<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GooglePhotos not showing images]]></title><description><![CDATA[<p dir="auto">My Google Photos are not showing up on the Mirror software, it looks like they are being transferred from the Google API (not an auth issue) since when I go in with npm start dev I can find the photos under sources, but they are not showing up on the interface. Can anyone help? Here’s my config. It’s giving me an error that’s shown below.</p>
<p dir="auto"><img src="/assets/uploads/files/1671491733774-f66f3ba0-f91b-4d4b-99a8-7eaef4c0a97e-image.png" alt="f66f3ba0-f91b-4d4b-99a8-7eaef4c0a97e-image.png" class=" img-fluid img-markdown" /></p>
<pre><code>{
		  module: "MMM-GooglePhotos",
		  position: "bottom_center",
				albums: ["Magic Mirror"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
				updateInterval: 1000 * 60, // minimum 10 seconds.
				sort: "new", // "old", "random"
				uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
				condition: {
					fromDate: null, // Or "2018-03", RFC ... format available
					toDate: null, // Or "2019-12-25",
					minWidth: null, // Or 400
					maxWidth: null, // Or 8000
					minHeight: null, // Or 400
					maxHeight: null, // Or 8000
					minWHRatio: null,
					maxWHRatio: null,
					// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   &lt; 1 : Portraited Photo, &gt; 1 : Landscaped Photo)
				showWidth: 800, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
				showHeight: 600,
				timeFormat: "YYYY/MM/DD HH:mm", // Or `relative` can be used.
]]></description><link>https://forum.magicmirror.builders/topic/17469/mmm-googlephotos-not-showing-images</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 16:01:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17469.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Dec 2022 23:16:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Fri, 23 Dec 2022 17:55:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ctilt" aria-label="Profile: ctilt">@<bdi>ctilt</bdi></a> glad you found it.  basically it crashed mm  but the modules kept running.  but couldn’t find their content to update</p>
]]></description><link>https://forum.magicmirror.builders/post/106694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106694</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 23 Dec 2022 17:55:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Fri, 23 Dec 2022 17:13:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That was totally it, I had one as blank instead of removing the position altogether, Happy Holidays and thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/106693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106693</guid><dc:creator><![CDATA[ctilt]]></dc:creator><pubDate>Fri, 23 Dec 2022 17:13:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Fri, 23 Dec 2022 17:06:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ctilt" aria-label="Profile: ctilt">@<bdi>ctilt</bdi></a> can u check the position of all the modules listed before MMM-GooglePhotos…</p>
<p dir="auto">I think one of them is wrong…</p>
]]></description><link>https://forum.magicmirror.builders/post/106692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106692</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 23 Dec 2022 17:06:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Fri, 23 Dec 2022 16:57:15 GMT]]></title><description><![CDATA[<p dir="auto">Nope, changing the position didn’t work either. Any other thoughts?</p>
]]></description><link>https://forum.magicmirror.builders/post/106691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106691</guid><dc:creator><![CDATA[ctilt]]></dc:creator><pubDate>Fri, 23 Dec 2022 16:57:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Fri, 23 Dec 2022 17:01:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ctilt" aria-label="Profile: ctilt">@<bdi>ctilt</bdi></a> i put mine at position:“fullscreen_below” to have the images as big as desktop, behind other content, and it worked fine…</p>
<p dir="auto">bottom_center didn’t work well…  had some of the shading but not the pic.</p>
]]></description><link>https://forum.magicmirror.builders/post/106670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106670</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 23 Dec 2022 17:01:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos not showing images on Tue, 20 Dec 2022 13:45:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ctilt" aria-label="Profile: ctilt">@<bdi>ctilt</bdi></a> have you tried other position?</p>
]]></description><link>https://forum.magicmirror.builders/post/106669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106669</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 20 Dec 2022 13:45:41 GMT</pubDate></item></channel></rss>
