<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hiding degree Fahrenheit]]></title><description><![CDATA[<p dir="auto">In both the MMM-Weather-Now and MMM-3Day-Forecast, how would I not show the “(43 o F)”? My config.js is metric, but looking at the code it appears whichever you select the other shows in brackets.</p>
<p dir="auto"><img src="/assets/uploads/files/1669656117159-3f43bf15-8baf-4a96-b241-9c0381948a36-image.png" alt="3f43bf15-8baf-4a96-b241-9c0381948a36-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/17413/hiding-degree-fahrenheit</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 23:06:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17413.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Nov 2022 17:26:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hiding degree Fahrenheit on Wed, 30 Nov 2022 15:03:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bicolorbore586" aria-label="Profile: bicolorbore586">@<bdi>bicolorbore586</bdi></a> it would block updates.<br />
but you could save your changes,<br />
copy file,<br />
git checkout xxx.js<br />
then update<br />
then check if there are any impacts<br />
and re-apply them after update</p>
<p dir="auto">you could also fork the repo, and run that.<br />
update and submit or back to module author</p>
<p dir="auto">maybe they would take it as a change… I didn’t look at last update date to see if module is still actively maintained ( modified just last month)</p>
]]></description><link>https://forum.magicmirror.builders/post/106269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106269</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 30 Nov 2022 15:03:38 GMT</pubDate></item><item><title><![CDATA[Reply to Hiding degree Fahrenheit on Wed, 30 Nov 2022 13:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> what impact would it have if I changed the code? for updates etc?</p>
]]></description><link>https://forum.magicmirror.builders/post/106267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106267</guid><dc:creator><![CDATA[bicolorbore586]]></dc:creator><pubDate>Wed, 30 Nov 2022 13:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to Hiding degree Fahrenheit on Wed, 30 Nov 2022 13:18:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bicolorbore586" aria-label="Profile: bicolorbore586">@<bdi>bicolorbore586</bdi></a> looking at the code, it’s hard coded to show the opposite.</p>
<p dir="auto">you could remove the feels like line completely w css. but not part.</p>
<p dir="auto">only other way is to change the code</p>
]]></description><link>https://forum.magicmirror.builders/post/106266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106266</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 30 Nov 2022 13:18:31 GMT</pubDate></item></channel></rss>
