<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR-Sensor-Lite not switching off]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I installed my PIR incl. the aforementioned module.</p>
<p dir="auto">I have configured the module to xrandr  on HDMI-1 and verified whether it works on the command line, which it does.</p>
<p dir="auto">Test of the sensor works fine too, module also sees movement and restarts the countdown.<br />
However, when it reaches 0, the screen doesn’t turn off. I don’t see any log that it would want to turn off, neither when doing npm run start:dev nor through the pm2 logs.</p>
<p dir="auto">Just updated to v2.22.0, just in case - but no luck.<br />
Any ideas or pointers?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/17500/mmm-pir-sensor-lite-not-switching-off</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 15:39:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17500.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Jan 2023 20:15:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Fri, 03 Feb 2023 19:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Found the error - xrandr needs a sudo in front, otherwise it doesn’t execute.</p>
]]></description><link>https://forum.magicmirror.builders/post/107663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107663</guid><dc:creator><![CDATA[djlagaffe]]></dc:creator><pubDate>Fri, 03 Feb 2023 19:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Thu, 04 May 2023 01:45:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djlagaffe" aria-label="Profile: djlagaffe">@<bdi>djlagaffe</bdi></a> - I was able to get it working with xrandr with a small modification to the <code>node_helper.js</code> file. I’ll submit a PR soon.</p>
]]></description><link>https://forum.magicmirror.builders/post/109164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109164</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 04 May 2023 01:45:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Fri, 03 Feb 2023 19:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Found the error - xrandr needs a sudo in front, otherwise it doesn’t execute.</p>
]]></description><link>https://forum.magicmirror.builders/post/107663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107663</guid><dc:creator><![CDATA[djlagaffe]]></dc:creator><pubDate>Fri, 03 Feb 2023 19:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Sat, 14 Jan 2023 11:53:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry, one add-on no debug messages either in the logs, nor via npm run start:dev</p>
]]></description><link>https://forum.magicmirror.builders/post/107232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107232</guid><dc:creator><![CDATA[djlagaffe]]></dc:creator><pubDate>Sat, 14 Jan 2023 11:53:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Sat, 14 Jan 2023 11:45:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : yes, however no luck or any log entry at all in pm2 logs mm - am I looking in the wrong place?</p>
]]></description><link>https://forum.magicmirror.builders/post/107253</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107253</guid><dc:creator><![CDATA[djlagaffe]]></dc:creator><pubDate>Sat, 14 Jan 2023 11:45:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Sat, 14 Jan 2023 11:41:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : I did check with the scripts and the PIR itself works. I have also activated the countdown timer, thus the communication between the PIR, the script and MM in general works. What I do not see is that the command to switch off the screen is executed (or even sent).</p>
<p dir="auto">I have verified the script and the command to check whether the command itself works on my installation, and yes, it does.<br />
So it should be something not triggering the switch-off / on command. However I have not been able to put my finger on it yet…</p>
]]></description><link>https://forum.magicmirror.builders/post/107252</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107252</guid><dc:creator><![CDATA[djlagaffe]]></dc:creator><pubDate>Sat, 14 Jan 2023 11:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Tue, 03 Jan 2023 18:45:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djlagaffe" aria-label="Profile: djlagaffe">@<bdi>djlagaffe</bdi></a> also note the info in the doc after the options table about problems with bullseye and/or buster</p>
]]></description><link>https://forum.magicmirror.builders/post/106894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106894</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Jan 2023 18:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Tue, 03 Jan 2023 18:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djlagaffe" aria-label="Profile: djlagaffe">@<bdi>djlagaffe</bdi></a>  did u enable debugMode?</p>
<p dir="auto">from doc</p>
<p dir="auto">debugMode: true</p>
]]></description><link>https://forum.magicmirror.builders/post/106890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106890</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Jan 2023 18:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Tue, 03 Jan 2023 18:41:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> No. are they yours?.. I’ll take a look…<br />
Dennis</p>
]]></description><link>https://forum.magicmirror.builders/post/106889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106889</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Tue, 03 Jan 2023 18:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Tue, 03 Jan 2023 18:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n6ng" aria-label="Profile: N6NG">@<bdi>N6NG</bdi></a> did you run any of the python test scripts to verify that the sensor works outside of MagicMirror?</p>
<p dir="auto">if it doesn’t, then MagicMirror can’t fix it…</p>
]]></description><link>https://forum.magicmirror.builders/post/106888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106888</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Jan 2023 18:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite not switching off on Tue, 03 Jan 2023 18:38:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djlagaffe" aria-label="Profile: djlagaffe">@<bdi>djlagaffe</bdi></a> It’s the one module I’ve never been able to make work… I’ve tried everyone I can find, I’ve check to make sure I have the correct pin number and that the PIR itself worked but I still can’t find one that does the job… I’ve not even had any luck with the EXT-PIR on 4th party modules and not been able to make that one work.  I wish you all the best and I’ll be watching and hope you find the problem.  I’ve been watching for some answers but  not yet…<br />
Good Luck<br />
Dennis N6NG</p>
]]></description><link>https://forum.magicmirror.builders/post/106886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106886</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Tue, 03 Jan 2023 18:38:09 GMT</pubDate></item></channel></rss>
