<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error octomirror module]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/6260/octomirror-module-monitor-control-an-octoprint-3d-printer-server">[octomirror-module] Monitor &amp; Control an OctoPrint 3D Printer Server</a></p>
<p dir="auto">Hello, I try to install the module on my magicmirror. but I have one error.</p>
<p dir="auto">When I lauch the npm start dev, I have this :</p>
<p dir="auto">starting module: octomirror-module<br />
octomirror-module.js:110 Uncaught ReferenceError: OctoPrintClient is not defined<br />
at Class.start (octomirror-module.js:110:29)<br />
at startModules (loader.js:51:11)<br />
at loader.js:38:6<br />
at HTMLLinkElement.stylesheet.onload (loader.js:210:7)</p>
<p dir="auto">in the config.js I have<br />
{<br />
module: “octomirror-module”,<br />
position: “middle_center”,<br />
config: {<br />
//js octomirror   stream.setAttribute (‘width’, ‘300’);<br />
debugMode: true,<br />
url: “<a href="http://192.168.0.30" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.0.30</a>”,<br />
printerName: “D12 230”,<br />
api_key: “CC9E078BF70443DC94CB4C664E13E872”,<br />
streamUrl: ‘<a href="http://192.168.0.30/webcam/?action=stream/" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.0.30/webcam/?action=stream/</a>’,<br />
interactive: false,<br />
showDetailsWhenOffline: false,<br />
}<br />
},</p>
<p dir="auto">thanks for help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17462/error-octomirror-module</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 22:30:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17462.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Dec 2022 13:02:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error octomirror module on Thu, 15 Dec 2022 13:39:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/myayo001" aria-label="Profile: myayo001">@<bdi>myayo001</bdi></a> I just searched GitHub and octomirror  and found multiple.</p>
<p dir="auto">some older ones don’t use the library producing the error.</p>
<p dir="auto">I know nothing about theodule itself, just debugging the error</p>
]]></description><link>https://forum.magicmirror.builders/post/106599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106599</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Dec 2022 13:39:37 GMT</pubDate></item><item><title><![CDATA[Reply to Error octomirror module on Thu, 15 Dec 2022 13:21:29 GMT]]></title><description><![CDATA[<p dir="auto">You use an another module?</p>
]]></description><link>https://forum.magicmirror.builders/post/106597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106597</guid><dc:creator><![CDATA[myayo001]]></dc:creator><pubDate>Thu, 15 Dec 2022 13:21:29 GMT</pubDate></item><item><title><![CDATA[Reply to Error octomirror module on Thu, 15 Dec 2022 13:18:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/myayo001" aria-label="Profile: myayo001">@<bdi>myayo001</bdi></a> I think you installed this version?</p>
<p dir="auto"><a href="https://github.com/shbatm/octomirror-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/shbatm/octomirror-module</a></p>
<p dir="auto">I would open an.issue on his GitHub page to engage the author.</p>
<p dir="auto">you might also open the developers window ctrl-shift-i on the keyboard and select the console tab and add a unique part of the module name, octo for example , to the filter field.</p>
<p dir="auto">it might show any errors</p>
]]></description><link>https://forum.magicmirror.builders/post/106596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106596</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Dec 2022 13:18:49 GMT</pubDate></item></channel></rss>
