<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cast from Server]]></title><description><![CDATA[<p dir="auto">Hi, I’d like to know about having magic mirror installable as a Chromecast app.</p>
<p dir="auto">Ideally, I’d like to be able to host a version of magic mirror centrally somewhere and use a Chromecast as a receiver for a magic mirror, which near-enough works out of the box.</p>
<p dir="auto">I know a similar setup is possible now, with centrally hosting the server side and having a separate receiver, but I’d like to use the Chromecast as the setup is so simple (compared to installing &amp; configuring something like a pi-zero)</p>
]]></description><link>https://forum.magicmirror.builders/topic/1750/cast-from-server</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 23:38:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1750.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Feb 2017 17:04:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cast from Server on Mon, 20 Mar 2017 22:31:28 GMT]]></title><description><![CDATA[<p dir="auto">I put together a small module which allows this. It initially needs to be started out of the browser but then the Chromecast directly loads the content from the server.</p>
<p dir="auto">You can try it out: <a href="https://github.com/flo80/MMM-chromecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/flo80/MMM-chromecast</a></p>
]]></description><link>https://forum.magicmirror.builders/post/17947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17947</guid><dc:creator><![CDATA[flo80]]></dc:creator><pubDate>Mon, 20 Mar 2017 22:31:28 GMT</pubDate></item><item><title><![CDATA[Reply to Cast from Server on Tue, 14 Feb 2017 11:07:51 GMT]]></title><description><![CDATA[<p dir="auto">You can get this to work if you create a custom receiver for the Chromecast. A bit more work but definately doable.</p>
<p dir="auto">More info here:<br />
<a href="https://developers.google.com/cast/docs/custom_receiver" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/cast/docs/custom_receiver</a></p>
]]></description><link>https://forum.magicmirror.builders/post/14513</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14513</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Tue, 14 Feb 2017 11:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to Cast from Server on Tue, 14 Feb 2017 09:37:44 GMT]]></title><description><![CDATA[<p dir="auto">The simple answer is no not really.</p>
<p dir="auto">I have done some experimentation and if I run the mirror in chrome from the server machine and then cast that page then a still snapshot of the mirror appears on my cast device.</p>
]]></description><link>https://forum.magicmirror.builders/post/14508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14508</guid><dc:creator><![CDATA[izanbard]]></dc:creator><pubDate>Tue, 14 Feb 2017 09:37:44 GMT</pubDate></item></channel></rss>
