<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[monitor power button unreachable]]></title><description><![CDATA[<p dir="auto">hey im looking for advice on how to fix a problem with my magicmirror monitor. so i have built a magicmirror as a christmas present and everything software side works but when i plug everything together the display doesnt automatically turn on, i have to press the monitors power button. but the problem is that the powerbutton is on the other side against the glass already stuck on and i cant rebuild it in time. i checked if i could use cec client to turn it on but my monitor doesnt support that. any other suggestions? thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/17470/monitor-power-button-unreachable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 00:16:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17470.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Dec 2022 09:10:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to monitor power button unreachable on Sun, 01 Jan 2023 08:07:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> lol yeah that config file can be touchy. I’m glad you figured it out. Happy new year!</p>
]]></description><link>https://forum.magicmirror.builders/post/106793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106793</guid><dc:creator><![CDATA[jturczak]]></dc:creator><pubDate>Sun, 01 Jan 2023 08:07:54 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Mon, 26 Dec 2022 20:39:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jturczak" aria-label="Profile: jturczak">@<bdi>jturczak</bdi></a> hey sorry for late reply thing were alittle bit stressful before christmas turn out i was just stupid and there was just an error in the config when the mirror didnt connect to the home network and because of that i just got a blank mirror i didnt notice that it was on but just not displaying anything. thank you so much for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/106715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106715</guid><dc:creator><![CDATA[SILLEN 0]]></dc:creator><pubDate>Mon, 26 Dec 2022 20:39:21 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Sun, 25 Dec 2022 13:28:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jturczak" aria-label="Profile: jturczak">@<bdi>jturczak</bdi></a> just fyi.  every post from users with less than 2 reputation are reviewed before being posted on the forum.  this stops all the spam we get.</p>
]]></description><link>https://forum.magicmirror.builders/post/106702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106702</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 25 Dec 2022 13:28:57 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Sun, 25 Dec 2022 05:10:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> Doesn’t your MM run off a Raspberry Pi? When it powers up you should get a signal to power the monitor from the HDMI cable… check your pi settings also for autoboot</p>
]]></description><link>https://forum.magicmirror.builders/post/106699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106699</guid><dc:creator><![CDATA[jturczak]]></dc:creator><pubDate>Sun, 25 Dec 2022 05:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Sun, 25 Dec 2022 05:07:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> look in the monitor set up itself.</p>
]]></description><link>https://forum.magicmirror.builders/post/106700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106700</guid><dc:creator><![CDATA[jturczak]]></dc:creator><pubDate>Sun, 25 Dec 2022 05:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Sun, 25 Dec 2022 05:04:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> you might try looking in the monitor setup for a power option that turns on the monitor when power is applied.</p>
]]></description><link>https://forum.magicmirror.builders/post/106696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106696</guid><dc:creator><![CDATA[jturczak]]></dc:creator><pubDate>Sun, 25 Dec 2022 05:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Wed, 21 Dec 2022 17:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> Would you be able to dismantle it (carefully) enough to get rear access to the button?</p>
<p dir="auto">I was thinking either to be able to remove and relocate it perhaps, or to solder a switch or other solution in parallel to the existing one to put that somewhere accessible?</p>
]]></description><link>https://forum.magicmirror.builders/post/106680</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106680</guid><dc:creator><![CDATA[DarrenHill]]></dc:creator><pubDate>Wed, 21 Dec 2022 17:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to monitor power button unreachable on Wed, 21 Dec 2022 13:33:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillen-0" aria-label="Profile: SILLEN-0">@<bdi>SILLEN-0</bdi></a> sadly I don’t think there is any easy solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/106678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106678</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 21 Dec 2022 13:33:46 GMT</pubDate></item></channel></rss>
