<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[only desktop since update some modules]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">maybe someone can help me.<br />
Yesterday I updated a few modules via MMM-RemoteControl, since then my mirror no longer starts. I only see the desktop.</p>
<p dir="auto">Thank you Dirk</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMir | &gt; magicmirror@2.21.0 start
0|MagicMir | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|MagicMir |
0|MagicMir |
0|MagicMir |
0|MagicMir |
0|MagicMir |
0|MagicMir |
0|MagicMir |
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | A JavaScript error occurred in the main process
0|MagicMir | Uncaught Exception:
0|MagicMir | Error: Cannot find module '/home/pi/MagicMirror/node_modules/range_check/dist/range-check.umd.js'. Please verify that the package.json has a valid "main" entry
0|MagicMir |     at tryPackage (node:internal/modules/cjs/loader:360:19)
0|MagicMir |     at Module._findPath (node:internal/modules/cjs/loader:573:18)
0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:926:27)
0|MagicMir |     at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
0|MagicMir |     at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
0|MagicMir |     at c._load (node:electron/js2c/asar_bundle:5:13343)
0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/express-ipfilter/lib/ipfilter.js:14:20)
0|MagicMir | [3053:1217/110253.460777:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|MagicMir | [3073:1217/110253.750405:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
]]></description><link>https://forum.magicmirror.builders/topic/17464/only-desktop-since-update-some-modules</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 15:42:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17464.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Dec 2022 10:11:29 GMT</pubDate><ttl>60</ttl></channel></rss>
