<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotate screen problem when MM starts]]></title><description><![CDATA[<p dir="auto">Hi everybody</p>
<p dir="auto">i need help about rotate screen when MM starts. I use a screen on vertical position for my MM.<br />
When i start my raspberry (pi3 b+ on bulleye and i used <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> link to install MM) the boot logo is on horizontal position and when the graphical interface is shown, it’s on vertical position. (everything is ok, i used preference rotation to rotate the screen on right).<br />
After that, i start my MM with PM2 and MM starts vertically. But after 2 sec, the screen rotate on horizontal position and when i quit MM with Ctrl + Q, the graphical interface is also on horizontal position.</p>
<p dir="auto">Have you an idea ? (CSS on MM is blank)</p>
<p dir="auto">thx for next answers</p>
]]></description><link>https://forum.magicmirror.builders/topic/17509/rotate-screen-problem-when-mm-starts</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 06:52:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17509.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Jan 2023 19:06:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Sun, 08 Jan 2023 05:26:58 GMT]]></title><description><![CDATA[<p dir="auto">I don’t know about the Pi3, but on the Pi4 you just go to display settings and tell it to go vertical… easier than all this programming that I never got to work with my MM</p>
]]></description><link>https://forum.magicmirror.builders/post/107081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107081</guid><dc:creator><![CDATA[jturczak]]></dc:creator><pubDate>Sun, 08 Jan 2023 05:26:58 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Thu, 05 Jan 2023 12:30:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> ah, the xrandr under the covers…</p>
<p dir="auto">glad u found it.  thanks for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/106928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106928</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 05 Jan 2023 12:30:41 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Thu, 05 Jan 2023 07:29:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thx for your support. i found the guilty module after 2 hours. it’s MMM-PIR-Sensor-Lite. There is an hidden rotate parameter and the default parameter is normal rotate. that’s why when MM starts there was a rotate screen on normal position.</p>
<p dir="auto">So for people with rotate problem when MM Starts and if you have MMM-PIR-Sensor-Lite, add this parameter in your config.js:</p>
<p dir="auto">rotation	Direction of content rotation.</p>
<p dir="auto">Possible values: ‘normal’, ‘left’, ‘right’ or ‘inverted’<br />
Default value: ‘normal’</p>
]]></description><link>https://forum.magicmirror.builders/post/106927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106927</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Thu, 05 Jan 2023 07:29:37 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Wed, 04 Jan 2023 20:33:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> makes no sense.</p>
<p dir="auto">do<br />
pm2 stop all<br />
pm2 delete 0<br />
pm2 save</p>
<p dir="auto">then boot to rotated<br />
pm2 start installers/pm2_MagicMirror.json<br />
should be vertical<br />
then ctrl-m<br />
pm2 save</p>
<p dir="auto">then sudo reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/106924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106924</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Jan 2023 20:33:55 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Wed, 04 Jan 2023 19:53:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> if i turn on left right or inverted, when i start MM screen rotate on normal position</p>
]]></description><link>https://forum.magicmirror.builders/post/106919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106919</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Wed, 04 Jan 2023 19:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Wed, 04 Jan 2023 19:40:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> u have to edit the image and rotate it</p>
]]></description><link>https://forum.magicmirror.builders/post/106915</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106915</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Jan 2023 19:40:36 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Wed, 04 Jan 2023 19:38:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thx for your fast answer<br />
release is</p>
<p dir="auto">No LSB modules are available.<br />
Distributor ID:	Raspbian<br />
Description:	Raspbian GNU/Linux 11 (bullseye)<br />
Release:	11<br />
Codename:	bullseye</p>
<p dir="auto">image below is my orientation screen. how i turn the black slash screen ?</p>
<p dir="auto">![alt text]<a href="https://ibb.co/bK1s7Gc" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/bK1s7Gc</a>(image url)</p>
]]></description><link>https://forum.magicmirror.builders/post/106914</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106914</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Wed, 04 Jan 2023 19:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate screen problem when MM starts on Wed, 04 Jan 2023 19:19:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> which is version is this?</p>
<p dir="auto">lsb_release -a</p>
<p dir="auto">will tell</p>
<p dir="auto">if u pm2 stop all, and then sudo reboot</p>
<p dir="auto">the system should come up without mm and that will be the orientation.</p>
<p dir="auto">as for the slash screen, the image has to beadenin that orientation.we only supply horizontal image</p>
]]></description><link>https://forum.magicmirror.builders/post/106913</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106913</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Jan 2023 19:19:52 GMT</pubDate></item></channel></rss>
