:53.11.058] [LOG]   Loading config …<br />
[20.11.2022 19:53.11.068] [LOG]   Loading module helpers …<br />
[20.11.2022 19:53.11.077] [LOG]   No helper found for module: alert.<br />
[20.11.2022 19:53.11.105] [LOG]   Initializing new module helper …<br />
[20.11.2022 19:53.11.108] [LOG]   Module helper loaded: updatenotification<br />
[20.11.2022 19:53.11.111] [LOG]   No helper found for module: clock.<br />
[20.11.2022 19:53.11.492] [LOG]   Initializing new module helper …<br />
[20.11.2022 19:53.11.494] [LOG]   Module helper loaded: calendar<br />
[20.11.2022 19:53.11.498] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js</li>
<li>/home/svencarree/MagicMirror/js/app.js</li>
<li>/home/svencarree/MagicMirror/js/electron.js</li>
<li>/home/svencarree/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li></li>
</ul>
<p dir="auto">[20.11.2022 19:53.11.499] [LOG]   Loading module helpers …<br />
[20.11.2022 19:53.11.500] [LOG]   No helper found for module: alert.<br />
[20.11.2022 19:53.11.501] [LOG]   Initializing new module helper …<br />
[20.11.2022 19:53.11.502] [LOG]   Module helper loaded: updatenotification<br />
[20.11.2022 19:53.11.502] [LOG]   No helper found for module: clock.<br />
[20.11.2022 19:53.11.503] [LOG]   Initializing new module helper …<br />
[20.11.2022 19:53.11.504] [LOG]   Module helper loaded: calendar<br />
[20.11.2022 19:53.11.506] [ERROR] App threw an error during load<br />
[20.11.2022 19:53.11.509] [ERROR] Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)<br />
at n._resolveFilename (node:electron/js2c/browser_init:245:1105)<br />
at Module._resolveFilename (/home/svencarree/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (node:internal/modules/cjs/loader:785:27)<br />
at c._load (node:electron/js2c/asar_bundle:5:13343)<br />
at Module.require (node:internal/modules/cjs/loader:1012:19)<br />
at require (node:internal/modules/cjs/helpers:102:18)<br />
at Object. (/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js:9:17)<br />
at Module._compile (node:internal/modules/cjs/loader:1118:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)<br />
[20.11.2022 19:53.11.512] [ERROR] Whoops! There was an uncaught exception…<br />
[20.11.2022 19:53.11.517] [ERROR] Error: Cannot find module ‘request’<br />
Require stack:</li>
at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js’,<br />
‘/home/svencarree/MagicMirror/js/app.js’,<br />
‘/home/svencarree/MagicMirror/js/electron.js’,<br />
‘/home/svencarree/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
undefined<br />
]<br />
}<br />
[20.11.2022 19:53.11.520] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[20.11.2022 19:53.11.520] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
[20.11.2022 19:53.11.933] [LOG]   Launching application.<br />
MESA-LOADER: failed to retrieve device information<br />
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load driver: kms_swrast<br />
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load swrast driver</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/17383/keep-having-same-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 10:50:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17383.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Nov 2022 18:58:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 21:57:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svencarree" aria-label="Profile: svencarree">@<bdi>svencarree</bdi></a> said in <a href="/post/105943">Keep having same error</a>:</p>
<p dir="auto">Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’</p>
]]></description><link>https://forum.magicmirror.builders/post/105956</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105956</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Nov 2022 21:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 20:33:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the time and patience! But I’m still not finding it but I’m a real newbie…</p>
<p dir="auto">20.11.2022 19:53.11.506] [ERROR] App threw an error during load<br />
Require stack:</p>
<p dir="auto">/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js<br />
/home/svencarree/MagicMirror/js/app.js<br />
/home/svencarree/MagicMirror/js/electron.js<br />
/home/svencarree/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js<br />
Require stack:<br />
undefin</p>
<p dir="auto">This looks for me as the report of the error. But i’m not seeing wich library I should install under step 4 with npm install…</p>
]]></description><link>https://forum.magicmirror.builders/post/105953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105953</guid><dc:creator><![CDATA[svencarree]]></dc:creator><pubDate>Sun, 20 Nov 2022 20:33:08 GMT</pubDate></item><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 20:05:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svencarree" aria-label="Profile: svencarree">@<bdi>svencarree</bdi></a> see the messages u posted to start this topic.  just before either  indent is the message you are looking for</p>
]]></description><link>https://forum.magicmirror.builders/post/105952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105952</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Nov 2022 20:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 19:50:48 GMT]]></title><description><![CDATA[<p dir="auto">Hahaha sorry for the inconvinience!  In the folder *MMM0BMW-OW’  there is a ‘package.json’ file.  But at step 2 and 4 I really don’t know wich library is missing.</p>
]]></description><link>https://forum.magicmirror.builders/post/105951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105951</guid><dc:creator><![CDATA[svencarree]]></dc:creator><pubDate>Sun, 20 Nov 2022 19:50:48 GMT</pubDate></item><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 19:45:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> you replied to the topic  you deleted</p>
<ol>
<li>
<p dir="auto">find the message</p>
</li>
<li>
<p dir="auto">get the name of the missing library (???)</p>
</li>
<li>
<p dir="auto">look in the module folder for package.json<br />
4 if it does  NOT exist,  create it<br />
w the<br />
npm init -y<br />
command</p>
</li>
<li>
<p dir="auto">npm install ???  (from step 2)</p>
</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/105949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105949</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Nov 2022 19:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to Keep having same error on Sun, 20 Nov 2022 19:24:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svencarree" aria-label="Profile: svencarree">@<bdi>svencarree</bdi></a> see <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105946</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Nov 2022 19:24:10 GMT</pubDate></item></channel></rss>
