<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Vcgencmd display cron job not working]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">After a much needed update to my raspberry pi4, my cronjobs</p>
<p dir="auto">0  7 * * * root /usr/bin/vcgencmd display_power 1<br />
0 22 * * * root /usr/bin/vcgencmd display_power 0</p>
<p dir="auto">have stopped working.  Even running these in terminal is fruitless.  Any work around or suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17403/vcgencmd-display-cron-job-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 07:53:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17403.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Nov 2022 14:56:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Vcgencmd display cron job not working on Sun, 27 Nov 2022 07:00:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> I assume you are now on Bullseye - see here <a href="https://forum.magicmirror.builders/topic/16865/mmm-remotecontrol-or-vcgencmd-issue">https://forum.magicmirror.builders/topic/16865/mmm-remotecontrol-or-vcgencmd-issue</a> and change the settings to use the fake KMS driver (fkms) instead of kms.</p>
]]></description><link>https://forum.magicmirror.builders/post/106148</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106148</guid><dc:creator><![CDATA[thobach]]></dc:creator><pubDate>Sun, 27 Nov 2022 07:00:37 GMT</pubDate></item></channel></rss>
