<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarWeek is broken]]></title><description><![CDATA[<p dir="auto">I’m setting up my MagicMirror dashboard and like the layout and functionality of MMM-CalendarWeek, but realize the incorrect days of events is going to be a deal breaker. It seems that the module is been abandoned with a lot of unanswered issues posted to the GitHub page.</p>
<p dir="auto">I’m considering forking it and trying to fix the problems, but thought I’d ask first if anyone else found an alternative or maybe a fork of the module that works better. Fixing it will take me time as I’m new to NodeJS and MM modules.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17436/mmm-calendarweek-is-broken</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 22:17:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17436.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Dec 2022 06:25:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarWeek is broken on Mon, 02 Jan 2023 23:52:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> Thanks for this!  For some reason I didn’t see your reply last time I checked the forum.  I appreciate the tips!</p>
]]></description><link>https://forum.magicmirror.builders/post/106865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106865</guid><dc:creator><![CDATA[shizzlesticks]]></dc:creator><pubDate>Mon, 02 Jan 2023 23:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarWeek is broken on Tue, 06 Dec 2022 18:53:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shizzlesticks" aria-label="Profile: shizzlesticks">@<bdi>shizzlesticks</bdi></a> Couple of options, the best I could think of listed below:</p>
<p dir="auto">If you want the same kind of layout, with a little CSS magic, you could use MMM-Calendar3Agenda multiple times, each one set to a different relative day.</p>
<p dir="auto">(startDayIndex &amp; endDayIndex config options used)</p>
<p dir="auto">Alternatively, if you want to save space, just use MMM-Calendar3Agenda as is, and it lists the calendar items sensibly.</p>
<p dir="auto">Using MMM-Calendar3 products require the use of the base calendar for event population.</p>
<p dir="auto">mmrize has lots of Calendar3 products to do work on calendars - check them all out at <a href="https://github.com/orgs/MMRIZE/repositories?type=all" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/orgs/MMRIZE/repositories?type=all</a></p>
]]></description><link>https://forum.magicmirror.builders/post/106443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106443</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 06 Dec 2022 18:53:55 GMT</pubDate></item></channel></rss>
